DIY光立方設計
sdew
2016-3-30 17:09
DIY光立方設計
效果網址:
http://www.tudou.com/programs/view/Z0e4FqTXdP8/
http://www.tudou.com/v/Z0e4FqTXdP8/&resourceId=0_04_05_99/v.swf
程序:
#include <REG52.H>
#include <intrins.h>
uchar display[8][8];//此處的disply為一個空數組用于存放64個數據(8*8*8光立方底座共64個引腳,分別接8片573的8個引腳)
/*rank:A,1,2,3,4,I,心,U*/
uchar code table_cha[8][8]={0x51,0x51,0x51,0x4a,0x4a,0x4a,0x44,0x44,0x18,0x1c,0x18,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0x66,0x30,0x18,0xc,0x6,0xf6,0x3c,0x66,0x60,0x38,0x60,0x60,0x66,0x3c,0x30,0x38,0x3c,0x3e,0x36,0x7e,0x30,0x30,0x3c,0x3c,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0xff,0xff,0xff,0x7e,0x3c,0x18,0x18,0x66,0x66,0x66,0x66,0x66,0x66,0x7e,0x3c};
/*the "ideasoft"*/
uchar code table_id[40]={0x81,0xff,0x81,0x00,0xff,0x81,0x81,0x7e,0x00,0xff,0x89,0x89,0x00,0xf8,0x27,0x27,0xf8,0x00,0x8f,0x89,0x89,0xf9,0x00,0xff,0x81,0x81,0xff,0x00,0xff,0x09,0x09,0x09,0x01,0x0,0x01,0x01,0xff,0x01,0x01,0x00};
/*railway*/
uchar code dat[128]={0x00,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x6f,0x8f,0x93,0x73,0x6f,0x8f,0x93,0x73,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
/*railway 2*/
uchar code dat2[28]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
/*railway 3*/
uchar code dat3[24]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x16,0x26,0x36,0x46,0x56,0x66,0x65,0x64,0x63,0x62,0x61,0x60,0x50,0x40,0x30,0x20,0x10};
/*3p char*/
uchar code table_3p[3][8]={0xff,0x89,0xf5,0x93,0x93,0xf5,0x89,0xff,0x0e,0x1f,0x3f,0x7e,0x7e,0x3f,0x1f,0x0e,0x18,0x3c,0x7e,0xff,0x18,0x18,0x18,0x18};
/* //初始化
這是初始化程序。
這是寫在單片機設置定時器。所以程序可以更新光立方在固定時間使用中斷函數。
//中斷函數控制LED亮滅的速度。*/
void sinter()
IE=0x82;
TCON=0x01;
TH0=0xF5;
TL0=0;
TR0=1;
//誤差 -0.026765046296us STC 1T 22.1184Mhz
void delay5us(void)
unsigned char a,b;
for(b=7;b>0;b--)
for(a=2;a>0;a--);
//12t的mcu 注釋這個延時即可
void delay(uint i)
while (i--){
delay5us();}
/**********判斷數字的位***********/
uchar judgebit(uchar num,uchar b)
char n;
num=num&(1<<b);
if (num)
n=1;
n=0;
return n;
/*To figure out the round number*///計算出圓的數量
uchar abs(uchar a)
uchar b;
b=a/10;
a=a-b*10;
if (a>=5)
b++;
return b;
//找出的絕對值
uchar abss(char a)
if (a<0)
a=-a;
return a;
/*可以比較。和刪除后面的大。 */
void max(uchar *a,uchar *b)
uchar t;
if ((*a)>(*b))
t=(*a);
(*a)=(*b);
(*b)=t;
//函數是找出最大數量和返回它。
uchar maxt(uchar a,uchar b,uchar c)
if (a<b)
a=b;
if (a<c)
a=c;
return a;
/*le控制573 le為P2(位清零)*/
void clear(char le)
uchar i,j;
for (j=0;j<8;j++)
for (i=0;i<8;i++)
