基于51單片機AD7705模數轉換器使用C程序(自編)
晴楓
2017-7-28 10:35
#include<reg52.h>
sbit ADC_DOUT=P3^0;
sbit ADC_CLK=P3^1;
sbit ADC_DIN=P3^2;
sbit ADC_CS=P3^3;
sbit ADC_DRDY=P3^4;
/****************1毫秒延時函數***********************/
void Delay_1ms(unsigned int x)
unsigned char y,z;
for(;x>0;x--)
for(z=199;z>0;z--)
for(y=1;y>0;y--);
/****************ADC7705控制命令寫入函數**********************/
void Write_ToReg_ADC7705(unsigned int byteword)
unsigned int ADC16bit,Token;
unsigned char i;
ADC_CLK = 1; ADC_CS = 0;
Token = 0x08; ADC16bit = byteword;
for(i=0;i<8;i++) //數據位寫入
if(ADC16bit & Token)
ADC_DIN = 1;
ADC_DIN = 0;
ADC_CLK = 1; ADC_CLK = 0; ADC_CLK = 1;
Token = Token >> 1;
ADC_CLK = 1; ADC_DIN = 1;
/*****************ADC7705初始化************************/
void Init_AD7705(vid)
unsigned char i;
ADC_CLK=1;ADC_DIN=1;
for(i=0;i<40;i++)//防止接口迷失,通信寄存器回到等待寫的狀態
ADC_CLK=0;ADC_CLK=1;
Write_ToReg_ADC7705(0x20); ///選擇通道1,進行下一次寫時鐘寄存器
Write_ToReg_ADC7705(0x06); ////寫時鐘寄存器,并設定更新速率
Write_ToReg_ADC7705(0x10); //選擇通道1,進行下一次寫設置寄存器
Write_ToReg_ADC7705(0x5c);//寫設置寄存器,設置AD7705的極性、緩沖、增益、濾波、校準
Delay_1ms(50);
/*****讀數據寄存器函數*********/
unsigned int ADC7705_Read_16bit_Value(unsigned char channel)
unsigned int ADC16bit;
unsigned char i;
Write_ToReg_ADC7705(0x38|channel);
while(ADC_DRDY == 1);
ADC16bit = 0x00;
for(i=0;i<16;i++)
ADC16bit = ADC16bit << 1;
ADC_CLK = 0;
if(ADC_DOUT == 1)
…………限于本文篇幅 余下代碼請從51黑下載附件…………
AD7705使用程序.zip
(20.16 KB, 下載次數: 206)
2017-7-28 10:33 上傳
ADMIN_ALLENY
2020-4-3 11:38
復位引腳直接接地嗎
江火inseason
2020-6-28 11:28
很實用的程序
bdwang8901
2020-9-21 13:24
沒什么價值
bdwang8901
2020-9-21 13:25
沒什么價值
xiexugang
2022-9-2 09:10
程序沒有用的,不要下載了。main(){} 主函數里面是空的
