求助,剛才發(fā)的PM2.5檢測(cè)儀發(fā)現(xiàn)硬件沒問題,大家能看看是軟件的問題嗎?
duzeshuai
時(shí)間:
2017-5-6 22:00
#include<reg52.h>
void senddata(uchar dat);
uchar cal [7]= {0};// cal[0]:起始位 0xAA
// cal[1] : Vout(H)
// cal[2] : Vout(L)
// cal[3] : Vref(H)
// cal[4] : Vref(L)
// cal[5] : 校驗(yàn)位
// cal[6] : 結(jié)束位 OxFF
float Vo;
int i=0;
sbit rs=P1^0;
sbit lcden=P2^5;
sbit rw=P1^1;
sbit voice=P2^3;
sbit light=P2^2;
uchar buf,sum,count;
uchar num,TV,a,b,c;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
rs=0;
rw=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar date)
rs=1;
rw=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
lcden=0; //使能端為低電平
write_com(0x38);
/*顯示模式設(shè)置 00111000 設(shè)置16*2顯示 5*7點(diǎn)陣 8位數(shù)據(jù)接口*/
write_com(0x0f);
/*顯示開關(guān)及光標(biāo)設(shè)置 00001DCB
D=1,開顯示 D=0, 關(guān)顯示
C=1,顯示光標(biāo) C=0,不顯示光標(biāo)
B=1,光標(biāo)閃爍 B=0,光標(biāo)不閃爍*/
write_com(0x06);//地址指針自動(dòng)+1且光標(biāo)+1,寫字符屏幕不會(huì)移動(dòng)
write_com(0x01);
write_com(0x80);
write_data ('P');
write_com (0x81);
write_data ('M');
write_com (0x82);
write_data ('2');
write_com (0x83);
write_data ('.');
write_com (0x84);
write_data ('5');
write_com (0x85);
write_data (':');
write_com (0xcb);
write_data ('m');
write_com (0xcc);
write_data ('g');
write_com (0xcd);
write_data ('/');
write_com (0xce);
write_data ('m');
write_com (0xcf);
write_data ('3');
void warn()
if (num>=200)
voice=0;
light=0;
init();
SCON=0x50; //設(shè)定串口工作方式
PCON=0x00; //波特章不倍增
TMOD=0x20; //定時(shí)器1工作于8位自動(dòng)重載橫式,用于產(chǎn)生波特率
EA=1;
ES = 1; //允許串口中斷
TL0=0x80;
TH0=0xFB;
TR0=1;
num=TV;
a= TV /100+0x30;
TV %=100;
b= TV /10+0x30;
TV %=10;
c= TV +0x30;
write_com (0x88);
write_data (a);
write_com (0x89);
write_data (b);
write_com (0x8a);
write_data (c);
//warn();
while(1);
void serial() interrupt 4
ES = 0; //關(guān)閉串行中斷
RI = 0; //清除串行接受標(biāo)志位
buf = SBUF; //從串口緩沖區(qū)取得數(shù)據(jù)
senddata(buf);
ES = 1; //允許串口中斷
{if(dat==170) //判斷起始位 OxAA, (0xAA==l70〉
i=0;
cal[i]=dat;
i=i+1;
cal[i]=dat;
if(i==6)
sum= cal[1]+cal[2]+cal[3]+cal[4];//sum=Vout(M)+Vout(L)+Vref(M)+Vref(L)
if (sum == cal [5] && cal[6]==255) //sum與校驗(yàn) 相同 &&最后一位是 OxFF 結(jié)束位
for (i=0; i <=6; i++) //此處for循環(huán)是顯示出所有數(shù)據(jù),即cal [7]中的數(shù)據(jù)
SBUF=cal[i];
while(!TI);
TI=0;
Vo=(cal[1]*256+cal[2])/2048*5;
TV=3000* Vo;
