標題: 51單片機:從00到99,自動計數+蜂鳴器 [打印本頁]
作者: 51黑芯片    時間: 2016-1-17 01:16
  1. //從0到99計數
  2. #include <reg52.h>
  3. #define uint unsigned int
  5. sbit duan=P2^5;
  6. sbit wei=P2^6;
  7. sbit FM=P2^3;
  8. uchar bai,shi,ge,tt=0,temp;
  9. const unsigned char table[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E};
  10. void delay(uint x)
  11. {
  12. uint a,b;
  13. for(a=x;a>0;a--)
  14. for(b=110;b>0;b--);
  15. }
  16. void init()
  17. {
  18. TMOD=0x01;
  19. TH0=(65536-50000)/256;
  20. TL0=(65536-50000)%256;
  21. EA=1;
  22. ET0=1;
  23. TR0=1;
  24. }
  25. void disp(uchar shi,uchar ge)
  26. {
  27. duan=1;
  28. P0=table[shi];
  29. duan=0;
  30. wei=1;
  31. P0=0x4;
  32. wei=0;
  33. delay(1);
  34. duan=1;
  35. P0=table[ge];
  36. duan=0;
  37. wei=1;
  38. P0=0x08;
  39. wei=0;
  40. delay(1);
  41. }
  42. void didi(di_num)
  43. {
  44. uchar d;
  45. for(d=di_num;d>0;d--)
  46. {
  47. FM=0;
  48. delay(300);
  49. FM=1;
  50. delay(70);
  51. }
  52. }
  53. void main()
  54. {
  55. init();
  56. while(1)
  57. {
  58.    if(tt==20)
  59.      {
  60.       tt=0;                                          //清零,以便之后再次累計
  61.       temp++;
  62.       shi=temp/10;
  63.       ge=temp%10;
  64.       if(temp==100){didi(1);temp=0; }
  65.     }
  66. disp(shi,ge);    //這句放在上面的括號內會出現只顯法個位,十位百位均顯不出來
  67. }
  68. }
  69. void tming0() interrupt 1
  70. {
  71. TH0=(65536-50000)/256;
  72. TL0=(65536-50000)%256;
  73. tt++;
  74. }
