單片機2位簡單計時器仿真加程序源碼
1515132123
2017-10-10 21:19
單片機2位簡單計時器仿真加程序源碼
單片機計時器仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
(13.85 KB, 下載次數: 38)
2017-10-11 03:23 上傳
(36.1 KB, 下載次數: 36)
2017-10-11 03:22 上傳
#include<reg51.h>
sbit key=P3^0;
sbit ge=P2^7;
sbit shi=P2^6;
uchar time=0,count=0;
uchar code dis[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
uchar code dis_dot[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
void delay (uchar N)
uchar i,j;
for(i=0;i<N;i++)
for(j=0;j<125;j++);
void display(void)
P0=dis[time%10];
ge=0;
delay(3);
ge=1;
P0=dis_dot[time/10];
shi=0;
delay(3);
shi=1;
TMOD=0x01;TH0=0x3c;TL0=0xb0;IE=0x82;//定時器0工作方式1
while(key==1)
display();
TR0=1;
EA=1;
while(key==0)
display();
while(key==1)
display();
EA=0;
while(key==0);
display();
while(key==1)
display();
time=0;
while(key==0)
display();
void T0_time()interrupt 1
count++;
if(count==2)
…………限于本文篇幅 余下代碼請從51黑下載附件…………
147.zip
(62.35 KB, 下載次數: 27)
2017-10-10 21:19 上傳
