標題: avr單片機 PWM調速程序及原理圖 [打印本頁]
作者: wrgolf    時間: 2016-4-20 16:07
16單片機 PWM調速!!!!
源程序:
  1. #include<iom16v.h>
  2. #include<macros.h>
  3. #define uint unsigned int
  5. #define Left OCR1A
  6. #define Right OCR1B
  7. #define ADD 1.15;   //宏定義,加速系數
  8. uchar i;
  9. uchar flag;      //是否減速標志位
  10. uchar TCRT5000_IN;
  11. uint Max_Speed;
  12. uchar Min_Speed;
  13. /*************************************************
  14. 函數名稱:Init_TCRT5000
  15. 函數功能:初始化紅外傳感器TCRT5000
  16. 函數說明:設置PA口為輸入,監測傳感器信號*********/
  17. void Init_TCRT5000()
  18. {
  19. DDRA = 0X00;
  20. PORTA = 0XFF;
  21. }
  22. /*************************************************
  23. 函數名稱:Max()
  24. 函數功能:判斷最大速度
  25. 函數說明:判斷最大速度,將其值放入Max_Speed中*****/
  26. void Max()
  27. {
  28. if(Left >= Right)
  29. {
  30.   Max_Speed = Left * ADD;
  31. }
  32. else
  33. {
  34.   Max_Speed = Right * ADD;
  35. }
  36. if(Max_Speed >= 0xf7)
  37. {
  38.   Max_Speed = 0xf7;
  39. }
  40. Min_Speed = 0x20 ;
  41. }
  42. /*************************************************
  43. 函數名稱:Scan_TCRT5000
  44. 函數功能:TCRT5000進行掃描,返回跑到信息
  45. 函數說明:*********/
  46. void Scan_TCRT5000()
  47. {
  48. TCRT5000_IN = PINA&0x1F;
  49. switch(TCRT5000_IN)
  50. {
  51.    /*  OOOOO  *///全滅
  52.    case 0x00:
  53.        break;
  54.    /*  *****  *///全亮
  55.    case 0x1f:
  56.        OCR1A=0x00;
  57.        OCR1B=0x00;
  58.            break;
  59.    /*  O*OOO  */
  60.    case 0x08:
  61.        OCR1A=Min_Speed;
  62.            OCR1B=Max_Speed;
  63.            break;
  64.    /*  *OOOO  */
  65.    case 0x10:
  66.        OCR1A=Min_Speed;
  67.            OCR1B=Max_Speed;
  68.               break;
  69.    /*  O**OO  */
  70.    case 0x0c:
  71.        OCR1A=Min_Speed;
  72.            OCR1B=Max_Speed;
  73.            break;
  74.    /*  **OOO  */
  75.    case 0x18:
  76.        OCR1A=Min_Speed;
  77.            OCR1B=Max_Speed;
  78.            break;
  79.     /*  ***00*/
  80.     case 0x1c:
  81.        OCR1A=Min_Speed;
  82.            OCR1B=Max_Speed;
  83.            break;
  84.    /*  OOO*O  */
  85.    case 0x02:
  86.            OCR1A=Max_Speed;
  87.            OCR1B=Min_Speed;
  88.            break;
  89.    /*  OOOO*  */
  90.    case 0x01:
  91.        OCR1A=Max_Speed;
  92.            OCR1B=Min_Speed;
  93.            break;
  94.    /*  OO**O  */
  95.    case 0x06:
  96.        OCR1A=Max_Speed;
  97.            OCR1B=Min_Speed;
  98.            break;
  99.    /*  OOO**  */
  100.    case 0x03:
  101.        OCR1A=Max_Speed;
  102.            OCR1B=Min_Speed;
  103.            break;
  104.    /*  OO***  */
  105.    case 0x07:
  106.        OCR1A=Max_Speed;
  107.            OCR1B=Min_Speed;
  108.            break;
  109.    default:
  110.        break;
  111.   }
  112. }
  113. /*************************************************
  114. 函數名稱:Init_Speed
  115. 函數功能:定時器1初始化,產生兩路PWM信號
  116. 函數說明:通過改變全局變Left,Right控制小車速度**/
  117. void Init_Speed()
  118. {
  119. DDRD |= 0X30;
  120. TCCR1A=0xA1;
  121. TCCR1B=0x0A;
  122. OCR1A=0xa0;
  123. OCR1B=0xa0;
  124. }
  125. /**********************************************
  126. 函數名稱:Stop
  127. 函數功能:小車停止
  128. 函數說明:Right=0,Left=0*********************/
  129. void Stop()
  130. {
  131. OCR1A=0x00;
  132. OCR1B=0x00;
  133. }
  134. /**********************************************
  135. 函數名稱:Init_Timer0
  136. 函數功能:初始化定時器0
  137. 函數說明:初始化定時器0
  138.           設1024分頻
  139.                   100ms觸發一次中斷,速度加1**********/
  140. void Init_Timer0()
  141. {
  142. TCCR0 = 0x05;
  143. TCNT0 = 0x00;
  144. TIMSK |= BIT(2);
  145. SREG |= BIT(7);
  146. }
  147. void main()
  148. {
  149. uchar speed;
  150. TCRT5000_IN = PINA&0x1F;
  151. Init_Speed();
  152. Init_TCRT5000();
  153. Init_Timer0();
  154. while(1)
  155. {
  156.   TCRT5000_IN = PINA&0x1F;
  157.   while(TCRT5000_IN != 0x04)
  158.   {
  159.    SREG &= ~BIT(7);   //關閉中斷
  160.    Scan_TCRT5000();
  161.    TCRT5000_IN = PINA&0x1F;
  162.    flag = 1;
  163.   }
  164.   while(TCRT5000_IN == 0x04)
  165.   {
  166.    if(flag == 1)
  167.    {
  168.            Left = 0xb0;
  169.     Right = 0xb0;
  170.         flag =0;
  171.         SREG |= BIT(7);   //打開中斷
  172.    }
  173.    TCRT5000_IN = PINA&0x1F;
  174.   }
  175. }
  176. }
  177. /*定時器0中斷函數*/
  178. #pragma interrupt_handler Timer0:10
  179. void Timer0()
  180. {
  181. TCNT0 = 0x00;
  182. i++;
  183. if(i == 100)
  184. {
  185.   i=0;
  186.   Left++;
  187.   if(Left >= 0xfe)
  188.   {
  189.    Left = 0xfe;
  190.   }
  191.   OCR1B++;
  192.   if(OCR1B >= 0xfe)
  193.   {
  194.    OCR1B = 0xfe;
  195.   }
  196.   Max();
  197. }
  198. }
PWM調速.zip
294.58 KB, 下載次數: 98, 下載積分: 黑幣 -5
作者: 成森林    時間: 2018-1-31 16:42
都是好東西,謝謝分享。
作者: aifengdian    時間: 2018-3-20 10:03
這個論壇太貼心了!謝謝分享!
作者: 成森林    時間: 2018-4-12 14:17
好資料下載積分不夠,等有了再下載。
作者: huaishang    時間: 2018-8-9 23:09
都是好東西,謝謝分享。
作者: jjj12345    時間: 2018-11-8 19:33
好東西,謝謝分享
作者: huaishang    時間: 2019-2-23 18:23
都是好東西,謝謝分享
作者: yaolong986    時間: 2020-11-24 15:39
都是好東西,謝謝分享
作者: cqopd    時間: 2021-4-5 15:10
真是好東西,感謝分享
作者: shiyakuo    時間: 2022-11-11 07:39
太好了,就是找這個
