標(biāo)題: stm32代碼升級總結(jié) [打印本頁]
作者: 51heisex 時間: 2016-1-23 01:05
看了那么多stm32代碼升級的教程,有兩個疑點(diǎn):1,修改中斷向量表偏移是bootloader修還是app代碼要修?
答:app代碼
2:,修改rom的起始地址或RAM的地址在哪里?
答:app代碼
3,bootloader代碼干啥?
答:就寫段程序就行。
intmain(void)
u8t,key;
u16oldcount=0; //老的串口接收數(shù)據(jù)值
u16applenth=0; //接收到的app代碼長度
u8clearflag=0;
uart_init(256000); //串口初始化為256000
delay_init(); //延時初始化
LCD_Init(); //液晶初始化
LED_Init(); //初始化與LED連接的硬件接口
KEY_Init(); //按鍵初始化
POINT_COLOR=RED;//設(shè)置字體為紅色
LCD_ShowString(60,50,200,16,16,"WarshipSTM32");
LCD_ShowString(60,70,200,16,16,"IAPTEST");
LCD_ShowString(60,90,200,16,16,"ATOM@ALIENTEK");
LCD_ShowString(60,110,200,16,16,"2012/9/24");
LCD_ShowString(60,130,200,16,16,"WK_UP:CopyAPP2FLASH");
LCD_ShowString(60,150,200,16,16,"KEY1:EraseSRAM APP");
LCD_ShowString(60,170,200,16,16,"KEY0:RunSRAM APP");
LCD_ShowString(60,190,200,16,16,"KEY2:RunFLASH APP");
POINT_COLOR=BLUE;
//顯示提示信息
POINT_COLOR=BLUE;//設(shè)置字體為藍(lán)色
if(USART_RX_CNT)
if(oldcount==USART_RX_CNT)
//新周期內(nèi),沒有收到任何數(shù)據(jù),認(rèn)為本次數(shù)據(jù)接收完成.
applenth=USART_RX_CNT;
oldcount=0;
USART_RX_CNT=0;
printf("用戶程序接收完成!\r\n");
printf("代碼長度:?ytes\r\n",applenth);
}elseoldcount=USART_RX_CNT;
t++;delay_ms(10);
if(t==30)
LED0=!LED0;t=0;
if(clearflag)
clearflag--;
if(clearflag==0)LCD_Fill(60,210,240,210+16,WHITE);//清除顯示
key=KEY_Scan(0);
if(key==KEY_UP)
if(applenth)
printf("開始更新固件...\r\n");
LCD_ShowString(60,210,200,16,16,"CopyingAPP2FLASH...");
if(((*(vu32*)(0X20001000+4))&0xFF000000)==0x08000000)
//判斷是否為0X08XXXXXX.
iap_write_appbin(FLASH_APP1_ADDR,USART_RX_BUF,
applenth);//更新FLASH代碼
LCD_ShowString(60,210,200,16,16,"CopyAPP Successed!!");
printf("固件更新完成!\r\n");
}else
LCD_ShowString(60,210,200,16,16,"IllegalFLASHAPP! ");
printf("非FLASH應(yīng)用程序!\r\n");
}else
printf("沒有可以更新的固件!\r\n");
LCD_ShowString(60,210,200,16,16,"NoAPP!");
clearflag=7;//標(biāo)志更新了顯示,并且設(shè)置7*300ms后清除顯示
if(key==KEY_DOWN)
if(applenth)
printf("固件清除完成!\r\n");
LCD_ShowString(60,210,200,16,16,"APPErase Successed!");
applenth=0;
}else
printf("沒有可以清除的固件!\r\n");
if(key==KEY_LEFT)
了解完上面的教程以后,開始動手實踐,但問題來了:
1,必須找一個能打開bin文件的軟件,如用ultraedit
2,將純數(shù)據(jù)的二進(jìn)制拷出來,然后用串口助手發(fā)送給單片機(jī)
3,發(fā)現(xiàn)升級失敗,后來發(fā)現(xiàn)從ultraedit里拷貝出來的數(shù)據(jù)每一行后面都有一個換行,所以拷貝到word里,將所有的換行去掉,因為一個換行就是一個字節(jié),盡管在用串口助手的HEX方式發(fā)送時,看不到那個換行的字節(jié),但是實驗發(fā)現(xiàn),是多一個字節(jié)的。
4,具體操作如下:
第一步:按Ctrl + H
第二步:在“查找內(nèi)容”后面,輸入:^p (注意,^就是數(shù)字6上面的那個符號,p是小寫的)
第三步:在“替換為”后面,不輸入任何內(nèi)容。
第四步:點(diǎn)“全部替換”。
5,發(fā)現(xiàn)好使。
