松翰SN8F5702紅外發射的程序
實習生1
2017-10-25 17:46
松翰SN8F5702紅外發射的程序
剛學不喜勿碰.
#include "SN8F5702.h"
typedef unsigned char u8;
typedef unsigned int u16;
sbit LED=P1^2;
sbit K1=P1^3;
u8 code array[4]={0xff,0xff,0xff,0xff};
u8 key_shake,j,flag,start,i,a,succ,dat;
//key_shake°′¼üÏû¶¶ j°′¼ü2»Öظ′±äá¿ flag±ê¼Ç°′¼ü°′ÏÂ2Å·¢éä startÆô¶ˉ·¢éä a·¢Ëíμú¼¸¸öêy×é succ·¢éä3é1|±ê¼Ç datêy¾Y
u16 delay,delay_1,delay_2,time;
//delay·¢éäòyμ¼ÂëμÄÑóê± delay_1·¢éä¸ß1μÄÑóê± delay_2·¢éäμí0μÄÑóê± time·¢éäêy¾Y8¸ö×Ö½úμıäá¿
void Timer0Tnit()
TMOD|=0X01; //Ñ¡ÔñÎa¶¨ê±Æ÷0ģ꽣¬1¤×÷·½ê½1£¬½öóÃTR0′ò¿aÆô¶ˉ¡£
TH0=0Xff;
TL0=0X7f; //¸ø¶¨ê±Æ÷¸33õÖ죬¶¨ê±100us
ET0=1; //′ò¿a¶¨ê±Æ÷0ÖD¶ÏÔêDí
EAL=1; //′ò¿a×üÖD¶Ï
TR0=1; //′ò¿a¶¨ê±Æ÷
void key()//°′¼ü
if(!K1)
if(!j)
key_shake++;
if(key_shake>=250)
key_shake=0;
flag=1;
key_shake=0;
void Writeh()//·¢éä¸ß1
delay_1++;
if(delay_1>=5)
LED=0;
if(delay_1>=20)
delay_1=0;
succ=1;
LED=1;
void Writel()//·¢éäμí0
delay_2++;
if(delay_2>=5)
LED=0;
if(delay_2>10)
delay_2=0;
succ=1;
LED=1;
void Emiss()
if((dat&0x01)==0x01)//′ó×îμíλ¿aê¼·¢
Writeh();
Writel();
if(succ==1)
succ=0;
dat>>=1;
time++;
if(time>=8)
time=0;
a++;
dat=array[a];
if(a==5)
a=0;
dat=array[a];
flag=0;
start=0;
void EmissionInit()
switch(start)
case(0):
LED=1;
delay++;
if(delay>=90)
delay=0;
start=1;
LED=0;
break;
case(1):
LED=0;
delay++;
if(delay>=45)
delay=0;
start=2;
break;
case(2):
Emiss();
break;
CLKSEL = 0x06; // Fcpu = 32M/2 = 16M
CLKCMD = 0X69;
CKCON = 0X10; // Wait 2 Cycle From = 8M
//-----IO init -----//
P0M = 0xFf; //1111 111
P0 = 0x00;
P0UR = 0x00;
P1M = 0xF7; //1111 0111 ′ò¿a°′¼üIO¿ú½óêÕ
P1 = 0x00;
P1UR = 0x08;
P1W = 0x00;
P2M = 0xFf; //0000 0011
P2 = 0x00;
P2UR =0x00;
_nop_();
Timer0Tnit();
dat=array[a];
while(1);
void Timer0()interrupt ISRTimer0
TH0=0xff;
TL0=0x7f;
key();
if(flag==1)
EmissionInit();
