基于51單片機(jī)使用DHT11傳感器在12864顯示溫度代碼
查看數(shù): 3192 | 評(píng)論數(shù): 0 | 收藏 1
    組圖打開中,請(qǐng)稍候......
發(fā)布時(shí)間: 2019-7-27 10:46
#include "reg52.h" typedef unsigned char uchar; typedef unsigned int uint; typedef unsigned long ulong; //顯示 uchar code wen[]; uchar code du[]; uchar code mao_hao[]; uchar code num0[]; uch ...
