標題: 求助:PT2259電子音量IC尋不到地址。有玩過的大神指導下(附程序) [打印本頁]
作者: Taurus乀    時間: 2016-7-18 22:34
89c52外掛24c02跟一個PT2259;
程序就發送一個地址碼,接收ACK信號,并把接收到的ACK信號用液晶顯示出來;
發送 0x50 24c02有應答信號;
但我按PT2259資料寫的四個地址:0x88;0x89;0x8D;0x8C  都測試一邊都沒有收到應答信號!
這是什么回事啊?是不是24C02跟PT2259的尋址方式不同?
程序:
LCD1206.C
#include <reg52.h>
#define LCD1602_DB  P0
sbit LCD1602_RS = P1^2;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E  = P1^0;
/* 等待液晶準備好 */
void LcdWaitReady()
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do {
        LCD1602_E = 1;
        sta = LCD1602_DB; //讀取狀態字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重復檢測直到其等于0為止
/* 向LCD1602液晶寫入一字節命令,cmd-待寫入命令值 */
void LcdWriteCmd(unsigned char cmd)
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 向LCD1602液晶寫入一字節數據,dat-待寫入數據值 */
void LcdWriteDat(unsigned char dat)
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_DB = dat;
    LCD1602_E  = 1;
    LCD1602_E  = 0;
/* 設置顯示RAM起始地址,亦即光標位置,(x,y)-對應屏幕上的字符坐標 */
void LcdSetCursor(unsigned char x, unsigned char y)
    unsigned char addr;
    if (y == 0)  //由輸入的屏幕坐標計算顯示RAM的地址
        addr = 0x00 + x;  //第一行字符地址從0x00起始
        addr = 0x40 + x;  //第二行字符地址從0x40起始
    LcdWriteCmd(addr | 0x80);  //設置RAM地址
/* 在液晶上顯示字符串,(x,y)-對應屏幕上的起始坐標,str-字符串指針 */
void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str)
    LcdSetCursor(x, y);   //設置起始地址
    while (*str != '\0')  //連續寫入字符串數據,直到檢測到結束符
        LcdWriteDat(*str++);
/* 初始化1602液晶 */
void InitLcd1602()
    LcdWriteCmd(0x38);  //16*2顯示,5*7點陣,8位數據接口
    LcdWriteCmd(0x0C);  //顯示器開,光標關閉
    LcdWriteCmd(0x06);  //文字不動,地址自動+1
    LcdWriteCmd(0x01);  //清屏
main.c
#include <reg52.h>
#include <intrins.h>
#define I2CDelay()  {_nop_();_nop_();_nop_();_nop_();}
sbit I2C_SCL = P3^6;
sbit I2C_SDA = P3^7;
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
bit I2CAddresing(unsigned char addr);
        bit ack = 0;
        unsigned char str[10];
    InitLcd1602();   //初始化液晶
        ack = I2CAddresing(0x88);
        str[0] = '5';
        str[1] = '0';
        str[2] = ':';
        str[3] = (unsigned char)ack + '0';
        str[4] = '\0';
        LcdShowStr(0, 0, str);
        ack = I2CAddresing(0x89);
        str[0] = '6';
        str[1] = '2';
        str[2] = ':';
        str[4] = '\0';
        LcdShowStr(8, 0, str);
    while (1);
void I2CStart()
        I2C_SDA = 1;
        I2C_SCL = 1;
        I2CDelay();
        I2C_SDA = 0;
        I2CDelay();
        I2C_SCL = 0;
void I2CStop()
        I2C_SCL = 0;
        I2C_SDA = 0;
        I2CDelay();
        I2C_SCL = 1;
        I2CDelay();
        I2C_SDA = 1;
        I2CDelay();
bit I2CWrite(unsigned char dat)
        bit ack = 0;
        unsigned char mask;
        for(mask=0x80; mask!=0; mask>>=1)
                if((mask&dat) == 0)
                        I2C_SDA = 0;
                        I2C_SDA = 1;
                I2CDelay();
                I2C_SCL = 1;
                I2CDelay();
                I2C_SCL = 0;
        I2C_SDA = 1;
        I2CDelay();
        I2C_SCL = 1;
        ack = I2C_SDA;
        I2CDelay();
        I2C_SCL = 0;
        return ack;
        bit ack = 0;
        I2CStart();
        ack = I2CWrite(addr << 1);
        I2CStop();
        return ack;
作者: Taurus乀    時間: 2016-7-18 23:51
快來人救命啊!!!
作者: Taurus乀    時間: 2016-7-19 08:02
PT2257跟PT2259是不是不同的兩種東西啊?
那個更好?我看很多人都是在用2257的。
作者: huayangshiboqi    時間: 2016-7-19 08:57
不懂,但頂一個,樓主加油
作者: Taurus乀    時間: 2016-7-19 16:10
huayangshiboqi 發表于 2016-7-19 08:57
不懂,但頂一個,樓主加油
嗯嗯 謝謝哈~
作者: lxa0    時間: 2016-12-19 16:27
建議樓主用pga2311吧
作者: AHJY    時間: 2017-11-24 21:38
樓主解決了嗎?畢業設計得用這個芯片,想參考一下
