分享一個UCOS-atmega128程序
q991123
2017-10-18 12:22
#include "includes.h"
#define F_OSC 8000000 /* Crystal frequence 10Mhz*/
#define LED_ON() { DDRF = 0xff; PORTF = 0x0; }
#define LED_OFF() ( PORTF = 0xff )
* TimerInit()
* Fun: Initial the system timer for os, using timer 0
void TimerInit( void )
TCCR2 = 1<<3; /* work in CTC mode */
OCR2 = 98; /* 100 hz */
TCNT2 = 0;
TIMSK |= 1<<7; /* Enable CTC interrupt */
TCCR2 |= 3; /* start timer, F_OSC/1024 */
OS_EVENT * mbox;
OS_STK stk0[80], stk1[80];
void task0( void * pdata )
INT8U error;
OSMboxPend( mbox, 0, &error );
LED_ON();
OSTimeDly(400);
OSMboxPost( mbox, (void *)1 );
void task1( void * pdata )
INT8U error;
TimerInit();
LED_OFF();
OSTimeDly(400);
int main()
INT8U error;
OSInit();
mbox = OSMboxCreate( (void *)1 );
OSTaskCreate( task0, (void *)0, &stk0[99], 2 );
OSTaskCreate( task1, (void *)0, &stk1[99], 3 );
OSStart();
return 0;
…………限于本文篇幅 余下代碼請從51黑下載附件…………
ucos-Atmega128.zip
(160.36 KB, 下載次數: 37)
2017-10-18 12:21 上傳
hpdell
2019-10-18 15:05
下載來學習一下看看,多謝多謝了
hpdell
2019-10-18 15:07
這個是要的是什么編譯環境 ??
leyatt
2019-10-28 10:10
mega128是不是最大只支持16M的時鐘啊
