這是我今天做的單片機實驗,附件里面包含INT0及INT1中斷計數源代碼,proteus仿真工程文件
說明:每次按下第1個計數鍵時,第1組計數值累加并顯示在右邊3只數碼管上, 每次按下第2個計數鍵時,第2組計數值累加并顯示在左邊3只數碼管上,后兩個按鍵分別清零。
單片機源代碼:
- #include<reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit K3=P3^4; //2個清零鍵
- sbit K4=P3^5;
- //數碼管段碼與位碼
- uchar code DSY_CODE[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};
- uchar code DSY_Scan_Bits[]={0x20,0x10,0x08,0x04,0x02,0x01};
- //2組計數的顯示緩沖,前3位一組,后3位一組
- uchar data Buffer_Counts[]={0,0,0,0,0,0};
- uint Count_A,Count_B=0;
- //延時
- void DelayMS(uint x)
- uchar t;
- while(x--) for(t=0;t<120;t++);
- //數據顯示
- void Show_Counts()
- uchar i;
- Buffer_Counts[2]=Count_A/100;
- Buffer_Counts[1]=Count_A%100/10;
- Buffer_Counts[0]=Count_A%10;
- if( Buffer_Counts[2]==0)
- Buffer_Counts[2]=0x0a;
- if( Buffer_Counts[1]==0)
- Buffer_Counts[1]=0x0a;
- Buffer_Counts[5]=Count_B/100;
- Buffer_Counts[4]=Count_B%100/10;
- Buffer_Counts[3]=Count_B%10;
- if( Buffer_Counts[5]==0)
- Buffer_Counts[5]=0x0a;
- if( Buffer_Counts[4]==0)
- Buffer_Counts[4]=0x0a;
- for(i=0;i<6;i++)
- P2=DSY_Scan_Bits[i];
- P1=DSY_CODE[Buffer_Counts[i]];
- DelayMS(1);
- //主程序
- void main()
- IE=0x85;
- PX0=1; //中斷優先
- IT0=1;
- IT1=1;
- while(1)
- if(K3==0) Count_A=0;
- if(K4==0) Count_B=0;
- Show_Counts();
- //INT0中斷函數
- void EX_INT0() interrupt 0
- Count_A++;
- //INT1中斷函數
- void EX_INT1() interrupt 2
- Count_B++;
全部資料51hei下載地址:
INT0及INT1中斷計數.rar
(37.94 KB, 下載次數: 29)
2017-12-5 09:48 上傳
