標(biāo)題: 求助 音樂頻譜源代碼 [打印本頁]
作者: 明明明1300    時(shí)間: 2017-7-25 14:16
黑幣不夠無法下載,
各位大佬有沒有好心人愿意給個(gè)代碼的?
謝謝大佬們。
板子那些都鏈接好了,就差個(gè)代碼下載調(diào)試。
這里cospaly可以幫忙后期,紅包也行(不過最近窮)。
有同好可以K列啊。
作者: 明明明1300    時(shí)間: 2017-7-25 14:17
有大佬嗎。
萌新求助。
加了一些群都是死群,問問題也沒人回答很是絕望哎
作者: HC6800-ES-V2.0    時(shí)間: 2017-7-26 08:53
問題不清楚嘛!
是要音樂頻譜?還是51單片機(jī)演奏程序?
讓無源蜂鳴器演奏音樂的程序,我有一個(gè),你看是不是你要的?
#include <reg51.h>
sbit voice=P1^5;//蜂鳴器
unsigned char code sound[]={0xff,
0x26,0x20,0x2b,0x20,0x26,0x80,0xff,0x20,0x2b,0x20,0x26,0x20,0x26,0x10,//兩只蝴蝶
0x2b,0x10,0x30,0x80,0xff,0x40,0x39,0x20,0x30,0x20,0x2b,0x40,0x2b,0x20,
0x26,0x20,0x2b,0x20,0x30,0x20,0x39,0x20,0x39,0x10,0x30,0x10,0x40,0x80,
0x40,0x80,0x26,0x20,0x2b,0x20,0x26,0x80,0xff,0x20,0x2b,0x20,0x26,0x20,
0x26,0x10,0x2b,0x10,0x30,0x80,0xff,0x40,0x39,0x20,0x30,0x20,0x2b,0x40,
0x2b,0x20,0x26,0x20,0x2b,0x20,0x30,0x20,0x39,0x20,0x30,0x20,0x2b,0xc0,
0x2b,0x10,0x30,0xc0,0x39,0x20,0x30,0x20,0x2b,0x40,0x2b,0x20,0x26,0x20,
0x2b,0x20,0x30,0x20,0x39,0x20,0x39,0x10,0x30,0x10,0x40,0xc0,0x26,0x20,
0x20,0x20,0x20,0x80,0xff,0x20,0x20,0x20,0x1c,0x20,0x20,0x20,0x26,0xc0,
0x2b,0x20,0x2b,0x20,0x2b,0x60,0x2b,0x20,0x26,0x20,0x2b,0x20,0x30,0x20,
0x39,0x20,0x39,0x20,0x30,0x20,0x30,0x20,0x30,0xc0,0xff,0x40,0xff,0x40,
0xff,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,0x18,0x20,0x19,0x20,0x19,0x20,
0x1c,0x20,0x26,0x20,0x2b,0x20,0x2b,0x20,0x26,0x20,0x26,0x80,0xff,0x20,
0x26,0x20,0x26,0x20,0x20,0x20,0x1c,0x40,0x1c,0x40,0xff,0x20,0x39,0x20,
0x26,0x20,0x2b,0x20,0x2b,0xc0,0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x20,
0x20,0x40,0xff,0x20,0x18,0x40,0x19,0x20,0x1c,0x20,0x1c,0x10,0x19,0x10,
0x26,0x40,0xff,0x20,0x1c,0x20,0x1c,0x20,0x19,0x20,0x1c,0x20,0x20,0x20,
0x26,0x20,0x2b,0x20,0xff,0x20,0x26,0x20,0x2b,0x20,0x26,0x20,0x20,0x80,
0x26,0x20,0x2b,0x20,0xff,0x20,0x40,0x40,0x39,0x20,0x30,0xc0,0xff,0xc0,
0x00
};//音樂數(shù)據(jù),0xff為起始數(shù)據(jù),0x00為終止數(shù)據(jù),以后數(shù)據(jù)兩兩一組,前者為音階,后者為節(jié)拍
unsigned char zdjs=0,jp;
void del(yj);
void main(void)
        unsigned int dpjs=0;
        unsigned char yj;
        TMOD=0x01;
        IE=0x82;
        TH0=0xd8;
        TL0=0xf0;
        TR0=1;
                zdjs=0;
                dpjs++;
                yj=sound[dpjs];
                dpjs++;
                jp=sound[dpjs];
                while(zdjs!=jp)
                        if(yj!=0xff)
                                if(yj!=0)
                                        voice=!voice;
                                        del(yj);
                                        dpjs=0;
                                        break;
                                voice=1;
                                del(jp);
time0() interrupt 1  using 1
        TH0=0xd8;
        TL0=0xf0;
        zdjs++;
void del(yj)
        unsigned char yj2=2;
        while(yj!=0)
                while(yj2!=0)
                        yj2--;
                yj2=2;
                yj--;
作者: lingdudishou    時(shí)間: 2017-7-26 11:26
#include <REG52.H>
#include "SoundPlay.h"
void Delay1ms(unsigned int count)
        unsigned int i,j;
        for(i=0;i<count;i++)
        for(j=0;j<120;j++);
//*****************************Music******************************************************
//揮著翅膀的女孩
unsigned char code Music_Girl[]={ 0x17,0x02, 0x17,0x03, 0x18,0x03, 0x19,0x02, 0x15,0x03,
                                  0x16,0x03, 0x17,0x03, 0x17,0x03, 0x17,0x03, 0x18,0x03,
                                  0x19,0x02, 0x16,0x03, 0x17,0x03, 0x18,0x02, 0x18,0x03,
                                  0x17,0x03, 0x15,0x02, 0x18,0x03, 0x17,0x03, 0x18,0x02,
                                  0x10,0x03, 0x15,0x03, 0x16,0x02, 0x15,0x03, 0x16,0x03,
                                  0x17,0x02, 0x17,0x03, 0x18,0x03, 0x19,0x02, 0x1A,0x03,
                                  0x1B,0x03, 0x1F,0x03, 0x1F,0x03, 0x17,0x03, 0x18,0x03,
