標題: 求在已有電路圖基礎上設計的函數(shù)信號發(fā)生器的程序 [打印本頁]
作者: 糖糖有點咸 時間: 2017-6-26 15:20
我們的課設要求是設計一個能產生方波、正弦波、三角波、鋸齒波四種波形,且頻率、幅度均可調的函數(shù)信號發(fā)生器。
我們已經設計好了電路圖,也參考了網上的一些程序,但是自己又不會改。求助大神,68個黑幣是我的全部了。
我們使用AT89C52,DAC0832和LCD1602
希望大神在我們已有的電路圖和程序的基礎上幫我們編一下程
PS:以下程序可以實現(xiàn)產生三種波形和調頻的功能,還差產生鋸齒波、波形調幅和使用矩陣鍵盤這幾個功能。
附錄 程序清單(我們在網上找的程序,可供大神參考)
#include<reg52.h>
#define DAdata P0 //DA數(shù)據(jù)端口
sbit DA_S1= P2^0; // 控制DAC0832的8位輸入寄存器,僅當都為0時,可以輸出數(shù)據(jù)(處于直通狀態(tài)),否則,輸出將被鎖存
sbit DA_S2= P2^1; // 控制DAC0832的8位DAC寄存器,僅當都為0時,可以輸出數(shù)據(jù)(處于直通狀態(tài)),否則,輸出將被鎖存
sbit key= P3^2;
uchar wavecount; //'抽點'計數(shù)
uchar THtemp,TLtemp;//傳遞頻率的中間變量
uchar judge=1; //在方波輸出函數(shù)中用于簡單判別作用
uchar waveform; //當其為0、1、2時,分別代表三種波
uchar code freq_unit[3]={10,50,200}; //三種波的頻率單位
uchar idata wavefreq[3]={1,1,1}; //給每種波定義一個數(shù)組單元,用于存放單位頻率的個數(shù)
uchar code lcd_hang1[]={"Sine Wave " "Triangle Wave " "Square Wave " "Select Wave: " "press No.1 key! "};
uchar idata lcd_hang2[16]={"f= Hz "};
uchar code waveTH[]={
0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xec,0xf6,0xf9,0xfb,0xfc,0xfc,0xfd,0xfd,0xfd,0xfe};
uchar code waveTL[]={
0x06,0x8a,0x10,0x4e,0x78,0x93,0xa8,0xb3,0xbe,0xc6, //正弦波頻率調整中間值
0xac,0xde,0x48,0x7a,0x99,0xaf,0xbb,0xc8,0xd0,0xde, //三角波頻率調整中間值
0x88,0x50,0x90,0x32,0x34,0xbe,0x4a,0xa3,0xe5,0x2c};
uchar code triangle_tab[]={ //每隔數(shù)字8,采取一次
0x00,0x08,0x10,0x18,0x20,0x28,0x30,0x38,0x40,0x48,0x50,0x58,0x60,0x68,0x70,0x78,
0x80,0x88,0x90,0x98,0xa0,0xa8,0xb0,0xb8,0xc0,0xc8,0xd0,0xd8,0xe0,0xe8,0xf0,0xf8,0xff,
0xf8,0xf0,0xe8,0xe0,0xd8,0xd0,0xc8,0xc0,0xb8,0xb0,0xa8,0xa0,0x98,0x90,0x88,0x80,
0x78,0x70,0x68,0x60,0x58,0x50,0x48,0x40,0x38,0x30,0x28,0x20,0x18,0x10,0x08,0x00};
uchar code sine_tab[256]={
//輸出電壓從0到最大值(正弦波1/4部分)
0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,
0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,
0xee,0xef,0xf1,0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
//輸出電壓從最大值到0(正弦波1/4部分)
0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,
0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,
0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99 ,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
//輸出電壓從0到最小值(正弦波1/4部分)
0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,0x4e,0x4c,0x48,0x45,0x43,
0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16 ,0x15,0x13,
0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
//輸出電壓從最小值到0(正弦波1/4部分)
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02 ,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,
0x11,0x13,0x15 ,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,
0x40,0x43,0x45,0x48,0x4c,0x4e,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80};
void delay(uchar z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void triangle_out() //三角波輸出
DAdata=triangle_tab[wavecount++];
if(wavecount>64) wavecount=0;
DA_S1=0; //打開8位輸入寄存器
DA_S1=1; //關閉8位輸入寄存器
void sine_out() //正弦波輸出
DAdata=sine_tab[wavecount++];
void square_out() //方波輸出
judge=~judge;
if(judge==1) DAdata=0xff;
else DAdata=0x00;
/************1602液晶的相關函數(shù)*************/
#define lcd_ports P1
sbit rs=P2^2;
sbit rw=P2^3;
sbit lcden=P2^4;
void write_com(uchar com)
rs=0; //置零,表示寫指令
lcden=0;
lcd_ports=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
rs=1; //置1,表示寫數(shù)據(jù)(在指令所指的地方寫數(shù)據(jù))
lcden=0;
lcd_ports=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void disp_lcd(uchar addr,uchar *temp1)
uchar num;
write_com(addr);
delay(1); //延時一會兒???
