萌新求學,c語言邏輯運算
查看數: 2365 | 評論數: 9 | 收藏 0
發布時間: 2018-10-16 23:38
某乎看到的大佬寫的,感覺有趣,想自己動手也寫寫,但是這需求有點不理解! 跪求各方大佬~~~ 跪求各方大佬~~~ 跪求各方大佬~~~
ID:89515 發表于 2018-10-22 10:51
#include<windows.h>
#include<stdio.h>
#include<stdlib.h>
#include<time.h>
#include<conio.h>
#include<dos.h>
void gotoxy(int x, int y)
         COORD coord;    //定義一個坐標結構變量
         HANDLE hscr;    //定義一個句柄
         coord.X = x;    //給坐標賦值
         coord.Y = y;
         hscr = GetStdHandle(STD_OUTPUT_HANDLE); //獲得標準輸出句柄(就是顯示器)
         SetConsoleCursorPosition(hscr, coord);  //設置控制臺光標的到指定坐標
void guess(int n)
        int acount,bcount,i,j,k=0,flag,a[10],b[10];
        do
                flag=0;
                srand((unsigned)time(NULL));//利用系統時鐘設定種子
                for(i=0;i<n;i++)
                        a[i]=rand()%10;
                for(i=0;i<n-1;i++)
                        for(j=i+1;j<n;j++)
                                if(a[i]==a[j])
                                        flag=1;
                                        break;
        }while(flag==1);
        do///////////////////////比較函數/////////////////////////////////
                k++;
                acount=0;
                bcount=0;
                gotoxy(25,k+2);
                printf("guess:");
                for(i=0;i<n;i++)
                        scanf("%d",&b[i]);
                for(i=0;i<n;i++)
                        for(j=0;j<n;j++)
                                if(a[i]==b[i])
                                        acount++;
                                        break;
                                if(a[i]==b[j]&&i!=j)
                                        bcount++;
                                        break;
                gotoxy(35,k+2);
                printf("clue on:%dA%dB\n",acount,bcount);
                if(acount==n)//不同猜測次數贏得游戲后的界面
                        if(k==1)
                                        printf("you are the topmost rung of Fortune's ladder!!\n\n");
                        else if(k<=5)
                                        printf("you are genius!!\n\n");
                        else if(k<=10)
                                        printf("you are cleaver!!\n\n");
                        else
                                        printf("you need try hard!!\n\n");
                        break;
        }while(1);
void main()
        int i,n;
        while(1)
        {//////////////////////////////////開始界面//////////////////////////////////////
                system("cls");//清屏
                gotoxy(30,6);
                printf("1.start game?(y/n)");
                gotoxy(30,8);
                printf("2.Rule");
                gotoxy(30,10);
                printf("please choose:");
                scanf("%d",&i);
                switch(i)
                        case 1:
                                system("cls");
                                printf("please input n:\n");
                                scanf("%d",&n);
                                guess(n);
                                Sleep(2000);
                                break;
                        case 2://游戲規則
                                system("cls");
                                gotoxy(40,6);
                                printf("\n\n\n\t\tThe Rules OF The Game\n");
                                printf("step1:inpur of the number of difits\n");
                                printf("step2:input the number,separated by a apace between two number\n");
                                printf("step3:A represent location and data are correcr\n");
                                printf("      B represent location is correct but data is wrong!\n");
                                Sleep(10000);
                                break;
                        case 3:
                        //        system("exit");
                                return;
                        default:
                                break;
ID:411537 發表于 2018-10-18 09:56
能不能提供詳細一點的數據,這樣看不大明白
ID:411500 發表于 2018-10-18 08:45
這個是c語言書上的例題吧
ID:398162 發表于 2018-10-17 22:38
大佬啊,大佬啊,你在哪里~
ID:155507 發表于 2018-10-17 22:27
C語言猜數字程序代碼問題
隨機產生4個數(0-9).用戶輸入4個數進行核對.位置正確數字正確為A.數字正確位置不正確為B. 4A時提示繼續還是退出.類似文曲星里的游戲.
實現猜數字的游戲。游戲規則如下:
(1)首先程序隨機生成一個0-9999的數。
(2)玩家每次輸入一個4位數,程序告訴玩家兩個信息:
用戶輸入的數,在個、十、百、千4個數字中,有幾個數字是謎底里面有的,且出現在
正確的位置上為A;
用戶輸入的數,在個、十、百、千4個數字中,有幾個數字是謎底里面有的,但未出現
在正確的位置上為B。
ID:398162 發表于 2018-10-17 22:25
就只有這個圖片,,上面游戲規則應該很詳細了啊
ID:411345 發表于 2018-10-17 20:38
能不能詳細一點
ID:410902 發表于 2018-10-17 08:57
那個進制的
