發(fā)布時間: 2023-4-22 14:51
正文摘要:有沒有大佬知道負(fù)載平衡和負(fù)載均衡的區(qū)別,負(fù)載平衡是個什么原理啊,我對我這個設(shè)計的工作原理不太懂,有大佬接觸過這個設(shè)計嗎!設(shè)計是能根據(jù)當(dāng)前的負(fù)載情況選擇0%~80%,最小分辨率為10%的負(fù)載狀態(tài);一方負(fù)載高于另 ... |
#include <AT89X52.h> unsigned char code SEGtable[]= { 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0x00 }; sbit sw7 = P0 ^ 7; sbit sw6 = P0 ^ 6; sbit sw5 = P0 ^ 5; sbit sw4 = P0 ^ 4; sbit sw3 = P0 ^ 3; sbit sw2 = P0 ^ 2; sbit sw1 = P0 ^ 1; sbit sw0 = P0 ^ 0; sbit FMQ = P1 ^ 7; bit alarmflg = 0; unsigned RxByte = 0x00; unsigned char counter = 0; unsigned char Scounter,Lcounter; //·Ö±ð´æ·Å×Ô¼ºµÄˮλ״̬ºÍÔ¶·½µÄˮλ״̬ unsigned char FMcounter = 0x02; //±¨¾¯×´Ì¬²ÎÊý void DelayFM(unsigned int x) { unsigned char t; while(x--) { for(t=0;t<120;t++); } } //·äÃùÆ÷Çý¶¯º¯Êý£¬²ÎÊýΪ·¢ÉùÉùµ÷ void FM(unsigned char x) { unsigned char i; for(i=0;i<100;i++) { FMQ = ~FMQ; DelayFM(x); } FMQ = 0; } void Delayms(unsigned int MS) { unsigned int i,j; for( i=0;i<MS;i++) for(j=0;j<1141;j++); } void InitUART(void) { TMOD = 0x20; //9600bps SCON = 0x50; TH1 = 0xFD; TL1 = TH1; PCON = 0x00; EA = 1; ES = 1; TR1 = 1; } void Send(unsigned char x) { SBUF = x; while(TI == 0); TI = 0; } void Serial(void) interrupt 4 using 1 { unsigned char RxByte; if(RI == 1) { RxByte = SBUF; RI = 0; P2 = RxByte; switch(RxByte) { case 0x00: Lcounter = 0;break; case 0xf9: Lcounter = 1;break; case 0xa4: Lcounter = 2;break; case 0xb0: Lcounter = 3;break; case 0x99: Lcounter = 4;break; case 0x92: Lcounter = 5;break; case 0x82: Lcounter = 6;break; case 0xF8: Lcounter = 7;break; case 0x80: Lcounter = 8;break; default:{}; } if(Scounter > Lcounter) { if((Scounter - Lcounter) > 2) { FMcounter = Scounter - Lcounter; alarmflg = 1; } else { alarmflg = 0; } } else { alarmflg = 0; } } } int main(void) { InitUART(); while(1) { Delayms(100); P0 = 0xFF; counter = 0; counter = counter + (unsigned char)sw7; counter = counter + (unsigned char)sw6; counter = counter + (unsigned char)sw5; counter = counter + (unsigned char)sw4; counter = counter + (unsigned char)sw3; counter = counter + (unsigned char)sw2; counter = counter + (unsigned char)sw1; counter = counter + (unsigned char)sw0; Scounter = counter; Send(SEGtable[counter]); if(alarmflg == 1) { FM(FMcounter); } } } |
