STC52rc單片機點亮LCD1602程序
WaSHB
2017-6-12 10:26
stc52rc單片機點亮LCD1602程序如附件。顯示時鐘。
#include <reg52.h>
#include <intrins.h>
uint dxf[8]; //定義一個數組,用于顯示秒高低位、 分高低位、 時高低位及冒號
uint num1,num2,num3,num4,num5,num6,count1; //count1用于中斷50MS時間到判斷
uint fk0,fk1,fk2,fk3,fk4,fk5,fk6,fk7,ab1,ab2,ab3,ab4,ab5,ab6;
sbit LCDEn=P0^2;
sbit RS11=P0^0;
sbit rw=P0^1;
unsigned char code table[]={"HELLO 2015 "};
unsigned char code table1[]={"hello world: "};
unsigned char code tab12[]={'0','1','2','3','4','5','6','7','8','9'}; //用于液晶顯示調用
unsigned char code tab13[]={":"} ;
unsigned char code tab11[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//用于數碼顯示調用
void delay2(num2) //長延時
uchar aa1;
for(;num2>0;num2--)
for(aa1=120;aa1>0;aa1--)
void T01() interrupt 1 /*****定時器T0中斷子程序*****/
count1++ ;
if(count1==4)
num4++;
count1=0;
TH0=(65535-50000)/256; /*******50ms定時器,高八位******/
TL0= (65535-50000)%256;
void delay(unsigned int m )
unsigned char n; /****局部定義**/
for(;m>1;m--)
for(n=60;n>0;n--)
void okplay( )// 開顯示
uchar aa2;
for(aa2=1;aa2<9;aa2++)
if(num4==60)
num5++;
if(num5==60)
num6++;
if(num6==24)
num6=0;
num5=0;
num4=0;
switch(aa2)
case 1: dxf[0]=num6/10; break;
case 2: dxf[1]=num6%10; break;
case 3: dxf[2]=0[tab13] ; break;
case 4: dxf[3]=num5/10; break;
case 5: dxf[4]=num5%10; break;
case 6: dxf[5]=0[tab13] ; break;
case 7: dxf[6]=num4/10; break;
case 8: dxf[7]=num4%10; P1=dxf[7][tab11]; P3=0X20; break;
void lowcom(unsigned char a) /****寫命令**/
LCDEn=0;
RS11=0;
rw=0;
P2=a;
delay(2);
LCDEn=1;
delay(2);
LCDEn=0;
void lowwrite(uchar ab) /****寫數據**/
LCDEn=0;
RS11=1;
rw=0;
P2=ab;
delay(2);
LCDEn=1;
delay(2);
LCDEn=0;
/********初始化程序********/
void invion()
lowcom(0x38); /****開顯示**/
delay(2);
lowcom(0x0f); /****初始化**/
delay(2);
lowcom(0x06); /***寫一個指針數加1**/
delay(2);
lowcom(0x0C);/****開顯示不顯光標**/
delay(2);
unsigned char xx1,xx2;
TMOD=0X01;
TH0=(65535-50000)/256; /*******5ms定時器,高八位******/
EA=1; /******開總中斷******/
ET0=1;/******允許T0中斷******/
TR0=1; /*******T0中斷開始******/
invion(); /****初始化**/
okplay();
lowcom(0x80);/****顯示第一行從第1 位開始顯示**/
for(xx1=0;xx1<8;xx1++)
//原顯示lowwrite( dxf[xx1][tab12]),因冒號無法顯示改為switch語句
switch(xx1)
case 0:lowwrite( dxf[xx1][tab12]); break ;
case 1: lowwrite(dxf[xx1][tab12]); break;
…………限于本文篇幅 余下代碼請從51黑下載附件…………
(50.76 KB, 下載次數: 62)
2017-6-12 15:40 上傳
LCD_1.zip
(38.98 KB, 下載次數: 16)
2017-6-12 10:26 上傳
