標(biāo)題: 哪位大神幫我看下這個(gè)超聲波仿真 [打印本頁(yè)]
作者: seeker0528    時(shí)間: 2017-5-16 00:43
求問(wèn):超聲波上的數(shù)值為什么和LCD顯示屏上的NOW值不能同步顯示?總是相差點(diǎn)
程序在這:#include<reg52.h>#include <intrins.h>
#include "LCD1602.h"
//#include "STCEEPROM.h"
sbit  RX = P1^6;  //定義超聲波端口
sbit  TX = P1^7;
sbit LED = P2^3;  //LED
sbit SPEAK = P2^4; //蜂鳴器
sbit Motor = P2^5; //水泵
sbit KEY1 = P1^2;  //設(shè)置按鍵
sbit KEY2 = P1^3;  //加按鍵
sbit KEY3 = P1^4;  //減按鍵
unsigned int  time=0;//計(jì)時(shí)變量
unsigned int  timer=0;//計(jì)時(shí)變量
unsigned int S=0;//當(dāng)前值
unsigned int SET_H=100,SET_L=10;//最高值和最低值
bit  flag =0; //測(cè)量標(biāo)志位
unsigned char Table[3],Table1[5];//顯示數(shù)組
unsigned char KEY_flag=0; //按鍵選擇標(biāo)志
//延時(shí)函數(shù)
void Delay_ms(int jj)  //延時(shí)函數(shù)
        int ii;        //延時(shí)變量
        while(jj--)//延時(shí)n毫秒
                for(ii=0;ii<116;ii++);//延時(shí)1毫秒
void Conut(void)         //測(cè)量函數(shù)
         time=TH0*256+TL0;         //距離計(jì)數(shù)
         TH0=0;         //定時(shí)器清零
         TL0=0;         //定時(shí)器清零
         S=(time*1.87)/10;     //算出來(lái)是CM、轉(zhuǎn)換
         if((S>=700)||flag==1) //超出測(cè)量范圍顯示“-”
          flag=0; //數(shù)據(jù)無(wú)效標(biāo)志
          Table1[0]= S/1000+0X30;        //顯示當(dāng)前值
          Table1[1]= S/100%10+0X30;        //顯示當(dāng)前值
          Table1[2]= S/10/10+0X30;        //顯示當(dāng)前值
          Table1[3]= '.';                        //顯示當(dāng)前值
          Table1[4]= S%10+0X30;           //顯示當(dāng)前值
          LCD1602_Disp_ZF(0x88,Table1,5); //顯示當(dāng)前值
void main(void)        //主函數(shù)
    LCD1602_init();//液晶初始化
        //////////////////////0123456789ABCDEF
    LCD1602_Disp_ZF(0x80,"  Now S:     CM ",16);
                                                     //0123456789ABCDEF
    LCD1602_Disp_ZF(0x80+0X40,"Set H:    L:    ",16);
        TMOD=0x11;                   //設(shè)T0為方式1,GATE=1;
        TH0=0;                           //定時(shí)器清零
        TL0=0;             //定時(shí)器清零
        TH1=0xf8;                   //2MS定時(shí)
        TL1=0x30;                   //2MS定時(shí)
        ET0=1;             //允許T0中斷
        ET1=1;                           //允許T1中斷
        TR1=1;                           //開(kāi)啟定時(shí)器
        EA=1;                           //開(kāi)啟總中斷
        EA=0;//關(guān)閉中斷
//SET_H = ISP_READ(0x2c00)*256+ISP_READ(0x2c01);//讀取存儲(chǔ)的最大值
//SET_L = ISP_READ(0x2c02)*256+ISP_READ(0x2c03);//讀取存儲(chǔ)的最小值
        EA=1; //開(kāi)啟總中斷
        while(1)//函數(shù)循環(huán)
                while(!RX);                    //當(dāng)RX為零時(shí)等待
                TR0=1;                            //開(kāi)啟計(jì)數(shù)
                while(RX);                        //當(dāng)RX為1計(jì)數(shù)并等待
                TR0=0;                                //關(guān)閉計(jì)數(shù)
                Conut();  //計(jì)算顯示距離函數(shù)
                if((S/10>SET_H)||(S/10<SET_L)) //水位過(guò)低過(guò)高報(bào)警,
                        LED=0;SPEAK=0; //報(bào)警
                        LED=1;SPEAK=1; //不報(bào)警
                if((S/10>SET_H)) //水位過(guò)低打開(kāi)水泵
                        Motor=0; //打開(kāi)
                        Motor=1; //關(guān)閉
                if(!KEY1) //切換設(shè)置最大值和最小值
                        Delay_ms(10);//延時(shí)去抖動(dòng)
                        if(!KEY1)//切換設(shè)置最大值和最小值
                                KEY_flag++;        //模式選擇
                                //ISP_ERASE(0x2c00);                //注意:字節(jié)編程時(shí)必須要先要擦除整個(gè)扇區(qū)
                                //ISP_PROGRAM(0x2c00, SET_H/256);        //記憶存儲(chǔ)
                                //ISP_PROGRAM(0x2c01, SET_H);//記憶存儲(chǔ)
                                //ISP_PROGRAM(0x2c02, SET_L/256);//記憶存儲(chǔ)
                                //ISP_PROGRAM(0x2c03, SET_L);        //記憶存儲(chǔ)
                        while(!KEY1);//等待按鍵抬起
                if(!KEY2)//設(shè)置加
                        if(!KEY2) //設(shè)置加
                                if(KEY_flag%2==0)SET_H++; //設(shè)置加
                                if(KEY_flag%2==1)SET_L++; //設(shè)置加
                if(!KEY3) //設(shè)置減
                                if(KEY_flag%2==0)SET_H--; //設(shè)置減
                                if(KEY_flag%2==1)SET_L--;//設(shè)置減
          Table[0]= SET_H/100+0X30;//顯示最大值
          Table[1]= SET_H%100/10+0X30;
          Table[2]= SET_H%10+0X30;
          LCD1602_Disp_ZF(0x86+0x40,Table,3);
          Table[0]= SET_L/100+0X30;         //顯示最小值
          Table[1]= SET_L%100/10+0X30;
          Table[2]= SET_L%10+0X30;
          LCD1602_Disp_ZF(0x8C+0x40,Table,3);
     void zd0() interrupt 1                  //T0中斷用來(lái)計(jì)數(shù)器溢出,超過(guò)測(cè)距范圍
    flag=1;                                                         //中斷溢出標(biāo)志
   void  zd3()  interrupt 3
         TH1=0xf8;//2毫秒定時(shí)初始化
         TL1=0x30;//2毫秒定時(shí)初始化
         timer++;//計(jì)數(shù)
         if(timer>=100)//計(jì)數(shù)100次,200毫秒
          timer=0;
          TX=1;                                        //200MS  啟動(dòng)一次模塊
          _nop_(); _nop_(); _nop_();
          _nop_(); _nop_();_nop_();
          TX=0;
作者: seeker0528    時(shí)間: 2017-5-16 08:58
有大神幫忙解決下問(wèn)題嗎?小費(fèi)大大的有
作者: 呆萌俠    時(shí)間: 2017-5-16 10:05
能不能把 程序和 仿真發(fā)上來(lái),在調(diào)試的情況下更容易找到原因呢。
作者: cjjcjj1    時(shí)間: 2017-5-16 16:11
提示: 作者被禁止或刪除 內(nèi)容自動(dòng)屏蔽
