標(biāo)題: 各位大神,能幫我畫一下流程圖,謝謝大神們 [打印本頁]
作者: 哈哈一笑    時(shí)間: 2016-11-21 21:00
#include "reg52.h"
sbit IN = P1^0;
sbit LED = P2^6;
sbit RELAY=P2^0;
unsigned char   TimeDelay=0;  //5秒鐘自動(dòng)停止
void TimerInit(void);
void Delay_1ms(unsigned int i)
        unsigned int x,j;
        for(j=0;j<i;j++)
        for(x=0;x<123;x++);
void IN_Check(void)
  if(IN==0)
    Delay_1ms(10);
    if(IN==0)
      TimeDelay=3;
void RelayControl(void)
  if(TimeDelay>0)
    RELAY=0;
    LED=0;
    RELAY=1;
    LED=1;
void main(void)
  TimerInit();
    IN_Check();
    RelayControl();
void Timer_ISR(void)  interrupt 1
  static unsigned char  T50MS=0;
  TH0 = (65536-30000)/256;
  TL0 = (65536-30000)%256;
  if(TimeDelay>0)
     T50MS++;
     if(T50MS>=20)
       T50MS=0;
       if(TimeDelay>0)
         TimeDelay--;
  TMOD = 0x01;
  TH0 = (65536-50000)/256;
  TL0 = (65536-50000)%256;
  ET0 = 1;
  TR0 = 1;
  EA = 1;
作者: hudeli22    時(shí)間: 2016-11-22 16:12
我QQ1304223376發(fā)你
作者: abcdmby    時(shí)間: 2016-11-22 19:41
圍觀。。。。
