標題: stm32版的mwc源碼 [打印本頁]
作者: 藍吻君    時間: 2016-6-18 21:28
標題: stm32版的mwc源碼
#include "board.h"
#include "mw.h"
#ifndef sq
#define sq(x) ((x)*(x))
#endif
static void GPS_NewData(uint16_t c);
static void GPS_set_pids(void);
void gpsInit(uint32_t baudrate)
    GPS_set_pids();
    uart2Init(baudrate, GPS_NewData);
    // catch some GPS frames. TODO check this
    delay(500);
    if (GPS_Present)
        sensorsSet(SENSOR_GPS);
* Multiwii GPS code - revision: 851
#define POSHOLD_IMAX           20       // degrees
#define POSHOLD_RATE_IMAX      20       // degrees
#define NAV_IMAX               20       // degrees
/* GPS navigation can control the heading */
#define NAV_TAIL_FIRST             0    // true - copter comes in with tail first
#define NAV_SET_TAKEOFF_HEADING    1    // true - when copter arrives to home position it rotates it's head to takeoff direction
#define GPS_FILTERING              1    // add a 5 element moving average filter to GPS coordinates, helps eliminate gps noise but adds latency
#define GPS_LOW_SPEED_D_FILTER     1    // below .5m/s speed ignore D term for POSHOLD_RATE, theoretically this also removed D term induced noise
static bool check_missed_wp(void);
static void GPS_distance_cm_bearing(int32_t * lat1, int32_t * lon1, int32_t * lat2, int32_t * lon2, uint32_t * dist, int32_t * bearing);
//static void GPS_distance(int32_t lat1, int32_t lon1, int32_t lat2, int32_t lon2, uint16_t* dist, int16_t* bearing);
static void GPS_calc_longitude_scaling(int32_t lat);
static void GPS_calc_velocity(void);
static void GPS_calc_location_error(int32_t * target_lat, int32_t * target_lng, int32_t * gps_lat, int32_t * gps_lng);
static void GPS_calc_poshold(void);
static void GPS_calc_nav_rate(int max_speed);
static void GPS_update_crosstrack(void);
static bool GPS_newFrame(char c);
static int16_t GPS_calc_desired_speed(int16_t max_speed, bool _slow);
int32_t wrap_18000(int32_t error);
static int32_t wrap_36000(int32_t angle);
typedef struct {
    float kP;
    float kI;
    float kD;
    float Imax;
} PID_PARAM;
static PID_PARAM posholdPID;
static PID_PARAM poshold_ratePID;
static PID_PARAM navPID;
// AC_PID.h & AC_PID.cpp
typedef struct {
    float _integrator;          ///< integrator value
    int32_t _last_input;        ///< last input for derivative
    float _last_derivative;     ///< last derivative for low-pass filter
    float _output;
    float _derivative;
} AC_PID;
static float AC_PID_get_integrator(AC_PID * ac_pid)
    return ac_pid->_integrator;
static void AC_PID_set_integrator(AC_PID * ac_pid, float i)
    ac_pid->_integrator = i;
/// Low pass filter cut frequency for derivative calculation.
// static const float ac_pid_filter = 1.0f / (2.0f * M_PI * (float)cfg.gps_lpf); // Set to  "1 / ( 2 * PI * f_cut )"
#define AC_PID_FILTER       (1.0f / (2.0f * M_PI * (float)cfg.gps_lpf))
/// Iterate the PID, return the new control value
/// Positive error produces positive output.
/// @param error        The measured error value
/// @param dt           The time delta in milliseconds (note
///                                     that update interval cannot be more
///                                     than 65.535 seconds due to limited range
///                                     of the data type).
