經(jīng)典交通燈程序 只為學(xué)習(xí) 無任何意圖
[打印本頁(yè)]
山師工程師
時(shí)間:
2016-12-16 15:00
#include <reg52.h>
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char code LedChar[] = { //數(shù)碼管顯示字符轉(zhuǎn)換表
0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
unsigned char LedBuff[7] = { //數(shù)碼管+獨(dú)立LED顯示緩沖區(qū)
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
bit flag1s = 1; //1秒定時(shí)標(biāo)志
unsigned char T0RH = 0; //T0重載值的高字節(jié)
unsigned char T0RL = 0; //T0重載值的低字節(jié)
void ConfigTimer0(unsigned int ms);
void TrafficLight();
EA = 1; //開總中斷
ENLED = 0; //使能數(shù)碼管和LED
ADDR3 = 1;
ConfigTimer0(1); //配置T0定時(shí)1ms
while (1)
if (flag1s) //每秒執(zhí)行一次交通燈刷新
flag1s = 0;
TrafficLight();
/* 配置并啟動(dòng)T0,ms-T0定時(shí)時(shí)間 */
unsigned long tmp; //臨時(shí)變量
tmp = 11059200 / 12; //定時(shí)器計(jì)數(shù)頻率
tmp = (tmp * ms) / 1000; //計(jì)算所需的計(jì)數(shù)值
tmp = 65536 - tmp; //計(jì)算定時(shí)器重載值
tmp = tmp + 13; //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
T0RH = (unsigned char)(tmp>>8); //定時(shí)器重載值拆分為高低字節(jié)
T0RL = (unsigned char)tmp;
TMOD &= 0xF0; //清零T0的控制位
TMOD |= 0x01; //配置T0為模式1
TH0 = T0RH; //加載T0重載值
TL0 = T0RL;
ET0 = 1; //使能T0中斷
TR0 = 1; //啟動(dòng)T0
/* 交通燈顯示刷新函數(shù) */
void TrafficLight()
static unsigned char color = 2; //顏色索引:0-綠色/1-黃色/2-紅色
static unsigned char timer = 0; //倒計(jì)時(shí)定時(shí)器
if (timer == 0) //倒計(jì)時(shí)到0時(shí),切換交通燈
switch (color) //LED8/9代表綠燈,LED5/6代表黃燈,LED2/3代表紅燈
case 0: //切換到黃色,亮3秒
color = 1;
timer = 2;
LedBuff[6] = 0xE7;
break;
case 1: //切換到紅色,亮30秒
color = 2;
timer = 29;
LedBuff[6] = 0xFC;
break;
case 2: //切換到綠色,亮40秒
color = 0;
timer = 39;
LedBuff[6] = 0x3F;
break;
default:
break;
else //倒計(jì)時(shí)未到0時(shí),遞減其計(jì)數(shù)值
timer--;
LedBuff[0] = LedChar[timer%10]; //倒計(jì)時(shí)數(shù)值個(gè)位顯示
LedBuff[1] = LedChar[timer/10]; //倒計(jì)時(shí)數(shù)值十位顯示
/* LED動(dòng)態(tài)掃描刷新函數(shù),需在定時(shí)中斷中調(diào)用 */
void LedScan()
static unsigned char i = 0;
P0 = 0xFF;
P1 = (P1 & 0xF8) | i;
P0 = LedBuff[i];
if (i < 6)
i++;
i = 0;
/* T0中斷服務(wù)函數(shù),完成LED掃描和秒定時(shí) */
void InterruptTimer0() interrupt 1
static unsigned int tmr1s = 0;
TH0 = T0RH;
TL0 = T0RL;
LedScan();
tmr1s++;
if (tmr1s >= 1000)
tmr1s = 0;
flag1s = 1;
