查看: 3634|回復: 0
單片機8*8矩陣燈程序
ID:256768 發表于 2017-12-3 14:01 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
剛才上傳的是lcd1602,這個才是矩陣等8x8.
是一個矩陣等,采用的輸入時直觀矩陣。就是8x8矩陣。矩陣中有非零與零兩種狀態。
  1. #include<reg52.h>
  2. #include<intrins.h>
  3. typedef unsigned char uchar;
  4. typedef unsigned int  uint;
  5. uchar bdata Lie_Wei;
  6. sbit p00 = Lie_Wei^0;
  7. sbit p01 = Lie_Wei^1;
  8. sbit p02 = Lie_Wei^2;
  9. sbit p03 = Lie_Wei^3;
  10. sbit p04 = Lie_Wei^4;
  11. sbit p05 = Lie_Wei^5;
  12. sbit p06 = Lie_Wei^6;
  13. sbit p07 = Lie_Wei^7;
  14. uchar Ju_Zhen[8][18]= {        "1 0 0 1 1 0 0 1 L",
  15.                                                 "0 0 0 1 1 0 0 0 L",
  16.                         "0 0 0 0 0 0 0 0 L",
  17.                         "1 0 0 0 0 0 0 1 L",
  18.                                              "1 0 0 0 0 0 0 1 L",
  19.                                             "1 1 0 0 0 0 1 1 L",
  20.                                             "1 1 1 0 0 1 1 1 L",
  21.                                             "1 1 1 1 1 1 1 1 L"
  22.                                             };
  23.                       /*
  24.                         "1 1 1 1 1 1 1 1 L",
  25.                         "1 1 1 1 1 1 1 1 L",
  26.                         "1 1 1 1 1 1 1 1 L",
  27.                                              "1 1 1 1 1 1 1 1 L",
  28.                                             "1 1 1 1 1 1 1 1 L",
  29.                                             "1 1 1 1 1 1 1 1 L",
  30.                                             "1 1 1 1 1 1 1 1 L",
  31.                                             "1 1 1 1 1 1 1 1 L",
  32.                                         */
  33. sbit p34 = P3^4;
  34. sbit p35 = P3^5;
  35. sbit p36 = P3^6;
  36. void Yan_Shi(char i)
  37. {
  38.         char x=0;
  39.         for(;i>0;i--)
  40.         for(x=10;x>0;x--);
  41. }
  42. void Hang_Led(uchar Hang)
  43. {
  44.         char i;
  45.         p35 = 0;
  46.         for(i = 10*i; i<=8 ;i++)
  47.         {
  48.                 if(i == Hang)
  49.                 p34 = 1;
  50.                 else p34 = 0;
  51.                 p36 = 1;
  52.                 _nop_();_nop_();_nop_();
  53.                 p36 = 0;
  54.         }
  55. }
  56. void Lie_LED(uint GaoSiWei,uint DiSiWei)
  57. {
  58.         p07 = (bit)(GaoSiWei%10000/1000);
  59.         p06 = (bit)(GaoSiWei%1000/100);
  60.         p05 = (bit)(GaoSiWei%100/10);
  61.         p04 = (bit)(GaoSiWei%10);
  62.         p03 = (bit)(DiSiWei%10000/1000);
  63.         p02 = (bit)(DiSiWei%1000/100);
  64.         p01 = (bit)(DiSiWei%100/10);
  65.         p00 = (bit)(DiSiWei%10);
  66. }
  67.
  68. void  LED_8x8(char Hang,uint GaoSiWei,uint DiSiWei,uchar Shi_HZ)
  69. {
  70.         Hang_Led(Hang);
  71.         Lie_LED(GaoSiWei,DiSiWei);
  72.         P0=0xff;
  73.         p35=1;
  74.         _nop_();_nop_();_nop_();
  75.         p35=0;
  76.         P0 = Lie_Wei;
  77.         Yan_Shi(Shi_HZ);
  78. }
  79. void Ju_ZiFu(uchar Zhi_Zhen[8][18])
  80. {
  81.         uchar i;
  82.         for(i=0;i<8;i++)
  83.         {
  84.                 if(Zhi_Zhen[i][16]=='L')
  85.                 {
  86.                         Hang_Led(i+1);
  87.                         p07 = (bit)(Zhi_Zhen[i][0]-'0');
  88.                         p06 = (bit)(Zhi_Zhen[i][2]-'0');
  89.                         p05 = (bit)(Zhi_Zhen[i][4]-'0');
  90.                         p04 = (bit)(Zhi_Zhen[i][6]-'0');
  91.                         p03 = (bit)(Zhi_Zhen[i][8]-'0');
  92.                         p02 = (bit)(Zhi_Zhen[i][10]-'0');
  93.                         p01 = (bit)(Zhi_Zhen[i][12]-'0');
  94.                         p00 = (bit)(Zhi_Zhen[i][14]-'0');
  95.                         P0=0xff;
  96.                         p35=1;
  97.                         _nop_();_nop_();_nop_();
  98.                         p35=0;
  99.                         P0 = Lie_Wei;
  100.                         Yan_Shi(1);
  101.                 }
  102.         }
  103. }
  104. void main()
  105. {
  106.         P0 = 0xff;
  107.         p35 = 0;
  108.         p36 = 0;
  109.         Yan_Shi(10);
  110.          while(1)
  111.         {          uchar CiShu;
  112.             for(CiShu=180;CiShu>0;CiShu--)
  113.                 {
  114.                         Ju_ZiFu(Ju_Zhen);
  115. ……………………
  116. …………限于本文篇幅 余下代碼請從51黑下載附件…………
矩陣燈.rar (26.7 KB, 下載次數: 14)
