查看: 11613|回復: 7
LCD12864動態顯示漢字proteus仿真加源程序
ID:256626 發表于 2017-12-2 21:27 | 顯示全部樓層 |閱讀模式
LCD動態顯示漢字
單片機LCD12864驅動源程序如下:
  1. #include <reg51.h>
  2. #include <intrins.h>
  3. #define Dataport P0 //LCD數據線
  4. sbit RS=P2^2; // 數據\指令 選擇
  5. sbit RW=P2^1; // 讀\寫 選擇
  6. sbit EN=P2^0; // 讀\寫使能
  7. sbit cs1=P2^4; // 片選1
  8. sbit cs2=P2^3; // 片選2
  9.
  10. #define uint unsigned int
  11. #define uchar unsigned uchar
  12. /********************************/
  13. /*  定義中文字庫                */
  14. /********************************/
  15. unsigned char code Hzk[]={
  16. /*--  文字:  中  --*/
  17. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  18. 0x00,0x00,0xFC,0x08,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x08,0xFC,0x08,0x00,0x00,
  19. 0x00,0x00,0x07,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x02,0x02,0x07,0x00,0x00,0x00,
  20. /*--  文字:  國  --*/
  21. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  22. 0x00,0xFE,0x02,0x0A,0x8A,0x8A,0x8A,0xFA,0x8A,0x8A,0x8A,0x0A,0x02,0xFE,0x00,0x00,
  23. 0x00,0xFF,0x40,0x48,0x48,0x48,0x48,0x4F,0x48,0x49,0x4E,0x48,0x40,0xFF,0x00,0x00,
  24. /*--  文字:  人  --*/
  25. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  26. 0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x3F,0xC2,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  27. 0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x01,0x06,0x0C,0x18,0x30,0x60,0x20,0x00,
  28. /*--  文字:  民  --*/
  29. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  30. 0x00,0x00,0xFE,0x92,0x92,0x92,0x92,0xF2,0x92,0x92,0x92,0x9E,0x80,0x80,0x00,0x00,
  31. 0x00,0x00,0xFF,0x40,0x20,0x10,0x00,0x00,0x03,0x0C,0x10,0x20,0x40,0xF0,0x00,0x00,
  32. /*--  文字:  解  --*/
  33. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  34. 0x08,0xF4,0x57,0x54,0xFC,0x54,0xF0,0x42,0xA2,0x1E,0x02,0xA2,0x62,0x3E,0x00,0x00,
  35. 0x80,0x7F,0x02,0x02,0x5F,0x82,0x7F,0x0A,0x09,0x09,0x09,0xFF,0x09,0x09,0x09,0x00,
  36. /*--  文字:  放  --*/
  37. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  38. 0x08,0x08,0xF8,0x49,0x4E,0xC8,0x88,0x40,0x38,0xCF,0x0A,0x08,0x88,0x78,0x08,0x00,
  39. 0x40,0x30,0x0F,0x40,0x80,0x7F,0x00,0x40,0x20,0x10,0x0B,0x0E,0x31,0x60,0x20,0x00,
  40. /*--  文字:  軍  --*/
  41. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  42. 0x00,0x18,0x26,0x22,0xA2,0x72,0x2E,0xAA,0x22,0x22,0x22,0x32,0x22,0x0A,0x06,0x00,
  43. 0x00,0x10,0x10,0x12,0x13,0x12,0x12,0xFF,0x12,0x12,0x12,0x13,0x12,0x18,0x10,0x00,
  44. /*--  文字:  第  --*/
  45. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  46. 0x10,0x08,0x04,0xD3,0x56,0x5A,0x52,0x5A,0xF4,0x53,0x56,0x5A,0x72,0x02,0x02,0x00,
  47. 0x00,0x20,0x20,0x23,0x12,0x12,0x0A,0x06,0xFF,0x02,0x02,0x12,0x22,0x1E,0x00,0x00,
  48. /*--  文字:  三  --*/
  49. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  50. 0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x04,0x00,0x00,
  51. 0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
  52. /*--  文字:  三  --*/
  53. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  54. 0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x04,0x00,0x00,
  55. 0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
  56. /*--  文字:  零  --*/
  57. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  58. 0x00,0x0C,0x04,0x55,0x55,0x55,0x85,0x7F,0x85,0x55,0x55,0x55,0x05,0x0C,0x04,0x00,
  59. 0x04,0x04,0x04,0x0A,0x0A,0x09,0x2A,0xCC,0x28,0x19,0x09,0x02,0x06,0x02,0x02,0x00,
  60. /*--  文字:  三  --*/
  61. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  62. 0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x84,0x04,0x00,0x00,
  63. 0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
  64. /*--  文字:  工  --*/
  65. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  66. 0x00,0x00,0x02,0x02,0x02,0x02,0x02,0xFE,0x02,0x02,0x02,0x02,0x02,0x02,0x00,0x00,
  67. 0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
  68. /*--  文字:  廠  --*/
  69. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  70. 0x00,0x00,0xFE,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x00,
  71. 0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  72. /*--  文字:  導  --*/
  73. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  74. 0x00,0x00,0x00,0x3E,0x4A,0x4A,0x4A,0x4A,0x4A,0x4A,0xCA,0x4E,0x40,0x70,0x00,0x00,
  75. 0x02,0x02,0x02,0x02,0x06,0x3A,0x12,0x02,0x42,0x82,0x7F,0x02,0x02,0x02,0x02,0x00,
  76. /*--  文字:  彈  --*/
  77. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  78. 0x02,0xF2,0x12,0x12,0x1E,0x00,0xF9,0x2A,0x2C,0xF8,0x28,0x2C,0x2B,0xFA,0x00,0x00,
  79. 0x01,0x43,0x81,0x41,0x3F,0x08,0x0B,0x09,0x09,0xFF,0x09,0x09,0x09,0x0B,0x08,0x00,