/// @param scaler       An arbitrary scale factor
/// @returns            The updated control output.
static int32_t AC_PID_get_p(AC_PID * ac_pid, int32_t error, PID_PARAM * pid)
    return (float) error *pid->kP;
static int32_t AC_PID_get_i(AC_PID * ac_pid, int32_t error, float *dt, PID_PARAM * pid)
    ac_pid->_integrator += ((float) error * pid->kI) * *dt;
    if (ac_pid->_integrator < -pid->Imax) {
        ac_pid->_integrator = -pid->Imax;
    } else if (ac_pid->_integrator > pid->Imax) {
        ac_pid->_integrator = pid->Imax;
static int32_t AC_PID_get_d(AC_PID * ac_pid, int32_t input, float *dt, PID_PARAM * pid)
    ac_pid->_derivative = (input - ac_pid->_last_input) / *dt;
    // discrete low pass filter, cuts out the
    // high frequency noise that can drive the controller crazy
    ac_pid->_derivative = ac_pid->_last_derivative + (*dt / (AC_PID_FILTER + *dt)) * (ac_pid->_derivative - ac_pid->_last_derivative);
    // update state
    ac_pid->_last_input = input;
    ac_pid->_last_derivative = ac_pid->_derivative;
    // add in derivative component
    return pid->kD * ac_pid->_derivative;
/// Reset the PID integrator
static void AC_PID_reset(AC_PID * ac_pid)
    ac_pid->_integrator = 0;
    ac_pid->_last_input = 0;
    ac_pid->_last_derivative = 0;
#define _X 1
#define _Y 0
/****************** PI and PID controllers for GPS ********************///32938 -> 33160
static AC_PID pi_poshold[2];
static AC_PID pid_poshold_rate[2];
static AC_PID pid_nav[2];
#define RADX100                    0.000174532925f
#define CROSSTRACK_GAIN            1
#define NAV_SLOW_NAV               true
#define NAV_BANK_MAX               3000 // 30deg max banking when navigating (just for security and testing)
static float dTnav;             // Delta Time in milliseconds for navigation computations, updated with every good GPS read
static int16_t actual_speed[2] = { 0, 0 };
static float GPS_scaleLonDown;  // this is used to offset the shrinking longitude as we go towards the poles
// The difference between the desired rate of travel and the actual rate of travel
// updated after GPS read - 5-10hz
static int16_t rate_error[2];
static int32_t error[2];
//Currently used WP
static int32_t GPS_WP[2];
// Location & Navigation
// This is the angle from the copter to the "next_WP" location in degrees * 100
static int32_t target_bearing;
// Crosstrack
// deg * 100, The original angle to the next_WP when the next_WP was set
// Also used to check when we pass a WP
static int32_t original_target_bearing;
// The amount of angle correction applied to target_bearing to bring the copter back on its optimum path
static int16_t crosstrack_error;
// The location of the copter in relation to home, updated every GPS read (1deg - 100)
//static int32_t home_to_copter_bearing;
// distance between plane and home in cm
//static int32_t home_distance;
// distance between plane and next_WP in cm
static uint32_t wp_distance;
// used for slow speed wind up when start navigation;
static int16_t waypoint_speed_gov;
// moving average filter variables
#define GPS_FILTER_VECTOR_LENGTH 5
static uint8_t GPS_filter_index = 0;
static int32_t GPS_filter[2][GPS_FILTER_VECTOR_LENGTH];
static int32_t GPS_filter_sum[2];
static int32_t GPS_read[2];
static int32_t GPS_filtered[2];
static int32_t GPS_degree[2];   //the lat lon degree without any decimals (lat/10 000 000)
static uint16_t fraction3[2];
// with the addition of Crosstrack error in degrees * 100
static int32_t nav_bearing;
// saves the bearing at takeof (1deg = 1) used to rotate to takeoff direction when arrives at home
