標(biāo)題: 信道均衡 MCA算法 [打印本頁(yè)]
作者: 254945521    時(shí)間: 2017-6-1 09:33
% -----------實(shí)值信號(hào)~均衡器 ----------------%
clear all;    close all;
%%  -----------實(shí)值信號(hào)~均衡器----------------%
% ----生成2PAM信號(hào),點(diǎn)數(shù)為Num-------
Num=3e3;
Xn=rand(1,Num); Xn(Xn>=0.5)=1; Xn (Xn<0.5)=-1;
%% ----經(jīng)過信道,并加噪-------
H=[0.005,0.009,-0.024,0.854,-0.218,0.049,-0.016];
%電話信道系數(shù)矩陣,長(zhǎng)度為7. H(z)=0.005+0.009*(z^-1)-0.024*(z^-2)+...-0.016*(z^-6)、
Yn=filter(H,1,Xn);% 通過信道未加噪聲序列,長(zhǎng)度Num+6
SNR=20;  sig=awgn(Yn,SNR);  %加噪SNR=20dB
W=[0,0,0,1,0,0,0];     % 初始化均衡濾波器系數(shù),長(zhǎng)度為7
Y=[0,0,0,0,0,0,0];     % 長(zhǎng)度為7
Lf=7;
mu=0.0008;
R2=1;    %恒模常量,2PAM
    for m=1:1:Num    % Num+6卷積后Yn的長(zhǎng)度
        %------經(jīng)過濾波器模塊------
       Y=[sig(m) Y(1:6)];
       s= Y(Lf:-1:1)*W(1:Lf).';
        X(m)=s;
        %------判決模塊------
        a(m)=1;
        if X(m)<=0
            a(m)=-1;
        end
        %------誤差信號(hào)計(jì)算模塊------
        En=s *(s*s-R2);
        %------迭代模塊(系數(shù)更新)------
        W=W-mu*En*Y(Lf:-1:1);
    end
   % ----- 計(jì)算誤碼率-----
    j=0; l=0;
    for k=1:Num-Lf+1
        if a(k+Lf-1)==Xn(k)
            l=l+1;
             j=j+1;   % 計(jì)算錯(cuò)誤的數(shù)量
            C(j)=k; % 計(jì)算出錯(cuò)位置
        end
    end
BER=j/( Num-Lf+1);
%% ------------------程序后處理---------------------
