查看: 12144|回復(fù): 10
PIC18F45K80 CAN通信實例,可通過模擬調(diào)試
ID:90762 發(fā)表于 2017-12-2 10:03 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
PIC18F 45K80  CAN 通信實例,可通過模擬調(diào)試,注意選編譯器,C18是不能通過。
  1. #pragma config XINST = OFF                                                  // CONFIG1L
  2. #pragma config FOSC = INTIO2, FCMEN = OFF, IESO = OFF ,PLLCFG = OFF         // CONFIG1H
  3. #pragma config BOREN = OFF, BORV = 0                                                        // CONFIG2L
  4. #pragma config WDTEN = OFF        // CONFIG2H
  5. /** I N C L U D E S **************************************************/
  6. #include "main.h"
  7. unsigned char CAN_RecFLAG=0;
  8. unsigned char Flag50ms = 0;
  9. // AD采樣的數(shù)據(jù)變量
  10. unsigned int VoltageEdlc[5];
  11. unsigned int VoltageBat;
  12. unsigned int Current1;
  13. unsigned int Current2;
  14. unsigned int Temperature1;
  15. unsigned int Temperature2;
  16. void InterruptHandler(void);
  17. #pragma code high_vector=0x08
  18. void high_interrupt (void)
  19. {
  20.         _asm GOTO InterruptHandler _endasm
  21. }
  22. #pragma code
  23. #pragma code low_vector=0x18
  24. void low_interrupt (void)
  25. {
  26.         _asm GOTO InterruptHandler _endasm
  27. }
  28. #pragma code
  29. #pragma interruptlow InterruptHandler
  30. #pragma interrupt        InterruptHandler
  31. void InterruptHandler(void)
  32. {
  33.              static unsigned char Tick = 0;
  34.           static unsigned char ChannelNo = 0;
  35.       // 定時器0
  36.           if(INTCONbits.TMR0IF&&INTCONbits.TMR0IE)     // timer0 = 10ms
  37.           {
  38.                  INTCONbits.TMR0IF = 0;
  39.                  TMR0H = 0x63;
  40.          TMR0L = 0xBF;
  41.                  Tick++;
  42.                  if(Tick ==200)
  43.                  {
  44.                         Flag50ms = 1;     // 5s發(fā)送CAN消息到ECU
  45.                         Tick = 0;
  46.                         LATCbits.LATC5 = ~LATCbits.LATC5;
  47.                  }
  48.           }
  49.       // CAN接收數(shù)據(jù)
  50.       if(PIR5bits.RXB0IF==1)
  51.           {
  52.                  CAN_RecFLAG=1;
  53.                  PIR5bits.RXB0IF=0;                        // 清接收中斷標志
  54.                  RXB0CONbits.RXFUL=0;                // 清除標志,接收新報文
  55.           }
  56. }
  57. #pragma code
  58. void main(void)
  59. {
  60.         unsigned int EDLC_temp[4];
  61.         INTCON=0x00;
  62.         InitInterOSC();
  63.         InitPORT();
  64.         InitCan();
  65.         Timer0_Init();
  66. //        INTCON=0xc0;                //使能中斷 1100 0000
  67.         INTCONbits.GIE=1;
  68.     INTCONbits.PEIE=1;
  69.   //  INTCONbits.GIEL=1;
  70.   //  TXB0CONbits.TXREQ = 0;
  71.
  72.     while(1)
  73.         {
  74.                 if(CAN_RecFLAG==1)
  75.                 {
  76.                         CAN_RecFLAG = 0;
  77.                         TXB0D0=1;                                         /* 寫發(fā)送緩沖器數(shù)據(jù)區(qū)數(shù)據(jù)初值 */
  78.                         TXB0D1=2;
  79.                         TXB0D2=3;
  80.                         TXB0D3=4;
  81.                         TXB0D4=5;
  82.                     TXB0D5=6;
  83.                     TXB0D6=7;
  84. ……………………
  85. …………限于本文篇幅 余下代碼請從51黑下載附件…………
PIC18F45K80-CAN.zip (87.63 KB, 下載次數(shù): 148)
參與人數(shù) 1黑幣 +50 收起 理由
無效樓層,該帖已經(jīng)被刪除
ID:202754 發(fā)表于 2018-5-12 15:27 | 只看該作者
呵呵,沒有黑幣沒法下載
ID:202754 發(fā)表于 2018-10-15 16:22 | 只看該作者
下載去測試一下
ID:68585 發(fā)表于 2018-10-25 09:36 | 只看該作者
好久沒有回來,這個太好了,謝謝。
ID:108662 發(fā)表于 2018-11-4 23:19 | 只看該作者
多謝分享
ID:222858 發(fā)表于 2019-4-22 15:37 | 只看該作者
這個現(xiàn)在充電機上用很多CAN通訊,很有學(xué)習(xí)價值,新能源汽車現(xiàn)在鋰電的都需要CAN通訊。
ID:48413 發(fā)表于 2019-8-29 20:30 | 只看該作者
謝謝共享學(xué)習(xí)一下
ID:301860 發(fā)表于 2021-6-26 15:43 | 只看該作者
你好,我們準備用PIC18F45K80,請問仿真器型號和例程是......? 在哪里下載資料呢?
ID:957072 發(fā)表于 2021-7-28 14:08 | 只看該作者
這個單片機我還有60片庫存
無效樓層,該帖已經(jīng)被刪除
12#
無效樓層,該帖已經(jīng)被刪除
13#
ID:518629 發(fā)表于 2021-8-17 15:21 | 只看該作者
可以參考學(xué)習(xí)下,感謝分享
ID:961819 發(fā)表于 2021-8-22 23:33 來自觸屏版 | 只看該作者
您會編譯PiC18F50k80,OBD程序