                                  0x19,0x02, 0x16,0x03, 0x17,0x03, 0x18,0x03, 0x17,0x03,
                                  0x18,0x03, 0x1F,0x03, 0x1F,0x02, 0x16,0x03, 0x17,0x03,
                                  0x18,0x03, 0x17,0x03, 0x18,0x03, 0x20,0x03, 0x20,0x02,
                                  0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x20,0x03, 0x21,0x03,
                                  0x20,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x1F,0x03,
                                  0x1B,0x03, 0x19,0x03, 0x19,0x03, 0x15,0x03, 0x1A,0x66,
                                  0x1A,0x03, 0x19,0x03, 0x15,0x03, 0x15,0x03, 0x17,0x03,
                                  0x16,0x66, 0x17,0x04, 0x18,0x04, 0x18,0x03, 0x19,0x03,
                                  0x1A,0x03, 0x19,0x03, 0x19,0x03, 0x1F,0x03, 0x1B,0x03,
                                  0x1F,0x00, 0x1A,0x03, 0x1A,0x03, 0x1A,0x03, 0x1B,0x03,
                                  0x1B,0x03, 0x1A,0x03, 0x19,0x03, 0x19,0x02, 0x17,0x03,
                                  0x15,0x17, 0x15,0x03, 0x16,0x03, 0x17,0x03, 0x18,0x03,
                                  0x17,0x04, 0x18,0x0E, 0x18,0x03, 0x17,0x04, 0x18,0x0E,
                                  0x18,0x66, 0x17,0x03, 0x18,0x03, 0x17,0x03, 0x18,0x03,
                                  0x20,0x03, 0x20,0x02, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66,
                                  0x20,0x03, 0x21,0x03, 0x20,0x03, 0x1F,0x03, 0x1B,0x03,
                                  0x1F,0x66, 0x1F,0x04, 0x1B,0x0E, 0x1B,0x03, 0x19,0x03,
                                  0x19,0x03, 0x15,0x03, 0x1A,0x66, 0x1A,0x03, 0x19,0x03,
                                  0x15,0x03, 0x15,0x03, 0x17,0x03, 0x16,0x66, 0x17,0x04,
                                  0x18,0x04, 0x18,0x03, 0x19,0x03, 0x1F,0x03, 0x1B,0x03,
                                  0x1F,0x66, 0x20,0x03, 0x21,0x03, 0x20,0x03, 0x1F,0x03,
                                  0x1B,0x03, 0x1F,0x66, 0x1F,0x03, 0x1B,0x03, 0x19,0x03,
                                  0x19,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x00, 0x18,0x02,
                                  0x18,0x03, 0x1A,0x03, 0x19,0x0D, 0x15,0x03, 0x15,0x02,
                                  0x18,0x66, 0x16,0x02, 0x17,0x02, 0x15,0x00, 0x00,0x00};
//同一首歌
unsigned char code Music_Same[]={ 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x66, 0x18,0x03,
                                  0x17,0x02, 0x15,0x02, 0x16,0x01, 0x15,0x02, 0x10,0x02,
                                  0x15,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x02,
                                  0x17,0x03, 0x18,0x03, 0x19,0x02, 0x15,0x02, 0x18,0x66,
                                  0x17,0x03, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x00,
                                  0x17,0x01, 0x19,0x02, 0x1B,0x02, 0x1B,0x70, 0x1A,0x03,
                                  0x1A,0x01, 0x19,0x02, 0x19,0x03, 0x1A,0x03, 0x1B,0x02,
                                  0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x18,0x66, 0x18,0x03,
                                  0x19,0x02, 0x1A,0x02, 0x19,0x0C, 0x18,0x0D, 0x17,0x03,
                                  0x16,0x01, 0x11,0x02, 0x11,0x03, 0x10,0x03, 0x0F,0x0C,
                                  0x10,0x02, 0x15,0x00, 0x1F,0x01, 0x1A,0x01, 0x18,0x66,
                                  0x19,0x03, 0x1A,0x01, 0x1B,0x02, 0x1B,0x03, 0x1B,0x03,
                                  0x1B,0x0C, 0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x1F,0x01,
                                  0x1A,0x01, 0x18,0x66, 0x19,0x03, 0x1A,0x01, 0x10,0x02,
                                  0x10,0x03, 0x10,0x03, 0x1A,0x0C, 0x18,0x0D, 0x17,0x03,
                                  0x16,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x70,
                                  0x18,0x03, 0x17,0x02, 0x15,0x03, 0x15,0x03, 0x16,0x66,