for(num=0;num<16;num++)
write_date(temp1[num]);//或者這樣寫write_date(*(temp1+num));
delay(1);
void init_lcd()
//uchar num;
lcden=0; //可有可無???
rw=0; //初始化一定要設置為零,表示寫數(shù)據(jù)
write_com(0x38); //使液晶顯示點陣,為下面做準備
write_com(0x0c); //初始設置
write_com(0x06); //初始設置
write_com(0x01); //清零
write_com(0x80); //使指針指向第一行第一格
disp_lcd(0x80,&lcd_hang1[3*16]); //在第一行顯示
disp_lcd(0xc0,&lcd_hang1[4*16]); //在第二行顯示
/********************1602液晶函數(shù)聲明結束*********************/
uchar i=0;
DA_S2=0; //使DAC寄存器處于直通狀態(tài)
DAdata=0;
init_lcd();
waveform=0;
TMOD=0x01; //設置定時器0為16位工作方式
IT0=1; //設置外部中斷0為下降沿觸發(fā)
ET0=1; //開定時器中斷
EX0=1;
EA=1;
//DAout(0xff); //可輸出TTL波形
//DAout(0x80);
//T_temp=32;
void timer0() interrupt 1
TH0=THtemp;
TL0=TLtemp;
if(waveform==0) sine_out();
else if(waveform==1) triangle_out();
else if(waveform==2) square_out();
void key_int0() interrupt 0
uchar keytemp;
uint total_freq; //總頻率
EA=0; TR0=0; //關總中斷與定時器
delay(5); //延時夠嗎???
if(key==0) //確實有按鍵按下而引發(fā)中斷
keytemp=P3&0xf0; //獲取P3口高四位的值
switch(keytemp)
case 0xe0: //選擇波形
waveform++;
if(waveform>2) waveform=0;
break;
case 0xd0: //頻率按規(guī)定單位依次增加
wavefreq[waveform]++;
if(wavefreq[waveform]>10) wavefreq[waveform]=1; // /*這邊要用“>10”,因為它比“=11”可靠
break; // 性更高,使加數(shù)有個上限,不會一直加下去*/
case 0xb0: //頻率按規(guī)定單位依次衰減
wavefreq[waveform]--;
if(wavefreq[waveform]<1) wavefreq[waveform]=10; //這邊要用“<1”,因為它比“=0”可靠性更高
break;
case 0x70: //TTL輸出
DA_S2=1; //使DAC寄存器關閉
break;
THtemp=waveTH[waveform*10+(wavefreq[waveform]-1)]; //方括號中選取第幾個數(shù)后,并把該值賦給T_temp
TLtemp=waveTL[waveform*10+(wavefreq[waveform]-1)];
total_freq= wavefreq[waveform] * freq_unit[waveform]; //求輸出頻率(個數(shù)*單位)
lcd_hang2[5]=total_freq%10+0x30; //在液晶中顯示個位,(0x30 在液晶顯示中表示數(shù)字0)
total_freq/=10; lcd_hang2[4]=total_freq%10+0x30; //在液晶中顯示時十位
total_freq/=10; lcd_hang2[3]=total_freq%10+0x30; //在液晶中顯示時百位
total_freq/=10; lcd_hang2[2]=total_freq%10+0x30; //在液晶中顯示時千位
disp_lcd(0x80,&lcd_hang1[waveform*16]); //在第一行顯示
disp_lcd(0xc0,lcd_hang2); //在第二行顯示
wavecount=0; //'抽點'計數(shù)清零
while(!key);
EA=1; TR0=1; //開啟總中斷與定時器
(67.5 KB, 下載次數(shù): 175)
2017-6-26 15:04 上傳
函數(shù)信號發(fā)生器電路圖
作者: cjjcjj1 時間: 2017-6-26 16:53
提示: 作者被禁止或刪除 內容自動屏蔽
作者: cjjcjj1 時間: 2017-6-26 16:55
提示: 作者被禁止或刪除 內容自動屏蔽
作者: 糖糖有點咸 時間: 2017-6-28 22:09
并未得到解決
作者: 小飛123456 時間: 2018-11-20 14:51
對啊 感覺幫助不大