static int16_t nav_takeoff_bearing;
    int axis;
    static uint32_t nav_loopTimer;
    uint32_t dist;
    int32_t dir;
    int16_t speed;
    if (GPS_newFrame(c)) {
        if (GPS_update == 1)
            GPS_update = 0;
            GPS_update = 1;
        if (f.GPS_FIX && GPS_numSat >= 5) {
            if (!f.ARMED) {
                f.GPS_FIX_HOME = 0;
            if (!f.GPS_FIX_HOME && f.ARMED) {
                f.GPS_FIX_HOME = 1;
                GPS_home[LAT] = GPS_coord[LAT];
                GPS_home[LON] = GPS_coord[LON];
                GPS_calc_longitude_scaling(GPS_coord[LAT]); // need an initial value for distance and bearing calc
                nav_takeoff_bearing = heading; // save takeoff heading
            // Apply moving average filter to GPS data
#if defined(GPS_FILTERING)
            GPS_filter_index = (GPS_filter_index+1) % GPS_FILTER_VECTOR_LENGTH;
            for (axis = 0; axis < 2; axis++) {
                GPS_read[axis] = GPS_coord[axis];       // latest unfiltered data is in GPS_latitude and GPS_longitude
                GPS_degree[axis] = GPS_read[axis] / 10000000;   // get the degree to assure the sum fits to the int32_t
                // How close we are to a degree line ? its the first three digits from the fractions of degree
                // later we use it to Check if we are close to a degree line, if yes, disable averaging,
                fraction3[axis] = (GPS_read[axis] - GPS_degree[axis] * 10000000) / 10000;
                GPS_filter_sum[axis] -= GPS_filter[axis][GPS_filter_index];
                GPS_filter[axis][GPS_filter_index] = GPS_read[axis] - (GPS_degree[axis] * 10000000);
                GPS_filter_sum[axis] += GPS_filter[axis][GPS_filter_index];
                GPS_filtered[axis] = GPS_filter_sum[axis] / GPS_FILTER_VECTOR_LENGTH + (GPS_degree[axis] * 10000000);
                if (nav_mode == NAV_MODE_POSHOLD) {     //we use gps averaging only in poshold mode...
                    if (fraction3[axis] > 1 && fraction3[axis] < 999)
                        GPS_coord[axis] = GPS_filtered[axis];
#endif
            // dTnav calculation
            // Time for calculating x,y speed and navigation pids
            dTnav = (float) (millis() - nav_loopTimer) / 1000.0f;
            nav_loopTimer = millis();
            // prevent runup from bad GPS
            dTnav = min(dTnav, 1.0f);
            // calculate distance and bearings for gui and other stuff continously - From home to copter
            GPS_distance_cm_bearing(&GPS_coord[LAT], &GPS_coord[LON], &GPS_home[LAT], &GPS_home[LON], &dist, &dir);
            GPS_distanceToHome = dist / 100;
            GPS_directionToHome = dir / 100;
            //calculate the current velocity based on gps coordinates continously to get a valid speed at the moment when we start navigating
            GPS_calc_velocity();
            if (f.GPS_HOLD_MODE || f.GPS_HOME_MODE) { // ok we are navigating
                // do gps nav calculations here, these are common for nav and poshold
                GPS_distance_cm_bearing(&GPS_coord[LAT], &GPS_coord[LON], &GPS_WP[LAT], &GPS_WP[LON], &wp_distance, &target_bearing);
                GPS_calc_location_error(&GPS_WP[LAT], &GPS_WP[LON], &GPS_coord[LAT], &GPS_coord[LON]);
                switch (nav_mode) {
                case NAV_MODE_POSHOLD:
                    // Desired output is in nav_lat and nav_lon where 1deg inclination is 100
                    GPS_calc_poshold();
                    break;
                case NAV_MODE_WP:
                    speed = GPS_calc_desired_speed(cfg.nav_speed_max, NAV_SLOW_NAV);    //slow navigation