                                  0x16,0x03, 0x16,0x02, 0x16,0x03, 0x15,0x03, 0x10,0x02,
                                  0x10,0x01, 0x11,0x01, 0x11,0x66, 0x10,0x03, 0x0F,0x0C,
                                  0x1A,0x02, 0x19,0x02, 0x16,0x03, 0x16,0x03, 0x18,0x66,
                                  0x18,0x03, 0x18,0x02, 0x17,0x03, 0x16,0x03, 0x19,0x00,
                                  0x00,0x00 };
//兩只蝴蝶
unsigned char code Music_Two[] ={ 0x17,0x03, 0x16,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03,
                                  0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02,
                                  0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03,
                                  0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x16,0x03,
                                  0x17,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01,
                                  0x10,0x03, 0x15,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03,
                                  0x16,0x03, 0x15,0x03, 0x10,0x03, 0x15,0x03, 0x16,0x01,
                                  0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x19,0x03,
                                  0x19,0x01, 0x19,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x01,
                                  0x16,0x03, 0x16,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03,
                                  0x16,0x03, 0x15,0x03, 0x10,0x03, 0x10,0x0D, 0x15,0x00,
                                  0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03,
                                  0x1B,0x03, 0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03,
                                  0x16,0x0D, 0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03,
                                  0x1A,0x02, 0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03,
                                  0x16,0x01, 0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03,
                                  0x19,0x02, 0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E,
                                  0x1B,0x04, 0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E,
                                  0x1B,0x04, 0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03,
                                  0x17,0x0D, 0x16,0x03, 0x17,0x03, 0x19,0x01, 0x19,0x03,
                                  0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03, 0x1B,0x03,
                                  0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03, 0x16,0x03,
                                  0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03, 0x1A,0x02,
                                  0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x01,
                                  0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03, 0x19,0x03,
                                  0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
                                  0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
                                  0x17,0x16, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
                                  0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x0F,0x02,
                                  0x10,0x03, 0x15,0x00, 0x00,0x00 };
main()
        InitialSound();
                Play(Music_Girl,0,3,360);
                Delay1ms(500);
                Play(Music_Same,0,3,360);
                Delay1ms(500);
                Play(Music_Two,0,3,360);
                Delay1ms(500);
作者: 明明明1300    時(shí)間: 2017-7-26 18:07
HC6800-ES-V2.0 發(fā)表于 2017-7-26 08:53
問題不清楚嘛!
讓無源蜂鳴器演奏音樂的程序,我有一個(gè),你看是不 ...
謝謝大佬,我才看到。。其實(shí)我也不是很懂到底要的是什么程序- - 。。大概,大概是用51驅(qū)動(dòng)點(diǎn)陣模塊的頻譜?
作者: 明明明1300    時(shí)間: 2017-7-26 18:08
lingdudishou 發(fā)表于 2017-7-26 11:26
#include
謝謝大佬。感謝
