| Quantity | Reference Designator(s) | Descriptions | Value | Package Type | Manufacturer | Manufacturer Part Number | PRTNUM_49 |
1 | U3 | 16-Bit, 1.5 LSB INL, 250 kSPS PulSAR™ Differential ADC | RM-10 | Analog Devices | AD7687BRMZ | 30-025996-01 | |
1 | U2 | G = 0.2, Level Translation, 16-Bit ADC Driver | RM-8 | Analog Devices | AD8275BRMZ | 30-025997-01 | |
1 | U1 | Precision Instrumentation Amplifier with Signal Processing Amplifiers | CP-16-19-D | Analog Devices | AD8295BCPZ | 30-025998-01 | |
1 | U4 | IC ADP3336 ADJ 500mA LDO ADI | RM-8 | Analog Devices | ADP3336ARMZ | 30-025190-01 | |
1 | U5 | Ultralow Noise XFET Voltage References with Current Sink and Source Capability | RM-8 | Analog Devices | ADR431ARMZ | 30-025999-01 | |
4 | B1-4 | B0805 300ohm@100MHz 2A BLM21PG331SN1D MURATA | 330@100MHz | 0805 | MURATA | BLM21PG331SN1D | 7000692 |
9 | C1-3 C5-7 C9 C16 C20 | C0603 0.1uF 25V GRM188R71E104KA01D Murata | 0.1uF | 0603 | Murata | GRM188R71E104KA01D | 7000767 |
1 | C8 | C0603 1.5nF 50V GRM188R71H152KA01D Murata | 1.5nF | 0603 | Murata | GRM188R71H152KA01D | 7000917 |
2 | C19 C22 | C0603 100pF 50V 06035A101JAT2A AVX | 100pF | 0603 | AVX | 06035A101JAT2A | 7000405 |
1 | C24 | C0603 1nF 50V X7R0603HTTD102J KOA | 1nF | 0603 | KOA | X7R0603HTTD102J | 7000406 |
1 | C21 | C0603 470pF 50V 06033A471JAT2A AVX | 470pF | 0603 | AVX | 06033A471JAT2A | 7000352 |
2 | C10-11 | C0805 10uF 10V GRM21BR61A106KE19L MURATA | 10uF | 0805 | MURATA | GRM21BR61A106KE19L | 7000461 |
2 | C13-14 | C0805 1uF 25V ECJ-2VB1E104K PANASONIC | 1uF | 0805 | PANASONIC | ECJ-2VB1E104K | 7000758 |
1 | C4 | C1206 22uF 6.3V C2012X7R0J226K TDK | 22uF | 1206 | TDK | C2012X7R0J226K | 7000630 |
3 | C12 C15 C17-18 | C1206 10uF 25V YAGEO | 10uF | 1206 | YAGEO | CC1206ZKY5V8BB106 | 7000900 |
3 | F1-3 | CAP 3T C-Type Chip EMIFIL CKD510JB1A105ST 10V TDK | 1uF | EMIF3TC_0805 | CKD510JB1A105ST | 7000901 | |
1 | J5 | SDP Connector | CON_120PIN_SMD | Hirose | FX8-120S-SV(21) | 6000923 | |
2 | D1-2 | Schottky Diode BAT54S 200mA 30V DIODES INC | SOT23 | DIODES INC | BAT54S | 7000899 | |
1 | U7 | IC EEPROM I2C Bus 32K 24LC32A-I/SN MICROCHIP | 32K | SOIC8 | MICROCHIP | 24LC32A-I/SN | 1000614 |
1 | U8 | IC 74HC1G125GW NXP | 74HC1G125GW | SOT353-1 | NXP | 74HC1G125GW | 1000628 |
1 | J4 | 3Pin 2.54mm 22-03-2031 MOLEX | SIP-3P | MOLEX | 22-03-2031 | 6000964 | |
3 | JP1-3 | 3Pin 2.54mm 22-03-2031 MOLEX | SIP-3P | MOLEX | 22-03-2031 | 6000964 | |
3 | PS1-3 | Polyswitch NANOSMDC035F 350mA 30V TYCO | NANOSMDC035F | 1206 | Tyco | NANOSMDC035F | 6000972 |
2 | R10 R12 | R0603 100K 5% 1/10W 100ppm CRCW0603100KJNEA VASHAY | 100K | 0603 | VASHAY | CRCW0603100KJNEA | 7000367 |
2 | R6-7 | R0603 10K 1% 1/10W RC0603FR-0710KL YAGEO | 10K | 0603 | YAGEO | RC0603FR-0710KL | 7000401 |
1 | R31 | R0603 210K 1% 1/10W 100ppm ERJ-3EKF2103V PANASONIC | 210K | 0603 | PANASONIC | ERJ-3EKF2103V | 7000771 |
7 | R4-5 R13-17 | R0603 33 1% 1/10W 100ppm CRCW060333R0FKEA VISHAY | 33 | 0603 | VISHAY | CRCW060333R0FKEA | 7000415 |
1 | R8 | R0603 64.9K 1% 63mW 100ppm ERJ-3EKF6492V PANASONIC | 64.9K | 0603 | PANASONIC | ERJ-3EKF6492V | 7000772 |
2 | R1-2 | R0805 1.5K 1% 100mW 100ppm CRCW08051K50FKEA VIshay | 1.5K | 0805 | VIshay | CRCW08051K50FKEA | 7000050 |
1 | R11 | SURFACE MOUNT RESISTOR 0.031 X 0.061 INCHES, 1/10W | NP | 0603 | IPC SM-782 STD. | ||
1 | R3 | SURFACE MOUNT RESISTOR 0.048 X 0.079 INCHES | NP | 0805 | IPC SM-782 STD. | ||
3 | D3-5 | Diode SBR2U30P1-7 Vf:0.5V@2A If:2A DIODES INC | SBR2U30P1-7 | DIODE_S | DIODES INC | SBR2U30P1-7 | 7000782 |
2 | J1-2 | Terminal, 5.08mm, 2 Way | 2P_200_45 | MULTICOMP | MC24356 | 6000968 | |
1 | J3 | Screw Terminal MC24357 5.08mm 180(D) Multicomp | CON\5.08\3P | Multicomp | MC24357 | 6000969 | |
18 | +15VA -15VA A1V25 A2V5 AGND D5V D6V DGND MISO SCL SCLK SDA SPI_SEL TP6-10 | Test Point Hole 60*40(mil) | TP40 | ||||
5 | TVS1-5 | TVS SMBJ30CA 600W FAIRCHILD | DO-214AA | BOURNS | SMBJ30CA | 7000907 |
261.2 KB, 下載次數(shù): 8, 下載積分: 黑幣 -5
高阻抗、高CMR、±10 V模擬前端信號調(diào)理參考設(shè)計.pdf
1.41 MB, 下載次數(shù): 11, 下載積分: 黑幣 -5
1.48 MB, 下載次數(shù): 8, 下載積分: 黑幣 -5
12.95 KB, 下載次數(shù): 7, 下載積分: 黑幣 -5
