| 0x04,0x0E,0x78,0x08,0x08,0xFF,0x08,0x08,0x0A,0x0C,0x18,0x68,0x08,0x08,0x2B,0x10 0x40,0x50,0x48,0x48,0x40,0xFE,0x40,0x44,0x44,0x48,0x30,0x22,0x52,0x8A,0x06,0x02/*"我",0*/ |
| byte2 = { 0xe68891: [ 0x04,0x0E,0x78,0x08,0x08,0xFF,0x08,0x08,0x0A,0x0C,0x18,0x68,0x08,0x08,0x2B,0x10, 0x40,0x50,0x48,0x48,0x40,0xFE,0x40,0x44,0x44,0x48,0x30,0x22,0x52,0x8A,0x06,0x02, ],#我 0xe788b1: [ 0x00,0x01,0x7E,0x22,0x11,0x7F,0x42,0x82,0x7F,0x04,0x07,0x0A,0x11,0x20,0x43,0x1C, 0x08,0xFC,0x10,0x10,0x20,0xFE,0x02,0x04,0xF8,0x00,0xF0,0x10,0x20,0xC0,0x30,0x0E, ],#愛 0xe4bda0: [ 0x08,0x08,0x08,0x11,0x11,0x32,0x34,0x50,0x91,0x11,0x12,0x12,0x14,0x10,0x10,0x10, 0x80,0x80,0x80,0xFE,0x02,0x04,0x20,0x20,0x28,0x24,0x24,0x22,0x22,0x20,0xA0,0x40, ],#你 0xe7a596: [ 0x20,0x11,0x11,0xF9,0x09,0x11,0x11,0x39,0x55,0x95,0x11,0x11,0x11,0x11,0x17,0x10, 0x00,0xF8,0x08,0x08,0x08,0xF8,0x08,0x08,0x08,0xF8,0x08,0x08,0x08,0x08,0xFE,0x00 ],#祖 0xe59bbd: [ 0x00,0x7F,0x40,0x40,0x5F,0x41,0x41,0x4F,0x41,0x41,0x41,0x5F,0x40,0x40,0x7F,0x40, 0x00,0xFC,0x04,0x04,0xF4,0x04,0x04,0xE4,0x04,0x44,0x24,0xF4,0x04,0x04,0xFC,0x04 ],#國 } |
| def draw_chinese(self,ch_str,x_axis,y_axis): offset_=0 y_axis=y_axis*8#中文高度一行占8個 x_axis=127-(x_axis*16)#中文寬度占16個 for k in ch_str: code = 0x00#將中文轉成16進制編碼 data_code = k.encode("utf-8") code |= data_code[0]<<16 code |= data_code[1]<<8 code |= data_code[2] byte_data=font.byte2[code] for y in range(0,16): a_=bin(byte_data[y]).replace('0b','') while len(a_)<8: a_='0'+a_ b_=bin(byte_data[y+16]).replace('0b','') while len(b_)<8: b_='0'+b_ for x in range(0,8): self.set_pixel(x_axis-x-offset_,y+y_axis,int(a_[x]))#文字的上半部分 self.set_pixel(x_axis-x-8-offset_,y+y_axis,int(b_[x]))#文字的下半部分 offset_+=16 |
| TPYBoard v102 (SPI1) | OLED顯示屏(SPI) |
3.3V | VCC (2.8V~5.5V) |
GND | GND |
X6(SCK) | SCK/D0 |
X8(MOSI) | SDA/D1 |
Y10 | RES |
Y9 | DC |
NC(懸空) | CS |