                    // use error as the desired rate towards the target
                    GPS_calc_nav_rate(speed);
                    // Tail control
                    if (cfg.nav_controls_heading) {
                        if (NAV_TAIL_FIRST) {
                            magHold = wrap_18000(nav_bearing - 18000) / 100;
                        } else {
                            magHold = nav_bearing / 100;
                    // Are we there yet ?(within x meters of the destination)
                    if ((wp_distance <= cfg.gps_wp_radius) || check_missed_wp()) {      // if yes switch to poshold mode
                        nav_mode = NAV_MODE_POSHOLD;
                        if (NAV_SET_TAKEOFF_HEADING) {
                            magHold = nav_takeoff_bearing;
                    break;
            }                   //end of gps calcs
void GPS_reset_home_position(void)
        nav_takeoff_bearing = heading;             //save takeoff heading
        //Set ground altitude
        f.GPS_FIX_HOME = 1;
//reset navigation (stop the navigation processor, and clear nav)
void GPS_reset_nav(void)
    int i;
    for (i = 0; i < 2; i++) {
        GPS_angle[i] = 0;
        nav[i] = 0;
        AC_PID_reset(&pi_poshold[i]);
        AC_PID_reset(&pid_poshold_rate[i]);
        AC_PID_reset(&pid_nav[i]);
//Get the relevant P I D values and set the PID controllers
    posholdPID.kP = (float) cfg.P8[PIDPOS] / 100.0f;
    posholdPID.kI = (float) cfg.I8[PIDPOS] / 100.0f;
    posholdPID.Imax = POSHOLD_RATE_IMAX * 100;
    poshold_ratePID.kP = (float) cfg.P8[PIDPOSR] / 10.0f;
    poshold_ratePID.kI = (float) cfg.I8[PIDPOSR] / 100.0f;
    poshold_ratePID.kD = (float) cfg.D8[PIDPOSR] / 1000.0f;
    poshold_ratePID.Imax = POSHOLD_RATE_IMAX * 100;
    navPID.kP = (float) cfg.P8[PIDNAVR] / 10.0f;
    navPID.kI = (float) cfg.I8[PIDNAVR] / 100.0f;
    navPID.kD = (float) cfg.D8[PIDNAVR] / 1000.0f;
    navPID.Imax = POSHOLD_RATE_IMAX * 100;
// OK here is the onboard GPS code
// PID based GPS navigation functions
// Author : EOSBandi
// Based on code and ideas from the Arducopter team: Jason Short,Randy Mackay, Pat Hickey, Jose Julio, Jani Hirvinen
// Andrew Tridgell, Justin Beech, Adam Rivera, Jean-Louis Naudin, Roberto Navoni
// It's ok to calculate this once per waypoint setting, since it changes a little within the reach of a multicopter
    float rads = (abs((float)lat)) * (0.0174532925f / 10000000.0f);
    GPS_scaleLonDown = cosf(rads);
// Sets the waypoint to navigate, reset neccessary variables and calculate initial values
void GPS_set_next_wp(int32_t * lat, int32_t * lon)
    GPS_WP[LAT] = *lat;
    GPS_WP[LON] = *lon;
    GPS_calc_longitude_scaling(*lat);
    nav_bearing = target_bearing;
    original_target_bearing = target_bearing;
    waypoint_speed_gov = cfg.nav_speed_min;
// Check if we missed the destination somehow
    int32_t temp;
    temp = target_bearing - original_target_bearing;
    temp = wrap_18000(temp);
    return (abs(temp) > 10000); // we passed the waypoint by 100 degrees
// Get distance between two points in cm
// Get bearing from pos1 to pos2, returns an 1deg = 100 precision
    float dLat = *lat2 - *lat1; // difference of latitude in 1/10 000 000 degrees
    float dLon = (float) (*lon2 - *lon1) * GPS_scaleLonDown;
    *dist = sqrtf(sq(dLat) + sq(dLon)) * 1.113195f;
    *bearing = 9000.0f + atan2f(-dLat, dLon) * 5729.57795f;      // Convert the output radians to 100xdeg
    if (*bearing < 0)
        *bearing += 36000;
