| A0 | SMB | SMA | No | Top | Straight PCB Mount SMB Jack, keep hole clear of solder | Tyco | 1-1337482-0 | Do Not Insert. Keep clear of solder. | ||
| A1 | SMB | SMA | No | Top | Straight PCB Mount SMB Jack, keep hole clear of solder | Tyco | 1-1337482-0 | Do Not Insert. Keep clear of solder. | ||
| A2 | SMB | SMA | No | Top | Straight PCB Mount SMB Jack, keep hole clear of solder | Tyco | 1-1337482-0 | Do Not Insert. Keep clear of solder. | ||
| A3 | SMB | SMA | No | Top | Straight PCB Mount SMB Jack, keep hole clear of solder | Tyco | 1-1337482-0 | Do Not Insert. Keep clear of solder. | ||
| A4 | SMB | SMA | No | Top | Straight PCB Mount SMB Jack, keep hole clear of solder | Tyco | 1-1337482-0 | Do Not Insert. Keep clear of solder. | ||
| A5 | SMB | DNI | SMA | No | Top | Straight PCB Mount SMB Jack, keep hole clear of solder | Tyco | 1-1337482-0 | Do Not Insert. Keep clear of solder. | |
| A6 | SMB | DNI | SMA | No | Top | Straight PCB Mount SMB Jack, keep hole clear of solder | Tyco | 1-1337482-0 | Do Not Insert. Keep clear of solder. | |
| AIN0 | TESTPOINTS | DNI | TESTPOINT-SMALL | No | Top | Test point, not inserted, keep hole clear of solder | n/a | n/a | Do Not Insert. Keep clear of solder. | |
| AIN1 | TESTPOINTS | DNI | TESTPOINT-SMALL | No | Top | Test point, not inserted, keep hole clear of solder | n/a | n/a | Do Not Insert. Keep clear of solder. | |
| AIN2 | TESTPOINTS | DNI | TESTPOINT-SMALL | No | Top | Test point, not inserted, keep hole clear of solder | n/a | n/a | Do Not Insert. Keep clear of solder. | |
| AIN3 | TESTPOINTS | DNI | TESTPOINT-SMALL | No | Top | Test point, not inserted, keep hole clear of solder | n/a | n/a | Do Not Insert. Keep clear of solder. | |
| AIN4 | TESTPOINTS | DNI | TESTPOINT-SMALL | No | Top | Test point, not inserted, keep hole clear of solder | n/a | n/a | Do Not Insert. Keep clear of solder. | |
| AIN4' | TESTPOINTS | DNI | TESTPOINT-SMALL | No | Top | Test point, not inserted, keep hole clear of solder | n/a | n/a | Do Not Insert. Keep clear of solder. | |
| C1 | CAP | 4.7uF | ±10% | C0603 | Yes | Top | Capacitor ceramic, 6.3V, X5R, 0603 | Murata | GRM188R60J475K | FEC 173-5527 |
| C2 | CAP | 0.1uF | ±10% | C0603 | Yes | Top | Capacitor ceramic, 50V, X7R, 0603 | Murata | GRM188R71H104K | FEC 882-0023 |
| C3 | CAP | 4.7uF | ±10% | C0603 | Yes | Top | Capacitor ceramic, 10V, X5R, 0603 | Kemet | C0603C475K8PACTU | FEC 157-2625 |
| C4 | CAP | 1uF | ±10% | C0805 | Yes | Top | CAPACITOR, 0805, 1UF, 50V, X7R | MURATA | GRM21BR71H105KA12L | FEC 1735541 |
| C5 | CAP | DNI | TBD | C0402 | Yes | Top | Ceramic Capacitor, not inserted, 0402 | n/a | n/a | Do Not Insert |
| C6 | CAP | 1uF | ±10% | C0805 | Yes | Top | CAPACITOR, 0805, 1UF, 50V, X7R | MURATA | GRM21BR71H105KA12L | FEC 1735541 |
| C7 | CAP | DNI | TBD | C0402 | Yes | Bottom | Ceramic Capacitor, not inserted, 0402 | n/a | n/a | Do Not Insert |
| C8 | CAP | DNI | TBD | C0402 | Yes | Top | Ceramic Capacitor, not inserted, 0402 | n/a | n/a | Do Not Insert |
| C9 | CAP | DNI | TBD | C0402 | Yes | Top | Ceramic Capacitor, not inserted, 0402 | n/a | n/a | Do Not Insert |
