標(biāo)題: MSCANS08 CAN總線的程序模擬各傳感器的功能 [打印本頁(yè)]
作者: 51黑ww    時(shí)間: 2016-4-12 03:03
這可是我自己寫的CAN總線的程序呀,里面有模擬各傳感器的功能,比如汽車儀表,溫度還有油門等,血汗來的
; LINS08AW60 v.1.0
; filelist.txt
; Copyright (C) 2005 Freescale Semiconductor, Inc.
; All Rights Reserved
; LINS08AW60 file list
.\filelist.txt                        ; List of LIN S08 files
.\readme.txt                          ; Readme
.\license.txt                         ; License statement
.\inc:
.\inc\l_api.h                         ; User's main header (for LIN API)
.\inc\lintmr.h                        ; Timer routines header file
.\inc\linstd.h                        ; Define LIN driver data types
.\inc\linsci.h                        ; SCI routines header file
.\inc\linprot.h                       ; LIN Protocol header file.
.\inc\linmsgid.h                      ; User's Message configuration (for Freescale API)
.\inc\linmsg.h                        ; Message processing subsystem header file
.\inc\lininit.h                       ; LIN Driver initialization header file
.\inc\linerr.h                        ; LIN Error management header file
.\inc\lindef.h                              ; LIN Driver data types and definitions
.\inc\lindbg.h                        ; Debug routines header file
.\inc\lincfg.h                        ; User's Driver configuration (for Freescale API)
.\inc\linbase.h                       ; Includes all needed files for developers
.\inc\linapi.h                        ; User's main header (for Freescale API)
.\man:                                ;
.\man\lin.pdf                         ; User manual
.\S08:
.\S08\vector.c                        ; Interrupt vectors (for Freescale API)
.\S08\regs.h                          ; Register definition file
.\sample:                             ; Sample application
.\sample\inc\master.h                 ; Header file for master
.\sample\inc\master_option.h          ; Header file for preprocessor definitions
.\sample\inc\slave.h                  ; Header file for slave
.\sample\inc\slave_option.h           ; Header file for preprocessor definitions
.\sample\src\master.c                 ; Source code of sample master
.\sample\src\slave.c                  ; Source code of sample slave
.\sample\LIN config\master.cfg        ; Driver configuration file
.\sample\LIN config\master.id         ; Message configuration file
.\sample\LIN config\slave.cfg         ; Driver configuration file
.\sample\LIN config\slave.id          ; Message configuration file
.\sample\prm\S08AW60.prm              ; Parameter file for the sample project
.\sample\sample.mcp                   ; Sample project file
.\sample\BDM_P&E_Multilink_CyclonePro.ini ; MW Debugger initialisation file
.\sample\C_Layout.hwl                 ; MW Debugger layout file
.\src:
.\src\l_cfg.c                         ; LIN S08 configuration source (for LIN API)
.\src\lintmr.c                        ; LIN Timeout management module
.\src\linsci.c                        ; SCI management module
.\src\linprot.c                       ; LIN Protocol module. Master and Slave State Machines
.\src\linmsgid.c                      ; Message configuration source (for Freescale API)
.\src\linmsg.c                        ; Message processing subsystem
.\src\lininit.c                       ; LIN Driver initialization
.\src\linerr.c                        ; LIN Error management module
.\src\lincfg.c                        ; LIN S08 configuration source (for Freescale API)
.\src\linapi.c                        ; Some API realization
CAN2.rar
449.41 KB, 下載次數(shù): 17, 下載積分: 黑幣 -5