// keep old calculation function for compatibility (could be removed later) distance in meters, bearing in degree
//static void GPS_distance(int32_t lat1, int32_t lon1, int32_t lat2, int32_t lon2, uint16_t* dist, int16_t* bearing) {
//  uint32_t d1;
//  int32_t  d2;
//  GPS_distance_cm_bearing(&lat1,&lon1,&lat2,&lon2,&d1,&d2);
//  *dist = d1 / 100;          //convert to meters
//  *bearing = d2 /  100;      //convert to degrees
// Calculate our current speed vector from gps position data
    static int16_t speed_old[2] = { 0, 0 };
    static int32_t last[2] = { 0, 0 };
    static uint8_t init = 0;
    // y_GPS_speed positve = Up
    // x_GPS_speed positve = Right
    if (init) {
        float tmp = 1.0f / dTnav;
        actual_speed[_X] = (float) (GPS_coord[LON] - last[LON]) * GPS_scaleLonDown * tmp;
        actual_speed[_Y] = (float) (GPS_coord[LAT] - last[LAT]) * tmp;
        actual_speed[_X] = (actual_speed[_X] + speed_old[_X]) / 2;
        actual_speed[_Y] = (actual_speed[_Y] + speed_old[_Y]) / 2;
        speed_old[_X] = actual_speed[_X];
        speed_old[_Y] = actual_speed[_Y];
    init = 1;
    last[LON] = GPS_coord[LON];
    last[LAT] = GPS_coord[LAT];
// Calculate a location error between two gps coordinates
// Because we are using lat and lon to do our distance errors here's a quick chart:
//      100     = 1m
//      1000    = 11m    = 36 feet
//      1800    = 19.80m = 60 feet
//      3000    = 33m
//      10000   = 111m
    error[LON] = (float) (*target_lng - *gps_lng) * GPS_scaleLonDown;   // X Error
    error[LAT] = *target_lat - *gps_lat;        // Y Error
// Calculate nav_lat and nav_lon from the x and y error and the speed
    int32_t p, i, d;
    int32_t output;
    int32_t target_speed;
    int axis;
        target_speed = AC_PID_get_p(&pi_poshold[axis], error[axis], &posholdPID);       // calculate desired speed from lon error
        rate_error[axis] = target_speed - actual_speed[axis];   // calc the speed error
        p = AC_PID_get_p(&pid_poshold_rate[axis], rate_error[axis], &poshold_ratePID);
        i = AC_PID_get_i(&pid_poshold_rate[axis], rate_error[axis] + error[axis], &dTnav, &poshold_ratePID);
        d = AC_PID_get_d(&pid_poshold_rate[axis], error[axis], &dTnav, &poshold_ratePID);
        d = constrain(d, -2000, 2000);
        // get rid of noise
#if defined(GPS_LOW_SPEED_D_FILTER)
        if (abs(actual_speed[axis]) < 50)
            d = 0;
#endif
        output = p + i + d;
        nav[axis] = constrain(output, -NAV_BANK_MAX, NAV_BANK_MAX);
        AC_PID_set_integrator(&pid_nav[axis], AC_PID_get_integrator(&pid_poshold_rate[axis]));
// Calculate the desired nav_lat and nav_lon for distance flying such as RTH
    float trig[2];
    float temp;
    int axis;
    // push us towards the original track
    GPS_update_crosstrack();
    // nav_bearing includes crosstrack
    temp = (9000l - nav_bearing) * RADX100;
    trig[_X] = cosf(temp);
    trig[_Y] = sinf(temp);
        rate_error[axis] = (trig[axis] * max_speed) - actual_speed[axis];
        rate_error[axis] = constrain(rate_error[axis], -1000, 1000);
        // P + I + D
        nav[axis] = AC_PID_get_p(&pid_nav[axis], rate_error[axis], &navPID)
            + AC_PID_get_i(&pid_nav[axis], rate_error[axis], &dTnav, &navPID)
            + AC_PID_get_d(&pid_nav[axis], rate_error[axis], &dTnav, &navPID);
        nav[axis] = constrain(nav[axis], -NAV_BANK_MAX, NAV_BANK_MAX);
        AC_PID_set_integrator(&pid_poshold_rate[axis], AC_PID_get_integrator(&pid_nav[axis]));
// Calculating cross track error, this tries to keep the copter on a direct line
// when flying to a waypoint.
