| Digi-Key Part Number | Manufacturer | Manufacturer Part Number | Customer Reference | Quantity 1 | Quantity 2 | Quantity 3 | Description | Comments |
| P150GCT-ND | PANASONIC - ECG (VA) | ERJ-3GEYJ151V | 150 OHM | 162 | 0 | 0 | RES 150 OHM 1/10W 5% 0603 SMD | Alternate Packaging Exists |
| P220GCT-ND | PANASONIC - ECG (VA) | ERJ-3GEYJ221V | 220 OHM | 9 | 0 | 0 | RES 220 OHM 1/10W 5% 0603 SMD | Alternate Packaging Exists |
| P1.0KGCT-ND | PANASONIC - ECG (VA) | ERJ-3GEYJ102V | 1 K OHM | 13 | 0 | 0 | RES 1.0K OHM 1/10W 5% 0603 SMD | Alternate Packaging Exists |
| P470GCT-ND | PANASONIC - ECG (VA) | ERJ-3GEYJ471V | 470 OHM | 3 | 0 | 0 | RES 470 OHM 1/10W 5% 0603 SMD | Alternate Packaging Exists |
| P10KGCT-ND | PANASONIC - ECG (VA) | ERJ-3GEYJ103V | 10K OHM | 1 | 0 | 0 | RES 10K OHM 1/10W 5% 0603 SMD | Alternate Packaging Exists |
| 445-6853-1-ND | TDK CORPORATION (VA) | C1608X5R1A106M | 10UF | 2 | 0 | 0 | CAP CER 10UF 10V X5R 20% 0603 | Alternate Packaging Exists |
| 311-1372-1-ND | YAGEO (VA) | CC0603ZRY5V7BB105 | 1UF | 10 | 0 | 0 | CAP CERAMIC 1UF 16V Y5V 0603 | Alternate Packaging Exists |
| AP7333-33SAG-7DICT-ND | DIODES INC (VA) | AP7333-33SAG-7 | AP7333-33 | 1 | 0 | 0 | IC REG LDO 3.3V 0.3A SOT23 | Alternate Packaging Exists |
| DMP3098LDICT-ND | DIODES INC (VA) | DMP3098L-7 | DMP3098L | 3 | 0 | 0 | MOSFET P-CH 30V 3.8A SOT23-3 | Alternate Packaging Exists |
| MMBT2222A-FDICT-ND | DIODES INC (VA) | MMBT2222A-7-F | MMBT2222A | 12 | 0 | 0 | TRANS NPN 40V 350MW SMD SOT23-3 | Alternate Packaging Exists |
| PIC24F08KA101-I/SS-ND | MICROCHIP TECHNOLOGY | PIC24F08KA101-I/SS | PIC24F08KA101 | 1 | 0 | 0 | IC PIC MCU FLASH 8K 20-SSOP | Alternate Packaging Exists |
| P13351SCT-ND | PANASONIC - ECG (VA) | EVQ-Q7GA50 | 4-WAY STICK SWITCH | 1 | 0 | 0 | SWITCH LT MULTI DIRECTION SMD | Alternate Packaging Exists |
| WM4300-ND | MOLEX INC | 22-05-3021 | 2 pin right angle header | 1 | 0 | 0 | CONN HEADER 2POS .100 R/A TIN | |
| WM2011-ND | MOLEX INC | 22-01-2027 | 2 pin connector housing | 1 | 0 | 0 | CONN HOUSING 2POS .100 W/RAMP | |
| WM1114-ND | MOLEX INC | 08-50-0114 | Molex connector terminals | 2 | 0 | 0 | CONN TERM FEMALE 22-30AWG TIN | Alternate Packaging Exists |
477.59 KB, 下載次數(shù): 98, 下載積分: 黑幣 -5