display[j][i]=le;
/*******此函數將display[][]數組中的值顯示出來*******/
void trailler(uint speed)
char i,j;
for(i=6;i>=-3;i--)
if (i>=0)
for (j=0;j<8;j++)
display[j][i]=display[j][i+1];
if (i<4)
for (j=0;j<8;j++)
display[j][i+4]=0;
delay(speed);
//光立法燈的立體坐標以及控制其亮的LE端
void point(uchar x,uchar y,uchar z,uchar le)
uchar ch1,ch0;
ch1=1<<x;
ch0=~ch1;
if (le)
display[z][y]=display[z][y]|ch1;
display[z][y]=display[z][y]&ch0;
/**y表示第幾個,cha表示第幾個數組(字模原理每個數字或者圖形產生8個16進制數)***/
void type(uchar cha,uchar y)
uchar xx;
for (xx=0;xx<8;xx++)
display[xx][y]=table_cha[cha][xx];//將取模好的數字或者圖形的字模16進制,放入顯示的數組。
/*第一個變量是中點的距離。第二個是層。第三是LED走的速度每兩個點之間的時間。*/
void cirp(char cpp,uchar dir,uchar le)
uchar a,b,c,cp;
if ((cpp<128)&(cpp>=0))
if (dir)
cp=127-cpp;
cp=cpp;
a=(dat[cp]>>5)&0x07;
b=(dat[cp]>>2)&0x07;
c=dat[cp]&0x03;
if (cpp>63)
c=7-c;
point (a,b,c,le);
void line(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar le)
char t,a,b,c,a1,b1,c1,i;
a1=x2-x1;
b1=y2-y1;
c1=z2-z1;
t=maxt(abss(a1),abss(b1),abss(c1));
a=x1*10;
b=y1*10;
c=z1*10;
a1=a1*10/t;
b1=b1*10/t;
c1=c1*10/t;
for (i=0;i<t;i++)
point(abs(a),abs(b),abs(c),le);
a+=a1;
b+=b1;
c+=c1;
point(x2,y2,z2,le);
void box(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
uchar i,j,t=0;
max(&x1,&x2);
max(&y1,&y2);
max(&z1,&z2);
for (i=x1;i<=x2;i++)
t|=1<<i;
if (!le)
t=~t;
if (fill)
if (le)
for (i=z1;i<=z2;i++)
for (j=y1;j<=y2;j++)
display[j][i]|=t;
display[j][i]&=t;
if (le)
display[y1][z1]|=t;
display[y2][z1]|=t;
display[y1][z2]|=t;
display[y2][z2]|=t;
display[y1][z1]&=t;
display[y2][z1]&=t;
display[y1][z2]&=t;
display[y2][z2]&=t;
t=(0x01<<x1)|(0x01<<x2);
if (!le)
t=~t;
if (le)
for (j=z1;j<=z2;j+=(z2-z1))
for (i=y1;i<=y2;i++)
display[i][j]|=t;
for (j=y1;j<=y2;j+=(y2-y1))
display[j][i]|=t;
display[i][j]&=t;
display[j][i]&=t;
void box_apeak_xy(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
uchar i;
max(&z1,&z2);//比較z1 = 0和z2 = 7;
if(fill) //fill為標志
for(i=z1;i<=z2;i++)
line (x1,y1,i,x2,y2,i,le);
line (x1,y1,z1,x2,y2,z1,le);
line (x1,y1,z2,x2,y2,z2,le);
line (x2,y2,z1,x2,y2,z2,le);
line (x1,y1,z1,x1,y1,z2,le);
void poke(uchar n,uchar x,uchar y)
uchar i;
for (i=0;i<8;i++)
point(x,y,i,judgebit(n,i));
/**********僅僅進行三面顯示,字母*******/
void boxtola(char i,uchar n)
if ((i>=0)&(i<8))
poke(n,0,7-i);//在最邊緣的地方顯示第一面。
if ((i>=8)&(i<16))
poke(n,i-8,0);//在最邊緣的地方顯示第二面。
if ((i>=16)&(i<24))
poke(n,7,i-16);//在最邊緣的地方顯示第三面。
/***此處也可以寫第四面也顯示,但是在下一個函數中a的值為3*8=24,僅僅3面*****/
