stc單片機(jī)雙串口中斷收發(fā)源程序
查看數(shù): 10851 | 評(píng)論數(shù): 18 | 收藏 8
    組圖打開中,請(qǐng)稍候......
發(fā)布時(shí)間: 2017-4-7 18:22
雙串口中斷收發(fā)源代碼:
ID:1044540 發(fā)表于 2022-9-12 14:47
#include "UART.h"
#include "Key.h"
#include "Record.h"
uint8_t Rcv_Buf[RCV_LENGTH];
uint8_t Snd_Buf[SND_LENGTH];
volatile uint8_t        recvbyte=0;
uint8_t RcvFlag = 0;
volatile uint16_t         ScanTimeMs;
volatile uint16_t SysOverTime;
uint8_t InitStartEnable;
uint8_t SendAdd;
uint16_t SysCallStatus1=0;
uint16_t SysCallStatus2=0;
uint16_t SysCallStatus1Bak=0;
uint16_t SysCallStatus2Bak=0;
uint16_t alarm = 0;
bit MyAddStart;
bit Over1min;
bit OverTimeFlag;
bit OtherMaster;
bit OtherMasterChecked;
volatile uint16_t DisableSendTimeMs;
volatile uint16_t u16_OverTimeMs;
void UART1_ISR() interrupt 4 using 1
        if(RI)
                RI = 0;
                SysOverTime = 0;
                UartErr = 0;
                Rcv_Buf[recvbyte] = SBUF;                        //接收數(shù)據(jù)
                if(Rcv_Buf[0] == 0x53)
                        recvbyte++;
                if((Rcv_Buf[recvbyte-1]==0x0a) && (Rcv_Buf[recvbyte-2]==0x0d))                 //接收到幀尾
                        RcvFlag = 1;                        //置位接收標(biāo)志
                        recvbyte = 0;                        //接收下標(biāo)清零
void Uart1_Init(void)
//        SCON = 0x50;
//        TMOD &= 0x0f;
//        TH1 = BAUD>>8;
//        TL1 = BAUD;
//        TR1 = 1;
//        AUXR |= 0x40;
//         ES = 1;
//        EA = 1;
//        RS485_RcevEnable();
                        TR1 = 0;
                AUXR &= ~0x01;                //S1 BRT Use Timer1;
                AUXR |=  (1<<6);        //Timer1 set as 1T mode
                TMOD &= ~(1<<6);        //Timer1 set As Timer
                TMOD &= ~0x30;                //Timer1_16bitAutoReload;
                TH1 = (uint8_t)(BAUD >> 8);
                TL1 = (uint8_t)BAUD;
                ET1 = 0;                                                // 禁止Timer1中斷
//                INT_CLKO &= ~0x02;        // Timer1不輸出高速時(shí)鐘
        //        INT_CLKO |=  0x02;        // Timer1輸出高速時(shí)鐘
                TR1  = 1;                        // 運(yùn)行Timer1
        SCON = (SCON & 0x3f) | (1<<6);        // 8位數(shù)據(jù), 1位起始位, 1位停止位, 無(wú)校驗(yàn)
//        PS  = 1;        //高優(yōu)先級(jí)中斷
        ES  = 1;        //允許中斷
        REN = 1;        //允許接收
//        if(MasterAdd !=0)
//                        MyAddStart = 0;
        OtherMaster = 1;
        OtherMasterChecked = 0;
        DisableSendTimeMs = 0;
        SysOverTime = 0;
        Over1min = 0;
        RS485_RcevEnable();
void UART1_Send_Char(unsigned char c)
        RS485_SendEnable();
        _nop_();
        _nop_();
        _nop_();
        SBUF = c;
        while(!TI);
        TI = 0;
        _nop_();
        _nop_();
        _nop_();
        RS485_RcevEnable();
void UART1_Send_String(unsigned char *s)
        while(*s)
                UART1_Send_Char(*s++);
void UART1_Send_Int(unsigned int c)
        UART1_Send_Char(c/10000+0x30);
        UART1_Send_Char(c%10000/1000+0x30);
        UART1_Send_Char(c%1000/100+0x30);
        UART1_Send_Char(c%100/10+0x30);
        UART1_Send_Char(c%10+0x30);
        UART1_Send_Char(0x0d);
        UART1_Send_Char(0x0a);
void UART1_Send_Buf(unsigned char *s,unsigned char len)
        unsigned char i;
        for(i=0;i<len;i++)
                UART1_Send_Char(s[i]);
void UART_Timer_Ms(void)
        SysOverTime++;
        if(SysOverTime > 10000)
                UartErr = 1;
                MyAddStart = InitStartEnable;
                ScanTimeMs = 0;
        if(MyAddStart)
                ScanTimeMs++;
請(qǐng)教一下,這個(gè)程序中初始波特率是多少呢
ID:596723 發(fā)表于 2019-8-7 11:39
標(biāo)記,下載測(cè)試下
ID:299740 發(fā)表于 2019-7-1 08:27
非常感謝,正在被這個(gè)串口2收發(fā)問(wèn)題困擾,趕緊下下來(lái)測(cè)試。
ID:535790 發(fā)表于 2019-5-26 16:24
謝謝,學(xué)習(xí)了
ID:43121 發(fā)表于 2019-5-24 09:38
謝謝分享,收獲很大
ID:434016 發(fā)表于 2018-11-27 10:44
謝謝提供,測(cè)試看看...
ID:120672 發(fā)表于 2018-9-29 18:19
謝謝分享,正在找相關(guān)資料呢!
ID:66287 發(fā)表于 2018-8-1 10:40
學(xué)習(xí)了,謝謝分享!
ID:381135 發(fā)表于 2018-7-31 09:52
謝謝分享
ID:65956 發(fā)表于 2018-7-12 08:51
謝謝分享,幫助很大,謝謝
ID:189673 發(fā)表于 2018-5-29 19:50
無(wú)常 發(fā)表于 2018-5-8 15:24
謝謝分享,初學(xué)很懵逼
要測(cè)試下這個(gè)可不可以用
ID:283906 發(fā)表于 2018-5-8 15:24
謝謝分享,初學(xué)很懵逼
ID:323951 發(fā)表于 2018-5-7 16:29
謝謝謝謝!非常感謝!!
ID:225369 發(fā)表于 2017-12-28 15:32
謝謝謝謝!非常感謝!!
ID:225369 發(fā)表于 2017-12-28 15:31
我正要找 這個(gè),可不可以用?
謝謝!謝謝!非常感謝!!
ID:94867 發(fā)表于 2017-12-27 11:03
我要測(cè)試下這個(gè)可不可以用
ID:94867 發(fā)表于 2017-12-27 11:00
標(biāo)記謝謝分享
