基于51單片機定時器的1602液晶顯示器時鐘顯示(帶年月日)
2597617987
2017-3-28 16:13
基于51單片機定時器的1602液晶顯示器時鐘顯示(帶年月日)。
下載:
基于51單片機定時器的1602液晶顯示器時鐘顯示(帶年月日).doc
(74 KB, 下載次數: 117)
2017-3-28 16:13 上傳
#include<reg52.h>
uchar a,count,S1num,xqnum;
char yue,ri,shi,fen,miao;
int nian;
sbit lcdrs=P2^5;
sbit lcdrw=P2^4;
sbit lcden=P2^3;
sbit S1=P3^0; //定義鍵——進入設置
sbit S2=P3^1; //定義鍵——增大
sbit S3=P3^2; //定義鍵——減小
sbit S4=P3^3; //定義鍵——退出設置
uchar code table0[]="2014-08-13 WED";
uchar code table1[]="00:00:00";
uchar code xingqi[][3]={"MON","TUE","WED","THU","FRI","SAT","SUN"};
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
1602液晶顯示器模塊
sbit lcdrs=P2^5;
sbit lcdrw=P2^4;
sbit lcden=P2^3;
void write_com(uchar com) //液晶寫指令
lcdrw=0;
lcdrs=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar dat) //液晶寫數據
lcdrw=0;
lcdrs=1;
P0=dat;
delay(5);
lcden=1;
delay(5);
lcden=0;
年月日寫入1602函數
void write_sfm(uchar add,uchar dat) //寫時分秒函數
uchar shi,ge;
shi=dat/10;
ge=dat%10;
write_com(0x80+0x40+add);
write_data(0x30+shi);
write_data(0x30+ge);
void write_yr(uchar add,uchar dat) //寫月日函數
uchar shi,ge;
shi=dat/10;
ge=dat%10;
write_com(0x80+add);
void write_nian(uchar add,uint dat) //寫年函數
uint qian,bai,shi,ge;
qian=dat/1000;
bai=dat%1000/100;
shi=dat%100/10;
ge=dat%10;
write_data(0x30+qian);
write_data(0x30+bai);
初始化
void init_lcd() //液晶初始化
lcden=0;
nian=2014;
yue=8;
ri=13;
shi=0; //初始shi、fen、miao
fen=0;
miao=0;
write_com(0x38); //設置16x2顯示,5x7點陣,8位數據口
write_com(0x0c); //設置開顯示,不顯示光標
write_com(0x06); //寫一個字符后地址指針加1
write_com(0x01); //顯示清0,數據指針清0
void init() //初始化函數
init_lcd(); //液晶初始化
write_com(0x80); //設置顯示初始坐標
for(a=0;a<14;a++) //顯示年月日初始值
write_data(table0[a]);
delay(5);
write_com(0x80+0x40); //設置顯示初始坐標
for(a=0;a<8;a++) //顯示時分秒初始值
write_data(table1[a]);
delay(5);
write_nian(0,nian);
write_sfm(6,miao); //分別將shi、fen、miao送去液晶顯示
write_sfm(3,fen);
write_sfm(0,shi);
count=0;
xqnum=0;
S1num=0; //初始化全局變量count
TMOD=0x01; //設置定時器0工作模式1
TH0=(65535-50000)/256; //定時器裝初始值
TL0=(65535-50000)%256;
EA=1; //開總中斷
ET0=1; //開定時器0中斷
TR0=1; //啟動定時器0
獨立鍵盤
獨立鍵盤已接地
void keyscan()
if(S1==0)
delay(5); //確認定義鍵被按下
if(S1==0)
S1num++; //定義鍵S1按下次數記錄
while(!S1); //釋放按鍵確認
if(S1num==1) //S1按下一次時
TR0=0; //關閉定時器
write_com(0xc0+7); //光標定位到秒位置
write_com(0x0f); //光標閃爍
if(S1num==2) //S1按下兩次時
write_com(0xc0+4); //光標定位到分位置
if(S1num==3) //S1按下三次時
write_com(0xc0+1); //光標定位到時位置
if(S1num==4) //S1按下四次時
write_com(0x80+13); //光標定位到星期位置
if(S1num==5) //S1按下五次時
write_com(0x80+9); //光標定位到日位置
if(S1num==6) //S1按下六次時
write_com(0x80+6); //光標定位到月位置
if(S1num==7) //S1按下七次時
write_com(0x80+3); //光標定位到年位置
if(S1num==8) //S1按下八次時
S1num=0; //S1記錄按鍵次數清零
TR0=1; //開啟定時器
write_com(0x0c); //取消光標閃爍
if(S1num!=0) //只有定義鍵按下后S2、S3、S4才有效
if(S2==0)
delay(5); //防抖
if(S2==0) //確認按鍵被按下
while(!S2); //釋放按鍵確認
miao++; //調整秒加1
if(miao==60) //滿60清零
miao=0;
write_sfm(6,miao); //每調節一次送液晶顯示一次
write_com(0x80+0x40+6); //顯示位置重新回到調節處
