#include<reg52.h>
#include<intrins.h>
#define uint8 unsigned char
#define uint16 unsigned int
#define CMD 0x00
#define DAT 0x01
#define DataPort P0//LCD數(shù)據(jù)口
unsigned char N,flag_1s,num;
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
uint8 Z=0;
uint8 count=0;
/**ms級(jí)延時(shí)子程序**/
void delay(uint16 t)
uint16 a;
for(;t>0;t--)
for(a=123;a>0;a--);
/**LCD時(shí)序**/
void write_LCD(uint8 dat,bit rs)
E=0;
RW=0;
RS=rs;//選擇指令or數(shù)據(jù)
_nop_();
_nop_();
_nop_();
E=1;
_nop_();//delay(1);
_nop_();
_nop_();
DataPort=dat;//將數(shù)據(jù)送到LCD數(shù)據(jù)口
_nop_();
_nop_();
_nop_();
E=0;
delay(1);
/**LCD選擇顯示位置子函數(shù)**/
void SetXY(uint8 x,uint8 y)
x=x&0x0f;//防止X、Y 超過量程
y=y&0x01;
if(y)
write_LCD(0x80+x,CMD);
write_LCD(0xc0+x,CMD);
/**轉(zhuǎn)速數(shù)值轉(zhuǎn)換子函數(shù)**/
void disload(uint16 a)
SetXY(4,0);
write_LCD(a/1000+'0',DAT);
write_LCD(a%1000/100+'0',DAT);
write_LCD(a%100/10+'0',DAT);
write_LCD(a%10+'0',DAT);
write_LCD('r',DAT);
write_LCD('/',DAT);
write_LCD('m',DAT);
write_LCD('i',DAT);
write_LCD('n',DAT);
/**LCD字符指針函數(shù)**/
void LCD_wrstr(uint8*str)
while(*str!='\0')
write_LCD(*str,DAT);
str++;
/**初始化子程序**/
void All_init()
delay(500);
//write_LCD(0x38,CMD);
write_LCD(0x0c,CMD);
write_LCD(0x01,CMD);
delay(10);
SetXY(0,1);//設(shè)置標(biāo)題顯示位置
LCD_wrstr("Tachometer:");
TMOD=0x20;
ET0=1;//打開定時(shí)器0的中斷
TR0=1;//打開定時(shí)器0
TH0=(65536-50000)/256;//裝入初值
TL0=(65536-50000)%256;
IT0=1;//外部中斷0為下降沿中斷
EX0=1;//打開外部中斷
EA=1;//打開總中斷
/***串口初始化****/
void init_serialcom( void ) //串口通信初始設(shè)定
SCON = 0x50 ; //UART為模式1,8位數(shù)據(jù),允許接收
PCON = 0x80 ; //SMOD=1;
TH1 = 0xfd ; //Baud:19200 fosc="11".0592MHz
TL1 = 0xfd;
IE |= 0x90 ; //Enable Serial Interrupt
TR1 = 1 ; // timer 1 run
ES=1;
void ser() interrupt 4 //串口中斷
RI=0;
N=SBUF;
flag_1s=1;
All_init();//初始化
init_serialcom();//串口初始化
if(flag_1s==1)
flag_1s=0;
ES=0;
SBUF=N;
while(!TI);
TI=0;
ES=1;
disload(N);
/**定時(shí)器0中斷服務(wù)子程序**/
void timer0() interrupt 1
num++;
if(num==20)
num=0;
EX0=0;//關(guān)閉外部中斷0
N=60*Z;//計(jì)算轉(zhuǎn)速
//Z=0;//初始化圈數(shù)
flag_1s=1;//1s標(biāo)志位置1
TH0=0;//重新賦值
TL0=0;
EX0=1;//打開外部中斷0,開始計(jì)數(shù)。
void wai0() interrupt 0
count++;
if(count==1) //一次外部脈沖,電機(jī)轉(zhuǎn)一圈。
Z++;//轉(zhuǎn)圈+1
count=0;//初始計(jì)數(shù)值
