標(biāo)題: STM32F103與FPM10A指紋識(shí)別與上位機(jī)測試可以錄指紋 連單片機(jī)之后就收不到數(shù)據(jù) [打印本頁]
作者: 夏天HIGH    時(shí)間: 2017-5-24 21:31
用串口通信,串口程序沒有問題,用串口助手測試能夠收發(fā),指紋模塊與上位機(jī)測試也能夠錄指紋,但是連接單片機(jī)之后就收不到數(shù)據(jù)
代碼下載:
STM32程序.rar (298.98 KB, 下載次數(shù): 34)
  1. #include "sys.h"
  2. #include "usart.h"
  3. #include "delay.h"
  4. #include "key.h"
  5. #include "lcd1602.h"
  6. #include "fpmxx.h"
  7. unsigned char LCD_ID_11[16] = {"    Huan Ying   "};
  8. unsigned char LCD_ID_22[16] = {"     Shi Bai    "};
  9. unsigned char LCD_ID_33[16] = {"  Qing Shi Yong "};
  10. void FPMXX_Check_Module()
  11. {
  12.          unsigned int i=0;
  13.          FPMXX_Cmd_Check();
  14.    for(i=0;i<12;i++)
  15.          {
  16.            FPMXX_RECEICE_BUFFER[i] = UART_Receive_Byte();//UART Receive a byteg
  17.    }
  18.          if(FPMXX_RECEICE_BUFFER[8]==0x03)
  19.          {
  20.                  for(i=0;i<556;i++)
  21.                  {
  22.                          switch(i)
  23.                          {
  24.                                  case 37:FPMXX_RECEICE_BUFFER[1] = UART_Receive_Byte();break;
  25.                                  case 38:FPMXX_RECEICE_BUFFER[2] = UART_Receive_Byte();break;
  26.                                  case 39:FPMXX_RECEICE_BUFFER[3] = UART_Receive_Byte();break;
  27.                                  case 40:FPMXX_RECEICE_BUFFER[4] = UART_Receive_Byte();break;
  28.                                  case 41:FPMXX_RECEICE_BUFFER[5] = UART_Receive_Byte();break;
  29.                                  default:FPMXX_RECEICE_BUFFER[0] = UART_Receive_Byte();
  30.                          }
  31.                  }
  32.
  33.                  //判斷指紋模塊型號(hào)
  34.                  if(FPMXX_RECEICE_BUFFER[1] == 0x46 && +
  35.                           FPMXX_RECEICE_BUFFER[2] == 0x50 && +
  36.                                 FPMXX_RECEICE_BUFFER[3] == 0x4D && +
  37.                                 FPMXX_RECEICE_BUFFER[4] == 0x31 && +
  38.                                 FPMXX_RECEICE_BUFFER[5] == 0x30)
  39.                  {
  40.                          L1602_string(1,1,LCD_ID_11);
  41.                          while(1)
  42.                          {
  43.                                  if(KEY0 == 0)
  44.                                  {
  45.                                          delay_ms(10);
  46.                                          while(KEY0 == 0);
  47.                                          delay_ms(100);
  48.                                          break;
  49.                                  }
  50.                                  delay_ms(100);
  51.                          }
  52.                  }
  53.          }
  54. }
  55.
  56. int main(void)
  57. {
  58.           Stm32_Clock_Init(9);//系統(tǒng)時(shí)鐘設(shè)置
  59.         delay_init(72);                //延時(shí)初始化
  60.         uart_init(72,57600); //串口1初始化
  61.
  62.     KEY_Init();
  63.         L1602_init();
  64.         L1602_string(1,1,LCD_ID_11);
  65.         delay_ms(20000);
  66.         USART1->DR=0X00;
  67.         while((USART1->SR&0X40)==0);//等待發(fā)送結(jié)束
  68.         delay_ms(20);
  69.         L1602_string(1,1,LCD_ID_22);
  70.         FPMXX_Check_Module();
  71.         while(1)
  72.         {
  73.         L1602_string(1,1,LCD_ID_11);
  74.                 L1602_string(2,1,LCD_ID_33);
  75.                 //添加指紋
  76.                 if(KEY0 == 0)
  77.                 {
  78.                         delay_ms(10);
  79.                         while(KEY0==0); //等待松開按鍵
  80.                         delay_ms(100);
  81.                         FPMXX_Add_Fingerprint();
  82.                 }
  83.                 //添加指紋
  84.
  85.                 //搜索指紋
  86.                 if(KEY1 == 0)
  87.                 {
  88.                         delay_ms(10);
  89.                         while(KEY1==0); //等待松開按鍵
  90.                         delay_ms(100);
  91.                         FPMXX_Find_Fingerprint();
  92.                 }
  93.                 //搜索指紋
  94.                 //清空指紋
  95.                 if(KEY2 == 0)
  96.                 {
  97.                         delay_ms(10);
  98.                         while(KEY2==0); //等待松開按鍵
  99.                         delay_ms(100);
  100.                         FPMXX_Delete_All_Fingerprint();
  101.                 }
  102.                 //清空指紋
  103.         }
  104. }