/**按speed速度將table_id[]中的字母顯示出來**/
void rolldisplay(uint speed)
uchar j;
char i,a;
//以下語句是僅顯示3面,如果顯示4面則i的值需要改變。
for (i=23;i>-40;i--)//i的值一共為64個
for (j=0;j<40;j++)//j為數組table_id[]的容量。
a=i+j;
if ((a>=0)&(a<24))
boxtola(a,table_id[j]);//該函數是在指定面顯示出字母
delay(speed);
void roll_apeak_yz(uchar n,uint speed)
uchar i;
switch(n)
case 1:
for (i=0;i<7;i++)
display[i][7]=0;
display[7][6-i]=255;
delay(speed);
break;
case 2:
for (i=0;i<7;i++)
display[7][7-i]=0;
display[6-i][0]=255;
delay(speed);
break;
case 3:
for (i=0;i<7;i++)
display[7-i][0]=0;
display[0][i+1]=255;
delay(speed);
break;
case 0:
for (i=0;i<7;i++)
display[0][i]=0;
display[i+1][7]=255;
delay(speed);
void roll_apeak_xy(uchar n,uint speed)
uchar i;
switch(n)
case 1:
for (i=0;i<7;i++)
line(0,i,0,0,i,7,0);
line(i+1,7,0,i+1,7,7,1);
delay(speed);
break;
case 2:
for (i=0;i<7;i++)
line(i,7,0,i,7,7,0);
line(7,6-i,0,7,6-i,7,1);
delay(speed);
break;
case 3:
for (i=0;i<7;i++)
line(7,7-i,0,7,7-i,7,0);
line(6-i,0,0,6-i,0,7,1);
delay(speed);
break;
case 0:
for (i=0;i<7;i++)
line(7-i,0,0,7-i,0,7,0);
line(0,i+1,0,0,i+1,7,1);
delay(speed);
void roll_3_xy(uchar n,uint speed)
uchar i;
switch(n)
case 1:
for (i=0;i<8;i++)
box_apeak_xy (0,i,0,7,7-i,7,1,1);
delay(speed);
if (i<7)
box_apeak_xy (3,3,0,0,i,7,1,0);
break;
case 2:
for (i=0;i<8;i++)
box_apeak_xy (7-i,0,0,i,7,7,1,1);
delay(speed);
if (i<7)
box_apeak_xy (3,4,0,i,7,7,1,0);
break;
case 3:
for (i=0;i<8;i++)
delay(speed);
if (i<7)
box_apeak_xy (4,4,0,7,7-i,7,1,0);
break;
case 0:
for (i=0;i<8;i++)
delay(speed);
if (i<7)
box_apeak_xy (4,3,0,7-i,0,7,1,0);
void trans(uchar z,uint speed)
uchar i,j;
for (j=0;j<8;j++)
for (i=0;i<8;i++)
display[z][i]>>=1;
delay(speed);//亮的時間
void tranoutchar(uchar c,uint speed)
uchar i,j,k,a,i2=0;
for (i=0;i<8;i++)
if (i<7)
box_apeak_xy (i+1,0,0,i+1,7,7,1,1);
box_apeak_xy (i2,0,0,i2,7,7,1,0);
a=0;
i2=i+1;
for (j=0;j<=i;j++)
a=a|(1<<j);
for (k=0;k<8;k++)
display[k][3]|=table_cha[c][k]&a;
display[k][4]|=table_cha[c][k]&a;
delay(speed);
/*64個數據依次放入數組disply中*/
void transss()
uchar i,j;
for (i=0;i<8;i++)
for (j=0;j<8;j++)
display[i][j]<<=1;
void flash_1()
clear(0);
type(1,4);//定位1顯示到第四排
delay(60000);
type(2,4);//定位2顯示到第四排
delay(60000);
type(3,4);//定位3顯示到第四排
delay(60000);
type(4,4);//定位4顯示到第四排
delay(60000);
type(5,4);//定位大寫字母I顯示到第四排
delay(60000);
type(6,4);//定位“心”顯示到第四排
delay(60000);
type(7,4);//定位大寫字母U顯示到第四排
delay(60000);
delay(60000);
clear(0);
rolldisplay(30000);
type(0,7);
delay(60000);
