標題: 1602顯示程序 [打印本頁]
作者: stupidqq    時間: 2017-5-19 22:35
標題: 1602顯示程序
#include"stc12c5a60s2.h"
sbit rs=P2^5;
sbit rw=P2^6;
sbit E=P2^7;
bit  shuaxin=1;
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
sbit key4=P1^3;
uchar name[]="Name: Xuwenlei ";
uchar tim[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3a,0x53,0x4a}; //0~9和: S J
uchar i;
uchar  shan;
uchar js50ms,second,minut,hour;
uchar  s1,s2,m1,m2,h1,h2;
void delay(uchar x)           //延時函數
{        uint y;
                        for(;x>0;x--)
                for(y=100;y>0;y--)
void LCD_wrdata(uchar dat)         //寫數據到LCD
        delay(6);
        rs=1;  //寫數據時RS拉高
        rw=0;
        E=1;
        P0=dat;
        delay(6);
        E=0;
        delay(6);
void LCD_wrcom(uchar cdat)//寫指令到LCD
        delay(6);
        rs=0;//寫指令時RS拉低
        rw=0;
        E=1;
        P0=cdat;//
        delay(6);//不加此延時將導致不能寫入指令,但能寫入顯示數據
        E=0;
        delay(6);
void LCD_Clear()        //清屏函數
  LCD_wrcom(0x01);
  delay(6);
void initiate()                          //1602初始化函數
    LCD_wrcom(0x38);                 //          顯示模式設置:16*2顯示,5*7點陣,8位數據接口
        LCD_wrcom(0x06);                 //          顯示模式設置:顯示開,有光標,光標閃爍
        LCD_wrcom(0x0c);                 //          顯示模式設置:光標右移,字符不移
void T0_init()                 //T0初始化
    TMOD=0x01;     //T0方式1
        TH0=0x4c;
        TL0=0x00;       //50ms初值
        TR0=1;
        ET0=1;
        EX0=1;
        IT0=1;
        EA=1;
void LCD_wirte_setring(uchar x,uchar y,uchar *s)  //寫字符串函數
if(y==0){LCD_wrcom( 0x80+x);}
else{LCD_wrcom( 0xc0+x);}
while(*s)
   LCD_wrdata(*s);
   s++;
void LCD_wirte_data(uchar x,uchar y,uchar dat)          //寫字符函數
  LCD_wrdata(dat);
void LCD_Time()                                  //時間顯示函數
{        s1=second%10;                   //  時間賦值                秒分時
    s2=second/10;
        m1=minut%10;
        m2=minut/10;
        h1=hour%10;
        h2=hour/10;
    LCD_wirte_data(6,1,tim[h2]);
    LCD_wirte_data(7,1,tim[h1]);
        LCD_wirte_data(8,1,tim[10]);
        LCD_wirte_data(9,1,tim[m2]);
        LCD_wirte_data(10,1,tim[m1]);
        LCD_wirte_data(11,1,tim[10]);
        LCD_wirte_data(12,1,tim[s2]);
        LCD_wirte_data(13,1,s1+'0');
void key_can() interrupt 0
  key1=1;key2=1; key3=1;key4=1;
   if(key1==0){          shan++;  TR0=0;
                        if(shan==4)shan=0        ;
        switch(shan){
        case 0:        shan=0;TR0=1;
        LCD_wrcom(0x0c);
        LCD_wirte_setring(1,0,"Name:Xuwenlei ") ;
        break;
                                            case 1:
        LCD_wirte_setring(1,0,"Name:hour    ") ;
        LCD_wrcom(0x0f);
        delay(10);
        break;
                                            case 2:
        LCD_wirte_setring(1,0,"Name:mint    ") ;
        LCD_wrcom(0x0f);
        delay(10);
        break;
                                            case 3:
        LCD_wirte_setring(1,0,"Name:second    ") ;
        LCD_wrcom(0x0f);
        delay(10);
        break;
// if(key2==0&&shan==1)
if(key2==0){
                                 if(shan==1) { hour++; shuaxin=1;   //h加1
        if(hour==24){hour=0;} }
                                                   else if(shan==2){minut++; shuaxin=1;
        if(minut==60){minut=0;}         }
                               else if(shan==3){second++;shuaxin=1;
        if(second==60){second=0; }
if(key3==0){
                       if(shan==1) {     //h減1
        if(hour==0){hour=24;}
        hour--;shuaxin=1;
                                                          else if(shan==2){
        if(minut==0){minut=60;}minut--;shuaxin=1;
                                 else if(shan==3){
        if(second==0){second=60;} second--;shuaxin=1;
void T0_intop() interrupt 1
  TH0=0x4c;
        TL0=0x00;       //50ms初值重裝
        js50ms++;
  if(js50ms==20)        //1s
     js50ms=0;
         shuaxin=1;
                 second++;
                if(second==60)   //60s
                        second=0;
      minut++;
                        if(minut==60)  //60m
        minut=0;
                                hour++;
                                if(hour==24) //60h
           hour=0;
    initiate();                 //          調1602初始化函數
        T0_init();                  //T0 初始化
        LCD_Clear();          //清屏
    LCD_wirte_setring(1,0,"Name:Xuwenlei") ;
        LCD_wirte_setring(1,1,"Time:") ;
//        { LCD_Time(); }
        if(shuaxin)
        shuaxin=0;
        LCD_Time();
