標題: 用4個按鍵按鍵控制電機暫停開始正轉(zhuǎn)反轉(zhuǎn)以及加速減速程序 [打印本頁]
作者: 希瓊心    時間: 2017-11-27 22:03
#include<reg52.h>
uint pp;
char num=2,aa=0,bb=0;
sbit DT=P1^2;                //EN1
sbit ZF=P1^1;                //IN1
sbit pwm=P1^0;                //EN2
sbit s1=P3^4;
sbit s2=P3^5;
sbit s3=P3^6;
sbit s4=P3^7;
sbit dula=P2^6;
sbit wela=P2^7;
unsigned char code table[]=
{0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,
0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
void delay_ms(uchar z)
        uchar i,j;
        for(i=z;i>0;i--)
                for(j=110;j>0;j--);
void keyscan()
        if(s1==1)                //加速
                delay_ms(5);
                if(s1==1)
                        num++;
                        if(num==10)
                                num=9;
                        while(s1);
        if(s2==1)                //減速
                delay_ms(5);
                if(s2==1)
                        num--;
                        if(num==-1)
                                num=0;
                        while(s2);
        if(s3==3)                        //暫停和轉(zhuǎn)
                delay_ms(5);
                if(s3==3)
                        if(aa==0)
                                        DT=1;
                                        num=2;
                                        aa=1;
                                while(s3);
                                        DT=0;                //EN=0
                                        num=2;
                                aa=0;
                                while(s3);
        if(s4==1)
                delay_ms(5);
                if(s4==1)
                        if(bb==0)
                                ZF=~ZF;                //IN1=0 1 0 1 0 1
                                pwm=~pwm;        //IN2=1 0 1
                                bb=1;
                                num=9-num;
                                while(s4);
                                ZF=~ZF;
                                pwm=~pwm;
                                bb=0;
                                num=9-num;
                                while(s4);
void display(a)
   dula=0;
   P0=table[a];
   dula=1;
   dula=0;
   wela=0;
   P0=0xfe;
   wela=1;
   wela=0;
void init()
        TMOD=0x01;
        TR0=1;
        TH0=(65536-92)/256;
        TL0=(65536-92)%256;
        ET0=1;
        EA=1;
        DT=0;
    ZF=0;
        pwm=0;
        init();
                keyscan();
                if((num!=0)&&(num!=9))
                        if(pp<=num)
                                pwm=1;
                                pwm=0;
                        if(pp>=9)
                        pp=0;
                else if(num==0)
                                pwm=0;
                                pwm=1;
        display(num);
void time0() interrupt 1
        TH0=(65536-92)/256;
        TL0=(65536-92)%256;
        pp++;
作者: faridzled    時間: 2017-11-28 07:49
thanks for shring