fen++; //調整分加1
if(fen==60)
fen=0;
write_sfm(3,fen);
write_com(0x80+0x40+3);
shi++; //調整時加1
if(shi==24)
shi=0;
write_sfm(0,shi);
if(S1num==4) //星期加調整
xqnum++;
if(xqnum==7)
xqnum=0;
write_com(0x80+0x0b);
for(a=0;a<3;a++)
write_data(xingqi[xqnum][a]);
delay(5);
if(S1num==5) //日加調整
ri++;
if(yue==2)
if(nian%400==0)
if(ri==30)
ri=1;
if(nian%400!=0)
if(ri==29)
ri=1;
else if(yue<=7)
if(yue%2==0&yue!=2)
if(ri==31)
ri=1;
else if(yue%2!=0&yue!=2)
if(ri==32)
ri=1;
else if(yue>=8)
if(yue%2==0)
if(ri==32)
ri=1;
else if(yue%2!=0)
if(ri==31)
ri=1;
write_yr(8,ri);
if(S1num==6) //月加調整
yue++;
if(yue==13)
yue=1;
write_yr(5,yue);
if(S1num==7) //年加調整
nian++;
if(nian==2019)
nian=2014;
write_nian(0,nian);
if(S3==0)
delay(5);
if(S3==0) //確認按鍵被按下
while(!S3);
if(S1num==1)
miao--; //調整秒減1
if(miao==-1) //減到00后再減重新設置為59
miao=59;
write_sfm(6,miao);
if(S1num==2)
fen--; //調整分減1
if(fen==-1)
fen=59;
write_sfm(3,fen);
if(S1num==3)
shi--; //調整時減1
if(shi==-1)
shi=23;
write_sfm(0,shi);
if(S1num==4)
xqnum--; //調整星期減一
if(xqnum==-1)
xqnum=6;
for(a=0;a<3;a++)
delay(5);
if(S1num==5) //調整日
ri--;
if(yue==2)
if(nian%400==0)
if(ri==0)
ri=29;
if(nian%400!=0)
if(ri==0)
ri=28;
else if(yue<=7)
if(yue%2==0&yue!=2)
if(ri==0)
ri=30;
if(ri==0)
ri=31;
else if(yue>=8)
if(yue%2==0)
if(ri==0)
ri=31;
else if(yue%2!=0)
if(ri==0)
ri=30;
write_yr(8,ri);
if(S1num==6) //調整月
yue--;
if(yue==0)
yue=12;
write_yr(5,yue);
if(S1num==7) //調整年
nian--;
if(nian==2013)
nian=2018;
write_nian(0,nian);
if(S4==0) //退出設置、開啟中斷
delay(5);
if(S4==0)
S1num=0;
TR0=1;
write_com(0x0c);
定時器0
void timer0() interrupt 1 //定時器0中斷服務程序
TH0=(65535-50000)/256; //重裝定時器初始值
count++; //中斷次數累加
if(count==20) //20次50毫秒即一秒
count=0;
miao++;
if(miao==60) //秒加到60時分進位
miao=0;
fen++;
if(fen==60) //分加到60時時進位
fen=0;
shi++;
if(shi==24) //時加到24時清0
shi=0;
xqnum++;
ri++;
if(yue==2) //如果是二月
if(nian%400==0) //閏年判斷
if(ri==30)
ri=1;
yue++;
write_yr(5,yue);
if(nian%400!=0) //平年判斷
if(ri==29)
ri=1;
yue++;
write_yr(5,yue);
else if(yue<=7&yue!=2) //一月到七月
if(yue%2==0) //偶數月(除二月)
if(ri==31)
ri=1;
yue++;
else if(yue%2!=0) //奇數月
if(ri==32)
ri=1;
yue++;
write_yr(5,yue);
else if(yue>=8) //八月到12月
if(ri==32)
ri=1;
yue++;
if(yue==13) //如果判斷月份為12月,則加一后重新定義月份為1
yue=1;
nian++;
write_nian(0,nian);
write_yr(5,yue);
if(ri==31)
ri=1;
yue++;
write_yr(5,yue);
write_yr(8,ri);
if(xqnum==7) //星期寫入
xqnum=0;
for(a=0;a<3;a++)
delay(5);
write_sfm(0,shi); //重新寫入數據
write_sfm(3,fen); //重新寫入數據
write_sfm(6,miao); //重新寫入數據
主函數
init();
keyscan(); //不停的檢測按鍵是否被按下
skay
2017-11-23 20:57
1602顯示器不顯示是怎么回事?放在單片機上就顯示時間,代碼應該沒問題,但放在自己焊的電路板上就不顯示了,求大神指教>_<
lzDestiny
2018-10-6 11:42
能說一下這幾個開關在protues中應該怎么畫么
ptlantu
2018-10-6 14:23
lzDestiny 發表于 2018-10-6 11:42
sbit lcdrs=P2^5;
sbit lcdrw=P2^4;
sbit lcden=P2^3;
看程序腳定義就知道畫啦
FGH116
2018-10-11 15:15
謝謝分享。。。。。。。。。。。。。。
趙晨杰
2019-5-18 22:29
樓主,仿真的時候液晶屏不顯示,請問下您貼在這的代碼是沒錯的么?我編譯也有一個警告