trailler(6000);
delay(60000);
void flash_2()
uchar i;
/* for (i=129;i>0;i--)//此處為2個為1組,一起閃。走一圈
cirp(i-2,0,1);
delay(8000);
cirp(i-1,0,0);
delay(8000);
for (i=0;i<136;i++)//此處為8個為一組亮136 = 128 + 8;走一圈。
cirp(i,1,1);
delay(8000);
cirp(i-8,1,0);
delay(8000); */
for (i=129;i>0;i--)//此處為走一圈亮一圈
cirp(i-2,0,1);
delay(8000);
delay(8000);
for (i=0;i<128;i++)//此處為滅一圈
cirp(i-8,1,0);
delay(8000);
delay(60000);
void flash_3()
char i;
for(i=0;i<8;i++)
box_apeak_xy(0,i,0,7,i,7,1,1);//0層-6層以delay(20000)的依次亮。
delay(20000);
if(i<7)
box_apeak_xy(0,i,0,7,i,7,1,0);//到第7層時就到下一個for語句。
for (i=7;i>=0;i--)
box_apeak_xy(0,i,0,7,i,7,1,1);//7層-1層以delay(20000)的依次亮。
delay(20000);
if (i>0)
box_apeak_xy(0,i,0,7,i,7,1,0);//到第0層時就到下一個for語句。
for (i=0;i<8;i++)//傾斜的亮(每層只有一排亮,依次錯開)
delay(20000);
if (i<7)
void flash_4()//向內凹陷和向外凹陷的顯示
char i,j,an[8];
for(j=7;j<15;j++)
an[j-7]=j;//裝入0-7值
for(i=0;i<=16;i++)
for(j=0;j<8;j++)
if((an[j]<8)&(an[j]>=0))
line(0,an[j],j,7,an[j],j,1);
for(j=0;j<8;j++)
if(((an[j]+1)<8)&(an[j]>=0))
line(0,an[j]+1,j,7,an[j]+1,j,0);
for (j=0;j<8;j++)
if (an[j]>0)
an[j]--;
delay(15000);
for(j=0;j<8;j++)
an[j]=1-j;
for(i=0;i<=16;i++)
for(j=0;j<8;j++)
for(j=0;j<8;j++)
if(((an[j]-1)<7)&(an[j]>0))
line(0,an[j]-1,j,7,an[j]-1,j,0);
for(j=0;j<8;j++)
if(an[j]<7)
an[j]++;
delay(15000);
void flash_5()
uint a=15000;//a=delay
char i=8,j,an[4];
//1 1-4為4個面循環的轉。
for (j=7;j<11;j++)
an[j-7]=j;
while(i--)
for (j=0;j<4;j++)
if (an[j]<8)
box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
if (an[j]<7)
box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
for (j=0;j<4;j++)
if (an[j]>3)
an[j]--;
delay(a);
//2
i=3;
for (j=0;j<4;j++)
an[j]=5-j;
while(i--)
for (j=1;j<4;j++)
if (an[j]<4)
if (an[j]<3)
for (j=0;j<4;j++)
if (an[j]>0)
an[j]--;
delay(a);
//3
i=3;
for (j=1;j<4;j++)
an[j]=4-j;
while(i--)
for (j=1;j<4;j++)
if (an[j]>=0)
if (an[j]>0)
box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
for (j=1;j<4;j++)
if (an[j]<3)
an[j]++;
delay(a);
//4
i=3;
for (j=0;j<4;j++)
an[j]=j+1;
while(i--)
for (j=1;j<4;j++)
if (an[j]>3)
if (an[j]>3)
for (j=0;j<4;j++)
an[j]++;
delay(a);
//5
i=3;
for (j=3;j<6;j++)
an[j-2]=j;
while(i--)
for (j=1;j<4;j++)
for (j=0;j<4;j++)
if (an[j]>3)
an[j]--;
delay(a);
//6
i=3;
for (j=0;j<4;j++)
an[j]=5-j;
while(i--)
for (j=1;j<4;j++)
if (an[j]<4)
if (an[j]<3)
for (j=0;j<4;j++)
if (an[j]>0)
an[j]--;
delay(a);
//7
i=3;
for (j=0;j<4;j++)
an[j]=3-j;
an[0]=2;
while(i--)
for (j=0;j<3;j++)
