51單片機三路紅外尋跡程序
liyue123liye
2017-5-9 20:33
51單片機三路紅外尋跡程序
#include<reg52.h>
sbit IN1=P0^1;
sbit ENA=P0^5;
sbit IN2=P0^2;
sbit IN4=P0^4;
sbit ENB=P0^0;;
sbit IN3=P0^3;
sbit hw1=P1^0;
sbit hw2=P1^1;
sbit hw3=P1^2;
//sbit hw4=P1^3;
uchar PWM1=0 ; //**右邊電機的占空比**//
uchar PWM2=0 ; //**左邊電機的占空比**//
uchar num=0; //**定時器中斷計數器**//
uchar flag;
void init()
TMOD=0x01;
TH0=(65536-50)/256;
TL0=(65536-50)%256;
EA=1;
ET0=1;
TR0=1;
IN1=0;
IN2=0;
IN3=0;
IN4=0;
init();
if(hw1||hw2||hw3/*||hw4*/)//如果檢測到信號
if(hw1&&hw2&&hw3/*&&hw4*/)
ENA=0;
ENB=0;
if(hw1&&!hw2&&!hw3/*&&!hw4*/)
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=0;
PWM2=15;
flag=1;
if(!hw1&&hw2&&!hw3/*&&!hw4*/)
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=0;
PWM2=13;
flag=2;
if(!hw1&&!hw2&&hw3/*&&!hw4*/)
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=13;
PWM2=0;
flag=3;
if(!hw1&&!hw2&&!hw3/*&&hw4*/)
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=15;
PWM2=0;
flag=4;
else //如果檢測不到信號
switch(flag)
case 1:
// IN1=1;
// IN2=0;
// IN3=1;
// IN4=0;
// PWM1=10;
// PWM2=5;
IN1=0;
IN2=1;
IN3=1;
IN4=0;
PWM1=12;
PWM2=12;
//flag=0;
} break;
case 2:
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=8;
PWM2=8;
flag=0;
} break;
case 3:
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=8;
PWM2=8;
flag=0;
} break;
case 4:
IN1=1;
IN2=0;
IN3=0;
IN4=1;
PWM1=12;
PWM2=12;
// flag=0;
} break;
default:
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=12;
PWM2=12;
void timer0() interrupt 1
TH0=(65536-50)/256;
TL0=(65536-50)%256;
num++;
if(num>=40)num=0;
if(num<PWM1)ENA=1;
else ENA=0;
if(num<PWM2)ENB=1;
else ENB=0;
1986654946
2018-11-18 23:20
這是硬件pwm?
