自己做的8位競賽搶答器仿真與代碼
csz8773
2017-5-29 18:42
自己做的8位競賽搶答器仿真與代碼
可能有些小毛病仿真沒毛病,就是自己的那個開發(fā)版出不來,大家拿去研究研究
仿真原理圖如下 需要用8.0以上的版本(proteus仿真工程文件可到本帖附件中下載)
(40.85 KB, 下載次數(shù): 97)
2017-5-30 01:24 上傳
(69.13 KB, 下載次數(shù): 80)
2017-5-30 01:24 上傳
單片機(jī)源代碼如下:
#include <reg52.h>
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//變量定義
sbit BEEP=P3^1;
sbit start_stop=P3^2;
sbit reset=P3^3;
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
sbit key4=P1^3;
sbit key5=P1^4;
sbit key6=P1^5;
sbit key7=P1^6;
sbit key8=P1^7;
sbit state=P3^0;
bit start_stop_flag=0;
bit key1_flag=0;
bit key2_flag=0;
bit key3_flag=0;
bit key4_flag=0;
bit key5_flag=0;
bit key6_flag=0;
bit key7_flag=0;
bit key8_flag=0;
bit reset_flag=0;
bit action=0;
uchar second=20;
uchar timer0_count=0;
uchar number=0;
uchar number_display=0;
uint flag=1; //延時函數(shù)
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=120;y>0;y--);
} //蜂鳴器發(fā)聲延時
void DelayMS(uint x)
uchar t;
while(x--)
for(t=0;t<100;t++);
} //數(shù)碼管顯示驅(qū)動函數(shù)
void display(uchar number,uchar second)
uchar second_first,second_second;
second_first = second / 10;
second_second = second % 10;
P0 =0x00;
P2 = 0xfe;
P0 = table[number];
delay(2);
P0 =0x00;
P2 = 0xfd;
P0 = 0x40;
delay(2);
P0 =0x00;
P2 = 0xfb;
P0 = table[second_first];
delay(2);
P0 =0x00;
P2 = 0xf7;
P0 = table[second_second];
delay(2);
P0 =0x00; } //蜂鳴器響應(yīng)按周期t發(fā)音
void Play(uchar t)
{ uchar i; for(i=0;i<1;i++)
{ BEEP=~BEEP;
DelayMS(t); } BEEP=0;
} //開始鍵掃描函數(shù)
void start_stop_keyscan()
if(start_stop == 0)
delay(8);
if((start_stop == 0)&&(!start_stop_flag))
start_stop_flag = 1;
action = 1;
TR0 = 1;
state = 0;
start_stop_flag = 0;
} //八位搶答鍵掃描函數(shù)
uchar key_scan8()
if(key1 == 0)
delay(8);
if((key1 == 0)&&(!key1_flag))
key1_flag = 1;
number = 1;
number_display = number;
key1_flag = 0;
number = 0;
} if(key2 == 0)
delay(8);
if((key2 == 0)&&(!key2_flag))
key2_flag = 1;
number = 2;
key2_flag = 0;
number = 0;
if(key3 == 0)
delay(8);
if((key3 == 0)&&(!key3_flag))
key3_flag = 1;
number = 3;
key3_flag = 0;
number = 0;
if(key4 == 0)
delay(8);
if((key4 == 0)&&(!key4_flag))
key4_flag = 1;
number = 4;
key4_flag = 0;
number = 0;
if(key5 == 0)
delay(8);
if((key5 == 0)&&(!key5_flag))
key5_flag = 1;
number = 5;
key5_flag = 0;
number = 0;
if(key6 == 0)
delay(8);
if((key6 == 0)&&(!key6_flag))
key6_flag = 1;
number = 6;
key6_flag = 0;
number = 0;
if(key7 == 0)
delay(8);
if((key7 == 0)&&(!key7_flag))
key7_flag = 1;
number = 7;
key7_flag = 0;
number = 0;
if(key8 == 0)
delay(8);
if((key8 == 0)&&(!key8_flag))
key8_flag = 1;
number = 8;
} else
key8_flag = 0;
number = 0;
} if(number_display != 0)
return 1;
return 0;
} //復(fù)位鍵掃描函數(shù)
void reset_keyscan()
if(reset == 0)
delay(8);
if((reset==0)&&(!reset_flag))
reset_flag = 1;
number_display = 0;
state = 1;
reset_flag = 0;
} //主函數(shù)
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA= 1;
ET0= 1;
TR0=0;
while( 1)
if(number_display!=0)
Play(number_display/2); //蜂鳴器發(fā)聲
start_stop_keyscan();
reset_keyscan();
while(action)
while(!key_scan8())
display(number_display,second);
if(second == 0)
…………限于本文篇幅 余下代碼請從51黑下載附件…………
8位競賽搶答器課程設(shè)計(jì).zip
(56.9 KB, 下載次數(shù): 137)
2017-5-29 18:41 上傳
點(diǎn)擊文件名下載附件
505631748
2018-6-27 11:11
很好很好
星空下你我
2018-7-6 12:16
沒流程圖啊
親愛的h
2018-7-12 23:58
用8.6報(bào)錯
boo_ker
2018-10-21 18:43
流程圖有嗎?
林鹿
2019-7-1 19:25
請問這個要怎么復(fù)位啊
admin_z
2019-7-3 12:18
好東西
野人豬心
2020-1-7 14:03
這個有流程圖嗎
寶貝兒111
2020-1-7 15:09
自己在protues上走了一遍程序,還可以,不錯
世事有償
2020-1-7 15:22
可以的,正要做這個
QQ1050409603
2020-1-7 19:03
好東西