if (an[j]>=0)
if (an[j]>=0)
for (j=0;j<4;j++)
if (j<5-i)
an[j]--;
delay(a);
//8
i=10;
for (j=0;j<4;j++)
an[j]=j-2;
while(i--)
for (j=0;j<4;j++)
if (an[j]>=0)
if (an[j]>=0)
for (j=0;j<4;j++)
if (an[j]<7)
an[j]++;
delay(a);
/*void flash_6()
uchar i,j,k,z;
roll_apeak_yz(1,10000);
roll_apeak_yz(2,10000);
roll_apeak_yz(3,10000);
roll_apeak_yz(0,10000);
for (i=0;i<3;i++)
for (j=0;j<8;j++)
for (k=0;k<8;k++)
if ((table_3p[i][j]>>k)&1)
for (z=1;z<8;z++)
point (j,7-k,z,1);
if (z-1)
point (j,7-k,z-1,0);
delay(5000);
trans(7,15000);
void flash_7()
uchar i;
uint a=3000;
roll_apeak_xy(0,10000);
roll_apeak_xy(1,10000);
roll_apeak_xy(2,10000);
roll_apeak_xy(3,10000);
for (i=0;i<8;i++)
box_apeak_xy (0,i,0,7-i,i,7,1,1);
delay(a);
delay(30000);
roll_3_xy(0,a);
delay(30000);
roll_3_xy(1,a);
delay(30000);
roll_3_xy(2,a);
delay(30000);
roll_3_xy(3,a);
delay(30000);
roll_3_xy(0,a);
delay(30000);
roll_3_xy(1,a);
delay(30000);
roll_3_xy(2,a);
delay(30000);
roll_3_xy(3,a);
for (i=7;i>0;i--)
box_apeak_xy(i,0,0,i,7,7,1,0);
delay(a);
void flash_8()
uchar i;
for (i=5;i<8;i++)
tranoutchar(i,10000);
delay(60000);
delay(60000);
void flash_9()
char i;
uchar j,an[8],x,y,t,x1,y1;
for (i=0;i<8;i++)
box_apeak_xy (i,0,0,i,7,7,1,1);
if (i)
box_apeak_xy (i-1,0,0,i-1,7,7,1,0);
delay(10000);
for (i=0;i<7;i++)
line(6-i,6-i,0,6-i,6-i,7,1);
delay(10000);
for (i=0;i<8;i++)
an[i]=14;
for (i=0;i<85;i++)
clear(0);
for (j=0;j<8;j++)
t=an[j]%28;
x=dat2[t]>>5;
y=(dat2[t]>>2)&0x07;
t=(an[j]-14)%28;
x1=dat2[t]>>5;
y1=(dat2[t]>>2)&0x07;
line(x,y,j,x1,y1,j,1);
for (j=0;j<8;j++)
if ((i>j)&(j>i-71))
an[j]++;
delay(5000);
for (i=0;i<85;i++)
clear(0);
for (j=0;j<8;j++)
t=an[j]%28;
x=dat2[t]>>5;
t=(an[j]-14)%28;
x1=dat2[t]>>5;
for (j=0;j<8;j++)
if ((i>j)&(j>i-71))
an[j]--;
delay(5000);
for (i=0;i<29;i++)
clear(0);
t=an[0]%28;
x=dat2[t]>>5;
t=(an[0]-14)%28;
x1=dat2[t]>>5;
box_apeak_xy(x,y,0,x1,y1,7,0,1);
box_apeak_xy(x,y,1,x1,y1,6,0,1);
an[0]++;
delay(5000);
for (i=0;i<16;i++)
clear(0);
t=an[0]%28;
x=dat2[t]>>5;
t=(an[0]-14)%28;
x1=dat2[t]>>5;
box_apeak_xy(x,y,0,x1,y1,7,1,1);
an[0]--;
delay(5000);
for (i=0;i<8;i++)
line(i,i,0,0,0,i,0);
delay(5000);
for (i=1;i<7;i++)
line(i,i,7,7,7,i,0);
delay(5000);
for (i=1;i<8;i++)
clear(0);
box(7,7,7,7-i,7-i,7-i,0,1);
delay(10000);
for (i=1;i<7;i++)
clear(0);
box(0,0,0,7-i,7-i,7-i,0,1);
delay(10000);
for (i=1;i<8;i++)
clear(0);
box(0,0,0,i,i,i,0,1);
delay(10000);
for (i=1;i<7;i++)
clear(0);
box(7,0,0,i,7-i,7-i,0,1);
