16按鍵數字顯示程序
唐長老
2016-12-11 21:29
16按鍵數字顯示程序
(99.96 KB, 下載次數: 44)
16按鍵Protues原理圖
2016-12-11 21:28 上傳
#include <regx51.h>
void delayms(unsigned int i)
unsigned char k;
while(i--)
for(k=0;k<120;k++);
char scan_key ();
unsigned char led[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
unsigned char i;
P1=0xff;
P0=0xff;
i=scan_key();
if(i==-1)continue;
P1=led[i];
char scan_key ()
char i, temp,m,n;
bit find=0;
P2=0xf0;
i=P0;
i&0x0f;
if(i!=0x0f)
delayms(10);
i=P0;
i&0x0f;
if(i!=0x0f)
for(i=0;i<4;i++)
P2=0xfe<<i;
temp=~P0;
temp=temp&0x0f;
if(temp!=0x00)
m=i;
find=1;
switch(temp)
case 0x01:n=0;break;
case 0x02:n=1;break;
case 0x04:n=2;break;
case 0x08:n=3;break;
default:break;
break;
if(find==0) return -1;
else return(n*4+m);