  80. /*--  文字:  中  --*/
  81. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  82. 0x00,0x00,0xFC,0x08,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x08,0xFC,0x08,0x00,0x00,
  83. 0x00,0x00,0x07,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x02,0x02,0x07,0x00,0x00,0x00,
  84. /*--  文字:  心  --*/
  85. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  86. 0x00,0x80,0x00,0x00,0xF0,0x00,0x01,0x02,0x1C,0x08,0x00,0x40,0x80,0x00,0x00,0x00,
  87. 0x04,0x03,0x00,0x00,0x3F,0x40,0x40,0x40,0x40,0x40,0x40,0x78,0x00,0x07,0x02,0x00,
  88. /*--  文字:  胡  --*/
  89. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  90. 0x08,0x88,0x88,0x88,0xFF,0x88,0x88,0x08,0x00,0xFE,0x12,0x12,0x12,0xFE,0x00,0x00,
  91. 0x00,0x3F,0x10,0x10,0x10,0x10,0x7F,0x80,0x40,0x3F,0x01,0x41,0x81,0x7F,0x00,0x00,
  92. /*--  文字:  國  --*/
  93. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  94. 0x00,0xFE,0x02,0x0A,0x8A,0x8A,0x8A,0xFA,0x8A,0x8A,0x8A,0x0A,0x02,0xFE,0x00,0x00,
  95. 0x00,0xFF,0x40,0x48,0x48,0x48,0x48,0x4F,0x48,0x49,0x4E,0x48,0x40,0xFF,0x00,0x00,
  96. /*--  文字:  平  --*/
  97. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  98. 0x00,0x01,0x05,0x09,0x71,0x21,0x01,0xFF,0x01,0x41,0x21,0x1D,0x09,0x01,0x00,0x00,
  99. 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0xFF,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00,
  100. /*--  文字:     --*/
  101. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  102. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  103. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  104. /*--  文字:     --*/
  105. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  106. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  107. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  108. /*--  文字:     --*/
  109. /*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
  110. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  111. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  112. };
  113. /****************************************/
  114. /* 定義ASCII字庫8列*16行                */
  115. /****************************************/
  116. unsigned char code Ezk[]={
  117. /*--  文字:  Q  --*/
  118. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  119. 0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00,
  120. /*--  文字:  Q  --*/
  121. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  122. 0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00,
  123. /*--  文字:  1  --*/
  124. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  125. 0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
  126. /*--  文字:  3  --*/
  127. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  128. 0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,
  129. /*--  文字:  0  --*/
  130. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  131. 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,
  132. /*--  文字:  8  --*/
  133. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  134. 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,
  135. /*--  文字:  1  --*/
  136. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  137. 0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
  138. /*--  文字:  3  --*/
  139. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  140. 0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,
  141. /*--  文字:  0  --*/
  142. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  143. 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,
  144. /*--  文字:  4  --*/
  145. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  146. 0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,
  147. /*--  文字:     --*/
  148. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  149. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  150. /*--  文字:     --*/
  151. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  152. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  153. /*--  文字:     --*/
  154. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  155. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  156. /*--  文字:     --*/
  157. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  158. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  159. /*--  文字:     --*/
  160. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  161. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  162. /*--  文字:     --*/
  163. /*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
  164. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  165. };
  166. void CheckState()                //狀態檢查,LCD是否忙?