delay(10000);
for (i=1;i<8;i++)
box(7,0,0,7-i,i,i,1,1);
delay(10000);
for (i=1;i<7;i++)
clear(0);
box(0,7,7,7-i,i,i,1,1);
delay(10000);
void flash_10()
uchar i,j,an[4],x,y,t;
for (i=1;i<7;i++)
clear(0);
box(0,6,6,1,7,7,1,1);
box(i,6,6-i,i+1,7,7-i,1,1);
box(i,6,6,i+1,7,7,1,1);
box(0,6,6-i,1,7,7-i,1,1);
box(0,6-i,6,1,7-i,7,1,1);
box(i,6-i,6-i,i+1,7-i,7-i,1,1);
box(i,6-i,6,i+1,7-i,7,1,1);
box(0,6-i,6-i,1,7-i,7-i,1,1);
delay(30000);
for (i=0;i<4;i++)
an[i]=6*i;
for (i=0;i<35;i++)
clear(0);
for(j=0;j<4;j++)
t=an[j]%24;
x=dat3[t]>>4;
y=dat3[t]&0x0f;
box(x,y,0,x+1,y+1,1,1,1);
box(x,y,6,x+1,y+1,7,1,1);
for (j=0;j<4;j++)
an[j]++;
delay(10000);
for (i=0;i<35;i++)
clear(0);
for(j=0;j<4;j++)
t=an[j]%24;
x=dat3[t]>>4;
y=dat3[t]&0x0f;
for (j=0;j<4;j++)
an[j]--;
delay(10000);
for (i=0;i<35;i++)
clear(0);
for(j=0;j<4;j++)
t=an[j]%24;
x=dat3[t]>>4;
y=dat3[t]&0x0f;
box(x,0,y,x+1,1,y+1,1,1);
box(x,6,y,x+1,7,y+1,1,1);
for (j=0;j<4;j++)
an[j]++;
delay(10000);
for (i=0;i<36;i++)
clear(0);
for(j=0;j<4;j++)
t=an[j]%24;
x=dat3[t]>>4;
y=dat3[t]&0x0f;
for (j=0;j<4;j++)
an[j]--;
delay(10000);
for (i=6;i>0;i--)
clear(0);
delay(30000);
void flash_11()
uchar i,j,t,x,y;
uchar code daa[13]={0,1,2,0x23,5,6,7,6,5,0x23,2,1,0};
for (j=0;j<5;j++)
for (i=0;i<13;i++)
if (daa[i]>>4)
t=daa[i]&0x0f;
line (0,0,t+1,0,7,t+1,1);
t=daa[i];
line (0,0,t,0,7,t,1);
transss();
delay(10000);
for (j=1;j<8;j++)
if (j>3)
t=4;
t=j;
for (i=0;i<24;i+=j)
x=dat3[i]>>4;
y=dat3[i]&0x0f;
box_apeak_xy(0,x,y,0,x+1,y+1,1,1);
transss();
delay(10000);
for (j=1;j<8;j++)
if (j>3)
t=4;
t=j;
for (i=0;i<24;i+=j)
x=dat3[i]>>4;
y=dat3[i]&0x0f;
point (0,x,y,1);
transss();
delay(10000);
sinter();
while(1){
// clear(0);
/*play list*/
flash_1();
clear(0);
flash_2();
flash_3();
flash_4();
flash_4();
flash_5();
flash_5();
// flash_6();
// flash_7();
flash_8();
flash_9();
flash_10();
clear (0);
flash_11();
flash_9();
flash_5();
// flash_7();
flash_5();
// flash_6();
flash_8();
flash_9();
flash_10();
//P0; //573 in
//P1; //uln2803
//P2; //573 LE
void print() interrupt 1
uchar i;
static uchar layer=0;
P1=0;
for (i=0;i<8;i++)
P2=1<<i;
delay(3);
P0=display[layer][i];
delay(3);
P1=1<<layer;
if (layer<7)
layer++;
layer=0;
TH0=0xF5;
TL0=0;
光立方程序.zip
2016-3-30 17:05 上傳
85.65 KB, 下載次數: 53, 下載積分: 黑幣 -5
DIY光立方設計
ilylyp
2016-10-7 13:21
牛人 這程序不錯 收下了
953791924
2017-3-20 22:07
真真厲害我也想做一個。
黑boy
2017-5-17 20:59
這個用89C52就能做嗎?
stc507811
2018-4-26 19:35
心累 B 下載了 唉
