查看: 1909|回復: 1
51單片機動態顯示屏
ID:256620 發表于 2017-12-2 21:16 | 顯示全部樓層 |閱讀模式
#include"reg52.h"
#include"intrins.h"
typedef unsigned char u8;
typedef unsigned int u16;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
u8 code smgduan[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,
                     0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(u16 i)
     while(i--);
void DigDisplay()
   u8 i;
   for(i=0;i<8;i++)
     switch(i)
      case(0):
   LSA=0;LSB=0;LSC=0;break;
   case(1):
   LSA=1;LSB=0;LSC=0;break;
   case(2):
   LSA=0;LSB=1;LSC=0;break;
   case(3):
   LSA=1;LSB=1;LSC=0;break;
   case(4):
   LSA=0;LSB=0;LSC=1;break;
   case(5):
   LSA=1;LSB=0;LSC=1;break;
   case(6):
   LSA=0;LSB=1;LSC=1;break;
   case(7):
   LSA=1;LSB=1;LSC=1;break;
  P0=smgduan[5];
  delay(40000);
  P0=0x00;
  P0=smgduan[2];
  delay(40000);
  P0=0x00;
  P0=smgduan[0];
  delay(40000);
  P0=0x00;
    DigDisplay();
哇哇哇666666