  167. {
  168.    unsigned char dat;
  169.    RS=0;
  170.    RW=1;
  171.    do{
  172.       Dataport=0x00;
  173.       EN=1;
  174.           dat=Dataport;
  175.       EN=0;
  176.       dat=0x80 & dat; //僅當第7位為0時才可操作(判別busy信號)
  177.       }while(!(dat==0x00));
  178. }
  179. SendCommandToLCD(unsigned char command)           //寫命令到LCD中
  180. {
  181.    CheckState();
  182.    RS=0;         //向LCD發送命令
  183.    RW=0;
  184.    Dataport=command;         //command :命令
  185.    EN=1;
  186.    EN=0;
  187. }
  188. void SetLine(unsigned char page)        //設置頁 0xb8是頁的首地址
  189. {
  190.   page=0xb8|page; //1011 1xxx                 0<=page<=7 設定頁地址--X 0-7,8行為一頁64/8=8,共8頁
  191.   SendCommandToLCD(page);
  192. }
  193. void SetStartLine(unsigned char startline)            //設定顯示開始行,0xc0是行的首地址
  194. {
  195.   startline=0xc0|startline; //1100 0000
  196.   SendCommandToLCD(startline); //設置從哪行開始:0--63,一般從0 行開始顯示
  197. }
  198. void SetColumn(unsigned char column)        //設定列地址--Y 0-63 ,0x40是列的首地址
  199. {
  200.   column=column &0x3f; //column最大值為64,越出 0=<column<=63
  201.   column= 0x40|column; //01xx xxxx
  202.   SendCommandToLCD(column);
  203. }
  204. void SetOnOff(unsigned char onoff)           //開關顯示,0x3f是開顯示,0x3e是關顯示
  205. {
  206.         onoff=0x3e|onoff; //0011 111x,onoff只能為0或者1
  207.         SendCommandToLCD(onoff);
  208. }
  209. void WriteByte(unsigned char dat)        //寫顯示數據
  210. {
  211.    CheckState();
  212.    RS=1;
  213.    RW=0;
  214.    Dataport=dat;//dat:顯示數據
  215.    EN=1;
  216.    EN=0;
  217.   }
  218. void SelectScreen(unsigned char screen)          //選擇屏幕screen: 0-全屏,1-左屏,2-右屏
  219. {
  220.    switch(screen)
  221.    { case 0: cs1=0;//全屏
  222.              _nop_(); _nop_(); _nop_();
  223.              cs2=0;
  224.              _nop_(); _nop_(); _nop_();
  225.              break;
  226.      case 1: cs1=0;//左屏
  227.              _nop_(); _nop_(); _nop_();
  228.              cs2=1;
  229.              _nop_(); _nop_(); _nop_();
  230.              break;
  231.      case 2: cs1=1;//右屏
  232.              _nop_(); _nop_(); _nop_();
  233.              cs2=0;
  234.              _nop_(); _nop_(); _nop_();
  235.              break;
  236.    }
  237. }
  238. void ClearScreen(unsigned char screen)          //清屏screen: 0-全屏,1-左屏,2-右
  239. {
  240.      unsigned char i,j;
  241.      SelectScreen(screen);
  242.