| C10 | CAP | DNI | TBD | C0402 | Yes | Top | Ceramic Cap XTAL, not inserted, 0402 | n/a | n/a | Do Not Insert |
| C11 | CAP | DNI | TBD | C0402 | Yes | Top | Ceramic Cap XTAL, not inserted, 0402 | n/a | n/a | Do Not Insert |
| C12 | CAP | 0.1uF | ±10% | C0402 | Yes | Top | Capacitor ceramic, 16V, X7R, 0402 | Murata | GRM155R71C104K | FEC 881-9742 |
| C13 | CAP | 0.1uF | ±10% | C0402 | Yes | Top | Capacitor ceramic, 16V, X7R, 0402 | Murata | GRM155R71C104K | FEC 881-9742 |
| C14 | CAP | 0.1uF | ±10% | C0402 | Yes | Top | Capacitor ceramic, 16V, X7R, 0402 | Murata | GRM155R71C104K | FEC 881-9742 |
| C15 | CAP | 1uF | ±10% | C0603 | Yes | Bottom | CAPACITOR, 0603, 1UF, 6.3V | Murata | GRM188R70J105KA01D | FEC 184-5765 |
| C16 | CAP | DNI | TBD | C0402 | Yes | Top | Ceramic Capacitor, not inserted, 0402 | n/a | n/a | Do Not Insert |
| C17 | CAP | 4.7uF | ±10% | C0603 | Yes | Top | Capacitor ceramic, 6.3V, X5R, 0603 | Murata | GRM188R60J475K | FEC 173-5527 |
| C18 | CAP | 0.1uF | ±10% | C0402 | Yes | Top | Capacitor ceramic, 16V, X7R, 0402 | Murata | GRM155R71C104K | FEC 881-9742 |
| C19 | CAP | 270pF | ±5% | C0603 | Yes | Top | Ceramic Capacitor, 50V, C0G/NPO, 0603 | AVX | 06035A271JAT2A | FEC 1734627 |
| C20 | CAP | 0.1uF | ±10% | C0402 | Yes | Bottom | Capacitor ceramic, 16V, X7R, 0402 | Murata | GRM155R71C104K | FEC 881-9742 |
| C21 | CAP | 0.1uF | ±10% | C0402 | Yes | Top | Capacitor ceramic, 16V, X7R, 0402 | Murata | GRM155R71C104K | FEC 881-9742 |
| C22 | CAP | 0.1uF | ±10% | C0402 | Yes | Top | Capacitor ceramic, 16V, X7R, 0402 | Murata | GRM155R71C104K | FEC 881-9742 |
| C23 | CAP | 680pF | ±5% | C0603 | Yes | Top | Ceramic Capacitor, 50V, NPO, 0603 | KEMET | C0603C681J5GACTU | FEC 1414648 |
| C24 | CAP | DNI | TBD | C0402 | Yes | Top | Ceramic Capacitor, not inserted, 0402 | n/a | n/a | Do Not Insert |
| C25 | CAP | DNI | TBD | C0603 | Yes | Top | Ceramic Capacitor, not inserted, 0402 | n/a | n/a | Do Not Insert |
| C26 | CAP | 680pF | ±5% | C0603 | Yes | Top | Ceramic Capacitor, 50V, NPO, 0603 | Kemet | C0603C681J5GACTU | FEC 1414648 |
| C27 | CAP | 270pF | ±5% | C0603 | Yes | Top | Ceramic Capacitor, 50V, C0G/NPO, 0603 | AVX | 06035A271JAT2A | FEC 1734627 |
| C28 | CAP | 270pF | ±5% | C0603 | Yes | Top | Ceramic Capacitor, 50V, C0G/NPO, 0603 | AVX | 06035A271JAT2A | FEC 1734627 |
| C29 | CAP | 4.7uF | ±10% | C0603 | Yes | Top | Capacitor ceramic, 6.3V, X5R, 0603 | Murata | GRM188R60J475K | FEC 173-5527 |
| C30 | CAP | 4.7uF | ±10% | C0603 | Yes | Top | Capacitor ceramic, 6.3V, X5R, 0603 | Murata | GRM188R60J475K | FEC 173-5527 |
| C31 | CAP | DNI | ±10% | C0402 | Yes | Top | Capacitor ceramic, 16V, X7R, 0402 | Murata | GRM155R71C104K | Do Not Insert |
| C32 | CAP | 10uF | tba | 1210 | Yes | Top | Capacitor ceramic, 50V, X5R, 1210 | Murata | GRM32ER61H106K | FEC 184-5764 |
| C33 | CAP | 0.1uF | ±10% | C0402 | Yes | Top | Capacitor ceramic, 16V, X7R, 0402 | Murata | GRM155R71C104K | FEC 881-9742 |
| C34 | CAP | 0.1uF | ±10% | C0402 | Yes | Bottom | Capacitor ceramic, 16V, X7R, 0402 | Murata | GRM155R71C104K | FEC 881-9742 |
394.44 KB, 下載次數: 11, 下載積分: 黑幣 -5
32.47 KB, 下載次數: 7, 下載積分: 黑幣 -5
1.45 MB, 下載次數: 12, 下載積分: 黑幣 -5
2.06 MB, 下載次數: 11, 下載積分: 黑幣 -5