    if (abs(wrap_18000(target_bearing - original_target_bearing)) < 4500) {     // If we are too far off or too close we don't do track following
        float temp = (target_bearing - original_target_bearing) * RADX100;
        crosstrack_error = sinf(temp) * (wp_distance * CROSSTRACK_GAIN); // Meters we are off track line
        nav_bearing = target_bearing + constrain(crosstrack_error, -3000, 3000);
        nav_bearing = wrap_36000(nav_bearing);
    } else {
// Determine desired speed when navigating towards a waypoint, also implement slow
// speed rampup when starting a navigation
//      |< WP Radius
//      0  1   2   3   4   5   6   7   8m
//                100  |  200     300     400cm/s
//                 |< we should slow to 1.5 m/s as we hit the target
    // max_speed is default 400 or 4m/s
    if (_slow) {
        max_speed = min(max_speed, wp_distance / 2);
        max_speed = max(max_speed, 0);
    } else {
        max_speed = min(max_speed, wp_distance);
        max_speed = max(max_speed, cfg.nav_speed_min);      // go at least 100cm/s
    // limit the ramp up of the speed
    // waypoint_speed_gov is reset to 0 at each new WP command
    if (max_speed > waypoint_speed_gov) {
        waypoint_speed_gov += (int) (100.0f * dTnav);    // increase at .5/ms
        max_speed = waypoint_speed_gov;
    return max_speed;
// Utilities
    if (error > 18000)
        error -= 36000;
    if (error < -18000)
        error += 36000;
    return error;
    if (angle > 36000)
        angle -= 36000;
    if (angle < 0)
        angle += 36000;
    return angle;
// This code is used for parsing NMEA data
/* Alex optimization
  The latitude or longitude is coded this way in NMEA frames
  dm.f   coded as degrees + minutes + minute decimal
  Where:
    - d can be 1 or more char long. generally: 2 char long for latitude, 3 char long for longitude
    - m is always 2 char long
    - f can be 1 or more char long
  This function converts this format in a unique unsigned long where 1 degree = 10 000 000
  EOS increased the precision here, even if we think that the gps is not precise enough, with 10e5 precision it has 76cm resolution
  with 10e7 it's around 1 cm now. Increasing it further is irrelevant, since even 1cm resolution is unrealistic, however increased
  resolution also increased precision of nav calculations
static uint32_t GPS_coord_to_degrees(char *s)
    char *p = s, *d = s;
    uint8_t min, deg = 0;
    uint16_t frac = 0, mult = 10000;
    while (*p) {                // parse the string until its end
        if (d != s) {
            frac += (*p - '0') * mult;  // calculate only fractional part on up to 5 digits  (d != s condition is true when the . is located)
            mult /= 10;
        if (*p == '.')
            d = p;              // locate '.' char in the string
        p++;
    if (p == s)
        return 0;
    while (s < d - 2) {
        deg *= 10;              // convert degrees : all chars before minutes ; for the first iteration, deg = 0
        deg += *(s++) - '0';
    min = *(d - 1) - '0' + (*(d - 2) - '0') * 10;       // convert minutes : 2 previous char before '.'
