標題: vc++多線程程序的基本編寫方法 [打印本頁]
作者: 51黑fan    時間: 2016-1-31 02:51
多線程方法:
#include <afxmt.h> //  ①=======》多線程頭文件
CMutex mutex;                //互斥量對象(全局)
static HANDLE  thr1;//②=======》定義線程句柄
static HANDLE  thr2;//
UINT ThreadProcWrite(LPVOID param)  //void *pi
        srand(time(NULL));                        //③=========>線程1 回調函數
        CWnd *wn=(CWnd *)param;
        CDC *dc=wn->GetDC();
        int xx,yy;
        RECT rec;
        wn->GetClientRect(&rec);
        while(true)
                CSingleLock singleLock(&mutex);//單線程鎖定變量
        //        singleLock.Lock();
                xx=rand()%rec.right;
                yy=rand()%rec.bottom;
                dc->Ellipse(xx-20,yy-20,xx+20,yy+20);
                dc->MoveTo(xx,yy);
                dc->LineTo(xx,yy-40);
                dc->MoveTo(xx,yy);
                dc->LineTo(xx,yy+40);
                dc->MoveTo(xx,yy);
                dc->LineTo(xx-40,yy);
                dc->MoveTo(xx,yy);
                dc->LineTo(xx+40,yy);
                //Sleep(300);                //阻塞線程一定時間
        //        singleLock.Unlock();                //互斥量解鎖
        wn->ReleaseDC(dc);
        return 0;
UINT ThreadProcRead(LPVOID param)//=========>線程2 回調函數
        srand(time(NULL));
        int xx,yy;
        RECT rec;
        while(true)
                dc->Rectangle(xx-20,yy-20,xx+20,yy+20);
                dc->MoveTo(xx-20,yy-20);
                dc->LineTo(xx+20,yy+20);
                dc->MoveTo(xx-20,yy+20);
                dc->LineTo(xx+20,yy-20);
                //singleLock.Unlock();                //互斥量解鎖
        wn->ReleaseDC(dc);
        return 0;
void Ca002View::OnThread1()//④==========>開啟線程1
        // TODO: 在此添加命令處理程序代碼
        CWinThread* pThread;//MFC
        pThread = AfxBeginThread(ThreadProcWrite, this,THREAD_PRIORITY_LOWEST,0,CREATE_SUSPENDED);//開始寫線程
        thr1 = pThread->m_hThread;//獲取線程1句柄,用于結束該線程
        //SetThreadPriority(g_WriteHnd,THREAD_PRIORITY_LOWEST);
        pThread->ResumeThread();
void Ca002View::OnThread2()//④========>開啟線程2
        pThread = AfxBeginThread(ThreadProcRead, this);
        thr2 = pThread->m_hThread;//獲取線程2句柄,用于結束該線程
void Ca002View::OnEnd1()// ⑤END========》結束線程1
        TerminateThread(thr1, 0);//結束線程1
void Ca002View::OnEnd2()// ⑤END========》結束線程2
        TerminateThread(thr2, 0);//結束線程2
