標題: 在書上看到的程序,總感覺它中斷里面的掃描緩存有問題,有興趣的可以看一下 [打印本頁]
作者: 星際漫游者    時間: 2017-7-14 15:00
#include <reg52.h>
sbit KEY_IN_1  = P2^4;  //矩陣按鍵的掃描輸入引腳1
sbit KEY_IN_2  = P2^5;  //矩陣按鍵的掃描輸入引腳2
sbit KEY_IN_3  = P2^6;  //矩陣按鍵的掃描輸入引腳3
sbit KEY_IN_4  = P2^7;  //矩陣按鍵的掃描輸入引腳4
sbit KEY_OUT_1 = P2^3;  //矩陣按鍵的掃描輸出引腳1
sbit KEY_OUT_2 = P2^2;  //矩陣按鍵的掃描輸出引腳2
sbit KEY_OUT_3 = P2^1;  //矩陣按鍵的掃描輸出引腳3
sbit KEY_OUT_4 = P2^0;  //矩陣按鍵的掃描輸出引腳4
sbit  ADDR0 = P1^0;
sbit  ADDR1 = P1^1;
sbit  ADDR2 = P1^2;
sbit  ADDR3 = P1^3;
sbit  ENLED = P1^4;
unsigned char code LedChar[] = {
    0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
    0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8e
};  //數碼管真值表
unsigned char KeySta[4][4] = {  //全部矩陣按鍵的當前狀態,默認都未按下
    {1, 1, 1, 1},      //bit類型不能定義數組,因此定義成unsigned char
    {1, 1, 1, 1},
    {1, 1, 1, 1},
    {1, 1, 1, 1}
void main(void)
    unsigned char i, j;
    unsigned char backup[4][4] = {  //按鍵值備份,保存前一次的值
        {1, 1, 1, 1},
        {1, 1, 1, 1},
        {1, 1, 1, 1},
        {1, 1, 1, 1}
    //選擇最右邊的數碼管進行顯示
    P0 = 0xFF;
    ADDR0 = 0;
    ADDR1 = 0;
    ADDR2 = 0;
    ADDR3 = 1;
    ENLED = 0;
    //配置T0工作在模式1,定時1ms
    TMOD = 0x01;
    TH0 = 0xFC;
    TL0 = 0x67;
    TR0 = 1;
    ET0 = 1;
    EA = 1;
        //檢索按鍵狀態的變化
        for (i=0; i<4; i++) //i作為行循環變量
            for (j=0; j<4; j++) //j作為列循環變量
                if (backup[j] != KeySta[j]) //判斷按鍵動作
                    if (backup[j] == 0)   //判斷按鍵彈起
                        P0 = LedChar[i*4+j]; //執行按鍵動作
                    backup[j] = KeySta[j]; //更新前一次的值
void InterruptTimer0() interrupt 1
    unsigned char i;
    static unsigned char keyout = 0;  //矩陣按鍵掃描輸出計數器
    static unsigned char keybuf[4][4] = {  //按鍵掃描緩沖區,保存一段時間內的掃描值
        {0xFF, 0xFF, 0xFF, 0xFF},
    TH0 = 0xFC;  //溢出后進入中斷重新賦值
    TL0 = 0x67;        按照我們的鍵盤掃描程序應該是中斷1ms鍵值賦值一次并賦值
                                         左移4次則keyout加1轉下一列重新掃描16ms掃描完成。而此
                                         程序我發現中斷1ms雖然會有鍵值輸入緩存但他會輸入一次
                                      keyout就增加一次達不到我們所涉及的效果嗎。或許我分析的
                                        不對,就請各位看一下
    //將一行的4個按鍵值移入緩沖區
    keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_1;
    keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_2;
    keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_3;
    keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_4;
    //消抖后更新按鍵狀態
    for (i=0; i<4; i++)  //每行4個按鍵,所以循環4
        if ((keybuf[keyout] & 0x0F) == 0x00)
        {   //連續4次掃描值為0,即16ms(4*4ms)內都只檢測到按下狀態時,可認為按鍵已按下
            KeySta[keyout] = 0;
        else if ((keybuf[keyout] & 0x0F) == 0x0F)
        {   //連續4次掃描值為1,即16ms(4*4ms)內都只檢測到彈起狀態時,可認為按鍵已彈起
            KeySta[keyout] = 1;
    //執行下一次的掃描輸出
    keyout++;
    keyout &= 0x03;  //用跟0x03做“與”的方式,實現加到4即歸零,是不是很巧妙,學會它吧
    switch (keyout)
        case 0:
            KEY_OUT_4 = 1;
            KEY_OUT_1 = 0;
            break;
        case 1:
            KEY_OUT_1 = 1;
            KEY_OUT_2 = 0;
            break;
        case 2:
            KEY_OUT_2 = 1;
            KEY_OUT_3 = 0;
            break;
        case 3:
            KEY_OUT_3 = 1;
            KEY_OUT_4 = 0;
            break;
        default:
            break;
作者: wulin    時間: 2017-7-14 17:08
這是哪本誤人子弟的書,這個例程不值得研究,給你推薦一個例程,程序很簡單,一眼看明白:
#include <reg52.h>                                                 //頭文件
#define uchar unsigned char                         //宏定義
#define uint unsigned int                                 //宏定義
uchar key=0;                                                        //鍵值變量
void key_scan()                                                        //矩陣鍵盤掃描函數
        uchar temp1,temp2,temp3;                        //臨時變量
        static bit sign=0;                                        //按鍵自鎖標志
        static uchar count=0;                                //消抖計數變量
        P3=0xf0;                                                        //先給P3賦一個初值
        if(P3!=0xf0)                                                 //判斷P3不等于所賦初值,說明有健按下
                if(sign==0)                                                //如果按鍵自鎖標志為0
                        count++;                                        //消抖計數
                        if(count>=100)                                //消抖計數自>=100,估算主循環周期調整
                        {                                                        //摒棄Delay延時方式,
                                count=100;                                //防止溢出
                                sign=1;                                        //按鍵自鎖標志置1,鍵不抬起,按其他鍵無效
                                temp1=P3;                                //temp1保存高4位變化
                                P3=0x0f;                                //再給P3賦值0x0f
                                temp2=P3;                                //temp2保存低4位變化
                                temp3=temp2|temp1;                //temp3=高4位+低4位
                                key=temp3;                                //保存鍵值
        else        //按鍵抬起
                sign=0;                                                        //按鍵自鎖標志清0
                count=0;                                                //消抖計數清0
                key_scan();                                                //鍵盤掃描
                P1=key;                                                        //LED低電平亮顯示鍵值
作者: #include51.h    時間: 2019-2-7 15:21
同感,最不喜歡將那些變量名定的又臭又長的
