#include<reg52.h>
sbit dula=P3^4;
sbit wela=P3^5;
sbit led=P0^1;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delayms(uint);
void display(uchar,uchar);
uchar num,num1,num2,shi,ge;
TMOD=0x01;
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
// TH1=(65536-45872)/256;
// TL1=(65536-45872)%256;
EA=1;
ET0=1;
// ET1=1;
TR0=1;
// TR1=1;
display(shi,ge);
void display(uchar shi,uchar ge)
P0=table[shi];
dula=1;
dula=0;
P0=0xfe;
wela=1;
wela=0;
delayms(2);
P0=table[ge];
dula=1;
dula=0;
P0=0xfd;
wela=1;
wela=0;
delayms(2);
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void T0_time()interrupt 1
num1++;
if(num1==4)
num1=0;
led=~led;
num2++;
if(num2==20)
num2=0;
num++;
if(num==60)
num=0;
shi=num/10;
ge=num%10;
void T1_time()interrupt 3
num2++;
if(num2==20)
num2=0;
num++;
if(num==60)
num=0;
shi=num/10;
ge=num%10;
