51單片機(jī)數(shù)控電源 tlc5615+tlc1543程序
[打印本頁(yè)]
19960601
時(shí)間:
2017-3-21 19:18
數(shù)控電源,51單片機(jī)+tlc5615+tlc1543
源程序:
/*最大電流為6A,最大電壓為40V*/
#include<reg52.h>
sbit sclk5615=P1^0; /*dac tlc5615串行時(shí)鐘*/
sbit din5615=P1^1; /*dac tlc5615串行數(shù)據(jù)輸入*/
sbit cs5615=P1^2; /*dac tlc5615片選*/
sbit dout5615=P1^3; /*dac tlc5615串行數(shù)據(jù)輸出*/
sbit eoc1543=P3^0;
sbit sclk1543=P3^1;
sbit addr1543=P3^2;
sbit dout1543=P3^3;
sbit cs1543=P3^4;
void Delayms(unsigned int t) //延時(shí)毫秒函數(shù):
unsigned int x,y;
for(x=t;x>0;x--)
for(y=120;y>0;y--);
void TLC1543_init(void)
cs1543=1;
sclk1543=0;
unsigned int ReadADC_TLC1543(unsigned char ch)
unsigned char temp;
unsigned int adc_value=0;
ch<<=4;
cs1543=0;
for(temp=0;temp<10;temp++) // 將判斷語(yǔ)句改為 temp<12
{ // 程序可移殖至 TLC2543.
adc_value<<=1;
ch<<=1;
addr1543=CY;
if(dout1543)
adc_value+=1;
sclk1543=1;
Delayms(1);
sclk1543=0;
cs1543=1;
return adc_value;
void WriteTLC5615(unsigned int wdata) //寫(xiě)TLC5615數(shù)據(jù)函數(shù):
unsigned char i;
cs5615=0; //片選使能
wdata<<=2; //將數(shù)據(jù)左移兩位,補(bǔ)兩位擴(kuò)展位,組成12位數(shù)據(jù)寫(xiě)入
for(i=0;i<12;i++) //寫(xiě)入12位數(shù)據(jù)
sclk5615=0;
din5615=(wdata&0x0800)?1:0; //取出最高位(第11位)寫(xiě)入
sclk5615=1; //上升沿送數(shù)據(jù)
wdata<<=1; //下一位移到最高位
cs5615=1; //片選禁止
float get_average(unsigned char ch,unsigned char time)
unsigned char i;
float v;
v=ReadADC_TLC1543(ch);
for(i=0;i<time;i++)
v+=v;
Delayms(5);
return v/time;
/*unsigned char KEY_Scan()
unsigned char temp=0;
unsigned char com=0x55,com1=0,com2=0;
P2=0xf0;
if(P2!=0xf0)
com1=P2;
P2=0x0f;
com2=P2;
P2=0xf0;
while(P2!=0xf0);
temp=com1|com2;
switch(temp)
case 0xee:com=0;break;
case 0xed:com=1;break;
case 0xeb:com=2;break;
case 0xe7:com=3;break;
case 0xde:com=4;break;
case 0xdd:com=5;break;
case 0xdb:com=6;break;
case 0xd7:com=7;break;
case 0xbe:com=8;break;
case 0xbd:com=9;break;
case 0xbb:com=10;break;
case 0xb7:com=11;break;
case 0x7e:com=12;break;
case 0x7d:com=13;break;
case 0x7b:com=14;break;
case 0x77:com=15;break;
return(com);
void main(void)
float dat1,dat2,volt,current;
TLC1543_init();
WriteTLC5615(100);/*向dac寫(xiě)入數(shù)據(jù)*/
dat1=get_average(0,10);/*通道0測(cè)電壓*/
dat2=get_average(1,10);/*通道1測(cè)電流*/
volt=dat1*8;/*最大電壓為40v,分壓為5v,分壓倍數(shù)為8倍*/
current=dat2*6/5;/*最大電流6A,采樣電阻為1mΩ,采樣電阻上面最大電壓為6mv,差分放大100倍,即最大電壓為6v,分壓電阻分壓后變成5v*/
…………余下代碼請(qǐng)下載附件…………
(43.5 KB, 下載次數(shù): 66)
2017-3-21 19:47 上傳
下載:
電源.zip
(30.14 KB, 下載次數(shù): 62)
2017-3-21 19:17 上傳
點(diǎn)擊文件名下載附件
963373449
時(shí)間:
2018-3-23 19:54
大神,有proteus仿真圖嗎?多謝
jiangming1313
時(shí)間:
2018-6-16 20:42
有沒(méi)有電路圖
