51單片機控制舵機 總框
c505085670
2016-11-19 20:43
51單片機控制舵機 總框
大概寫了一下控制程序 希望對你們有幫助
tpyedef i8 signed char
tpyedef u8 unsigned char
tpyedef i16 signed short int
tpyedef u16 unsigned short int
tpyedef i32 signed long int
tpyedef u32 unsigned long int
#define ELEVEL_LOW 0 //低電平
#define ELEVEL_HIGH 1 //高電平
#define TIMER_INIT 10 //定時器初始時間 單位US
#define STRENG_MINTIME 500 //舵機最小角度時間 0.5MS
#define STRENG_MAXTIME 2500 //舵機最大角度時間 2.5MS
#define STRENG_TIMERPRO 20000 //舵機周期 20MS
#define STRENG_MINANGLE 0 //最小角度
#define STRENG_MAXANGLE 185 //最大角度
#define IO_STRENG10 // PORT引腳
#define IO_STRENG20
#define IO_STRENG30
#define IO_STRENG40
#define IO_STRENG50
#define IO_STRENG60
#define IO_STRENG11
#define IO_STRENG21
#define IO_STRENG31
#define IO_STRENG41
#define IO_STRENG51
#define IO_STRENG61
u16 TimerCount = 0; //計數值
float StrEngAccu = 0; //舵機精度
u16 StrEngZeroAngle = 0; //零度對應的時間
void StrEngTimer0_Init(void) //定時器初始化
StrEngAccu = STRENG_MAXANGLE/((STRENG_MAXTIME - STRENG_MINTIME)/TIMER_INIT);
StrEngZeroAngle = STRENG_TIMEUS/TimerInitValue;
TH0 = (65535 - TIMER_INIT)/256;
TL0 = (65535 - TIMER_INIT);
EA = 1;
ET0 = 1;
TR0 = 1;
void STRENG_AngleControl(u8 angle,sbit *io)// 0-185角度控制
float regdat = 0;
u16 angletime = 0;
regdat = (float)angle;
angletime = (u16)(regdat/StrEngAccu) + (STRENG_MINTIME/TIMER_INIT);
if(angletime > TimerCount)
*io = ELEVEL_HIGH;
*io = ELEVEL_LOW;
void timer0(void) interrupt 0
TimerCount ++;
TH0 = (65535 - TIMER_INIT)/256;;
if(TimerCount > (STRENG_TIMERPRO/TIMER_INIT))
TimerCount = 0;
