| 謝謝分享 |
| 1602顯示漢字比較勉強啊 |
| 謝謝分享!實力超強! |
w358435135 發(fā)表于 2018-12-25 18:27 下面是重新修整過的代碼,此例的目地是讓他家了解一下LCD1602動態(tài)顯示 #include<reg51.h> #define uchar unsigned char #define uint unsigned int sbit RS = P2^5; sbit RW = P2^6; sbit EN = P2^7; uchar Data2[15]="jinsheng7533967"; //---------自定義的字符數(shù)據(jù)------ uchar code CGCODE[]={ 0x08,0x0f,0x12,0x0f,0x0a,0x1f,0x02,0x02,//顯示年0x00 0x0F,0x09,0x0F,0x09,0x0F,0x09,0x13,0x00,//顯示月0x01 0x0F,0x09,0x09,0x0f,0x09,0x09,0x0f,0x00 //顯示日0x02 }; //-----------函數(shù)的聲明------------------ void DelayMS(uint dly); void User_def(void); //----------液晶模塊的聲明--------------- bit BUSY(void); void Write_cmd(uchar cmd); void Write_dat(uchar dat); void LCD_Init(void); void main(void) { uchar i, k; LCD_Init(); User_def(); //將自定義的字符寫入CGRAM while(1) { Write_cmd(0x83); Write_dat(0x32); // 2 Write_dat(0x30); // 0 Write_dat(0x31); // 1 Write_dat(0x38); // 8 Write_dat(0x00); //顯示 年 Write_dat(0x31); // 1 Write_dat(0x32); // 2 Write_dat(0x01); //顯示 月 Write_dat(0x31); Write_dat(0x31); Write_dat(0x02); Write_cmd(0xc3); Write_dat(0x02); Write_dat(0x31); Write_cmd(0xc1); for(i=0;i<15;i++) Write_dat(Data2); Write_cmd(0x8b); Write_dat(0x30+k/10); Write_dat(0x31+k%10); DelayMS(200); DelayMS(200); DelayMS(200); if(k>30)k=0; else k++; } } void DelayMS(uint dly) { uint x,y; for(x=dly;x>0;x--) for(y=124;y>0;y--); } bit BUSY(void) { bit Bit; RS = 0; RW = 1; EN = 1; DelayMS(1); Bit = (bit)(P0 & 0x80); //最高位為忙信號位 EN = 0; return Bit; } void Write_cmd(uchar cmd) { while(BUSY()); //測忙 RS = 0; RW = 0; EN = 0; P0 = cmd; EN = 1; DelayMS(1); EN = 0; } void Write_dat(uchar dat) { while(BUSY()); //測忙 RS = 1; RW = 0; EN = 0; P0 = dat; EN = 1; DelayMS(1); EN = 0; } void LCD_Init(void) { Write_cmd(0x38); //功能設(shè)置 DelayMS(1); Write_cmd(0x0c); //顯示開關(guān)控制 DelayMS(1); Write_cmd(0x06); //輸入方式設(shè)置 DelayMS(1); Write_cmd(0x01); //清除LCD的顯示內(nèi)容 DelayMS(1); } void User_def(void) { uchar i; Write_cmd(0x40); //設(shè)置CGRAM地址 for(i=0;i<24;i++) { Write_dat(CGCODE); } } |
| 參與人數(shù) 5 | 黑幣 +119 | 收起 理由 |
| + 4 | |
| + 35 | |
| + 35 | 很給力! |
| + 35 | 贊一個! |
| + 10 | 很給力! |
文件不全啊 user_def()函數(shù)沒啊 |
文件打不開???? |