  243.          for(i=0;i<8;i++)         //控制頁數0-7,共8頁
  244.          {
  245.                 SetLine(i);
  246.                         SetColumn(0);
  247.               for(j=0;j<64;j++)           //控制列數0-63,共64列
  248.                                   {
  249.                   WriteByte(0x00); //寫點內容,列地址自動加1
  250.                 }
  251.      }
  252.
  253. }
  254. void        delay(uint nms)                //延時程序
  255. {
  256.         uint i;
  257.         for(; nms > 0; nms--)
  258.                 for(i = 0; i < 500; i++);
  259. }
  260. void        lcd_rol()                                        //向上滾屏
  261. {
  262.         uint i;
  263.         for(i = 0; i < 64; i++)
  264.         {
  265.                 cs1=0; // 片選1
  266.                 SendCommandToLCD(0xc0+i);
  267.                 cs1=1;
  268.
  269.                 cs2=0;// 片選2
  270.                 SendCommandToLCD(0xc0+62-i);
  271.                 cs2=0; // 片選2
  272.
  273.                 delay(6);
  274.         }
  275. }
  276. void InitLCD(  )             //初始化LCD
  277. {
  278.         CheckState();
  279.         SelectScreen(0);
  280.         SetOnOff(0); //關顯示
  281.         SelectScreen(0);
  282.         SetOnOff(1); //開顯示
  283.         SelectScreen(0);
  284.         ClearScreen(0);//清屏
  285.         SetStartLine(0); //開始行:0
  286. }
  287. //顯示全角漢字
  288. void Display(unsigned char ss,unsigned char page,unsigned char column,unsigned char number)
  289. {
  290.         int i;                          //選屏參數,pagr選頁參數,column選列參數,number選第幾漢字輸出
  291.
  292.         SelectScreen(ss);
  293.         column=column&0x3f;
  294.         SetLine(page);        //寫上半頁
  295.         SetColumn(column); //控制列
  296.         for(i=0;i<16;i++)  //控制16列的數據輸出
  297.         {
  298.         WriteByte(Hzk[i+32*number]); //i+32*number漢字的前16個數據輸出
  299.
  300.         }
  301.         SetLine(page+1);                 //寫下半頁
  302.         SetColumn(column);           //控制列
  303.     for(i=0;i<16;i++)          //控制16列的數據輸出
  304.         {
  305.         WriteByte(Hzk[i+32*number+16]);        //i+32*number+16漢字的后16個數據輸出
  306.         }
  307. }
  308. //顯示半角漢字和數字和字母
  309. void Displayen(unsigned char ss,unsigned char page,unsigned char column,unsigned char number)
  310. {
  311.         int i;           //選屏參數,pagr選頁參數,column選列參數,number選第幾漢字輸出
  312.
  313.         SelectScreen(ss);
  314.         column=column&0x3f;
  315. ……………………
  316. …………限于本文篇幅 余下代碼請從51黑下載附件…………
LCD動態顯示漢字.rar (92.13 KB, 下載次數: 259)
ID:52915 發表于 2018-12-4 11:12 | 顯示全部樓層
這個是不帶字庫的液晶屏吧?需要自己取模
ID:467365 發表于 2019-1-13 13:42 來自觸屏版 | 顯示全部樓層
怎么下載
ID:467365 發表于 2019-1-13 15:25 來自觸屏版 | 顯示全部樓層
怎么改漢字
ID:363867 發表于 2019-5-27 15:59 | 顯示全部樓層
可以嗎
ID:243394 發表于 2019-7-12 18:51 | 顯示全部樓層
先下載學習學習
ID:546335 發表于 2019-7-13 09:59 | 顯示全部樓層
厲害,好資料。
ID:77589 發表于 2021-12-9 13:51 | 顯示全部樓層
來看看,測我的取模軟件
