標(biāo)題: 串口通信,仿真成功,實(shí)際失敗,數(shù)碼管都沒亮 [打印本頁]
作者: geerbaziqiang    時(shí)間: 2017-6-23 23:50
#include<REG52.H>
uchar code a1[]={"ok#"};
uchar code a2[]={"..>>OK#"};
uchar code a3[]={"..well#"};
int data b1[10];
int data b2[8]={0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7};
int q=0;
uchar code *p;
void delay(uint k)
  uint data i,j;
  for(i=0;i<k;i++)
  for(j=0;j<121;j++){;}
void send(uchar code *a)
int m=0;
while(a[m]!=0x23)
SBUF=a[m];
m++;
while(TI==0);
TI=0;
delay(100);
m=0;
void send1(int data *c)
int q=0;
while(c[q]!=0)
SBUF=c[q];
q++;
while(TI==0);
TI=0;
delay(100);
q=0;
void read(int data *b)
int n=0;
  while(n<1)
        if(P1==0xFE) //1
    b[n]=0x31;
    n++;
        if(P1==0xFD) //2
    b[n]=0x32;
    n++;
        if(P1==0xFB) //3
    b[n]=0x33;
    n++;
           if(P1==0xF7) //4
    b[n]=0x34;
    n++;
        if(P1==0xEF) //5
    b[n]=0x35;
    n++;
           if(P1==0xDF) //6
    b[n]=0x36;
    n++;
           if(P1==0xBF) //7
    b[n]=0x37;
    n++;
           if(P1==0x7F) //8
    b[n]=0x38;
    n++;
           if(P1==0xFC) //9
    b[n]=0x39;
    n++;
           if(P1==0xF9) //0
    b[n]=0x30;
    n++;
b[n]=0;
int read1(int data *d,int data f)
{  uchar t;
   t=SBUF;
   if(t==0x31)
   { d[f]=0xF9;
send(a2);
if(t==0x32)
{ d[f]=0xA4;
send(a3);
if(t==0x33)
{d[f]=0xB0;
if(t==0x34)
{d[f]=0x99;
if(t==0x35)
{d[f]=0x92;
if(t==0x36)
{d[f]=0x82;
if(t==0x37)
{d[f]=0xF8;
  if(t==0x38)
  {d[f]=0x80;
   if(t==0x39)
   {d[f]=0x90;
   if(t==0x30)
   {d[f]=0xC0;
   return(d[f]);
void send2(int e)
P0=e;
P2=q;
delay(100);
void main(void)
  int h=-1;
TMOD=0x20;
TL1=0xFD;
TH1=0xFD;
TR1=1;
SCON=0x50;
p=a1;
send(p);
{for(q=0;q<8;q++)
         {send2(b2[q]);
  if(P1!=0xFF)
  {delay(10);
                if(P1!=0xFF)         //按鍵
                read(b1);
  send1(b1);
if(RI==1)                                 //數(shù)碼管修改
{        RI=0;
   b2[h]=read1(b2,h);
   h++;
   if(h==8)
   {h=-1;}
作者: geerbaziqiang    時(shí)間: 2017-6-24 00:06
仿真時(shí)接的是右下角虛擬終端。實(shí)物連接一開始數(shù)碼管還有顯示,時(shí)斷時(shí)續(xù),重焊接了一下就完全炸了。
作者: 51mcu    時(shí)間: 2017-6-24 06:54
重點(diǎn)檢查硬件電路,很可能是硬件電路焊接存在問題。
作者: a0931727149    時(shí)間: 2017-6-24 08:28
實(shí)物連接-數(shù)碼管有顯示時(shí)斷時(shí)續(xù)應(yīng)該是程式有bug
重焊一下完全炸了應(yīng)該是硬件有問題.....這需要靠自己量測
首先應(yīng)該處理硬件的問題....將data b2[]的內(nèi)容改成數(shù)碼管可以顯示的自形,測試硬件;
等到硬件正常後再來修正程式的bug .......
作者: cjjcjj1    時(shí)間: 2017-6-24 08:50
提示: 作者被禁止或刪除 內(nèi)容自動(dòng)屏蔽
作者: geerbaziqiang    時(shí)間: 2017-6-24 18:33
謝謝,現(xiàn)在數(shù)碼管好用了,能亮了。
但是通訊還是沒反應(yīng)。串行通訊時(shí),在串口通訊助手里發(fā)送字符沒有反應(yīng),單片機(jī)按鍵按下去也沒有接受。
max232查了輸入正極5v,負(fù)極0v,v+,v-之間為16v,好像沒問題。但我不知道com口怎么測,測出來發(fā)送線和接受線是-7v左右,不知道是不是意味著沒輸出。我仿真的時(shí)候用的是proteus,用虛擬終端模擬的PC,不確定程序是不是真的好使。
作者: poll12    時(shí)間: 2017-6-24 19:04
電壓問題
作者: zxpzxpzxp    時(shí)間: 2017-6-24 19:23
同問,怎么解決?
作者: qq469332529    時(shí)間: 2017-6-24 19:36
硬件哪里有問題?我也沒看出來
作者: a0931727149    時(shí)間: 2017-6-24 21:57
當(dāng)Reset c.後串口會(huì)接收到 OK字符.....當(dāng)按下按鍵後串口會(huì)一直傳送該按鍵......如按下按鍵1 後串口會(huì)一直重複傳送1這個(gè)字符......無法再接收其他的按鍵......
作者: a0931727149    時(shí)間: 2017-6-24 22:12
用Keil debug  模式下的結(jié)果......
當(dāng)reset 後串口會(huì)送出"OK"這兩個(gè)字符.....按下按鍵後串口會(huì)一直傳送該按件值.....
如果用串口程式?jīng)]有接收到ok這兩個(gè)字符那代表應(yīng)件接線還是有問題.....
應(yīng)先讓硬件正常後.....在來修正程式中的BUG......
作者: BJZT    時(shí)間: 2017-6-27 11:38
遇到問題首先分析問題的源頭!各種功能最好要分開測試,以免混亂!你這個(gè)最好先測試好LED數(shù)碼管!讓數(shù)碼管顯示一個(gè)固定的數(shù)值,然后測試串口,并顯示在數(shù)碼管上面
作者: zl2168    時(shí)間: 2017-6-27 19:44
90%硬件問題