    return deg * 10000000UL + (min * 100000UL + frac) * 10UL / 6;
#define DIGIT_TO_VAL(_x)    (_x - '0')
uint32_t GPS_coord_to_degrees(char* s)
    char *p, *q;
    uint8_t deg = 0, min = 0;
    unsigned int frac_min = 0;
    int i;
    // scan for decimal point or end of field
    for (p = s; isdigit(*p); p++)
    q = s;
    // convert degrees
    while ((p - q) > 2) {
        if (deg)
            deg *= 10;
        deg += DIGIT_TO_VAL(*q++);
    // convert minutes
    while (p > q) {
        if (min)
            min *= 10;
        min += DIGIT_TO_VAL(*q++);
    // convert fractional minutes
    // expect up to four digits, result is in
    // ten-thousandths of a minute
    if (*p == '.') {
        q = p + 1;
        for (i = 0; i < 4; i++) {
            frac_min *= 10;
            if (isdigit(*q))
                frac_min += *q++ - '0';
    return deg * 10000000UL + (min * 1000000UL + frac_min * 100UL) / 6;
// helper functions
static uint32_t grab_fields(char *src, uint8_t mult)
{                               // convert string to uint32
    uint32_t i;
    uint32_t tmp = 0;
    for (i = 0; src[i] != 0; i++) {
        if (src[i] == '.') {
            i++;
            if (mult == 0)
                break;
                src[i + mult] = 0;
        tmp *= 10;
        if (src[i] >= '0' && src[i] <= '9')
            tmp += src[i] - '0';
    return tmp;
static uint8_t hex_c(uint8_t n)
{                               // convert '0'..'9','A'..'F' to 0..15
    n -= '0';
    if (n > 9)
        n -= 7;
    n &= 0x0F;
    return n;
/* This is a light implementation of a GPS frame decoding
   This should work with most of modern GPS devices configured to output NMEA frames.
   It assumes there are some NMEA GGA frames to decode on the serial bus
   Here we use only the following data :
     - latitude
     - longitude
     - GPS fix is/is not ok
     - GPS num sat (4 is enough to be +/- reliable)
     // added by Mis
     - GPS altitude (for OSD displaying)
     - GPS speed (for OSD displaying)
#define FRAME_GGA  1
#define FRAME_RMC  2
    uint8_t frameOK = 0;
    static uint8_t param = 0, offset = 0, parity = 0;
    static char string[15];
    static uint8_t checksum_param, frame = 0;
    if (c == '$') {
        param = 0;
        offset = 0;
        parity = 0;
    } else if (c == ',' || c == '*') {
        string[offset] = 0;
        if (param == 0) {       //frame identification
            frame = 0;
            if (string[0] == 'G' && string[1] == 'P' && string[2] == 'G' && string[3] == 'G' && string[4] == 'A')
                frame = FRAME_GGA;
            if (string[0] == 'G' && string[1] == 'P' && string[2] == 'R' && string[3] == 'M' && string[4] == 'C')
                frame = FRAME_RMC;
        } else if (frame == FRAME_GGA) {
            if (param == 2) {
                GPS_coord[LAT] = GPS_coord_to_degrees(string);
            } else if (param == 3 && string[0] == 'S')
                GPS_coord[LAT] = -GPS_coord[LAT];
            else if (param == 4) {
                GPS_coord[LON] = GPS_coord_to_degrees(string);
            } else if (param == 5 && string[0] == 'W')
                GPS_coord[LON] = -GPS_coord[LON];
            else if (param == 6) {
                f.GPS_FIX = string[0] > '0';
            } else if (param == 7) {
                GPS_numSat = grab_fields(string, 0);
            } else if (param == 9) {
                GPS_altitude = grab_fields(string, 0);  // altitude in meters added by Mis
        } else if (frame == FRAME_RMC) {
            if (param == 7) {
                GPS_speed = ((uint32_t) grab_fields(string, 1) * 5144L) / 1000L;    // speed in cm/s added by Mis
        param++;
        offset = 0;
        if (c == '*')
            checksum_param = 1;
            parity ^= c;
    } else if (c == '\r' || c == '\n') {
        if (checksum_param) {   // parity checksum
            uint8_t checksum = hex_c(string[0]);
            checksum <<= 4;
            checksum += hex_c(string[1]);
            if (checksum == parity)
                frameOK = 1;
        checksum_param = 0;
    } else {
        if (offset < 15)
            string[offset++] = c;
        if (!checksum_param)
            parity ^= c;
    if (frame)
        GPS_Present = 1;
    return frameOK && (frame == FRAME_GGA);
