TIM2定時(shí)器中斷與中斷嵌套
51黑ren
時(shí)間:
2015-12-27 05:52
TIM2定時(shí)器中斷與中斷嵌套
#include "stm32f10x.h"
static __IO uint32_t TimingDelay; //__IO為volatile的宏定義
int8_t LED_Flag = 1; //LED燈翻轉(zhuǎn)標(biāo)志位
void GPIO_Config(void);
void EXIT_Config(void);
void TIM_Config(void);
void NVIC_Config(void);
void Delay(__IO uint32_t nTime);
main ()
GPIO_Config();
EXIT_Config();
TIM_Config();
NVIC_Config();
if (SysTick_Config(SystemCoreClock / 1000))
while (1);
while (1)
if (LED_Flag != 1)
GPIO_SetBits(GPIOG, GPIO_Pin_6); //setbits使能IO,當(dāng)前下指輸出(此時(shí)為滅)
GPIO_ResetBits(GPIOG, GPIO_Pin_6); //Resetbits屏蔽IO,當(dāng)前下指不輸出(此時(shí)為亮)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOG | RCC_AHB1Periph_GPIOA, ENABLE);
GPIO_StructInit(&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; //指定第六引腳
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //模式為輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //頻率為快速
GPIO_Init(GPIOG, &GPIO_InitStructure); //調(diào)用IO初始化函數(shù)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //指定第六引腳
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN; //模式為輸出
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //網(wǎng)上說要上拉,穩(wěn)定,我的沒有上拉也可以
GPIO_Init(GPIOA, &GPIO_InitStructure); //調(diào)用IO初始化函數(shù)
EXTI_InitTypeDef EXTI_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); //使能外部中斷復(fù)用時(shí)鐘
SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, GPIO_PinSource0);//選擇GPIOA的Pin0為EXTILine0
EXTI_ClearITPendingBit(EXTI_Line0); //清外部線路0中斷
EXTI_InitStructure.EXTI_Line = EXTI_Line0; //線路0
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; //觸發(fā)模式為中斷
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; //下降沿觸發(fā)
EXTI_InitStructure.EXTI_LineCmd = ENABLE; //開外部中斷
EXTI_Init(&EXTI_InitStructure);
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
TIM_DeInit(TIM2);
TIM_TimeBaseStructure.TIM_Period = 10000;
TIM_TimeBaseStructure.TIM_Prescaler = 8400;
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
TIM_ClearFlag(TIM2, TIM_FLAG_Update);
TIM_ITConfig(TIM2, TIM_IT_Update,ENABLE);
TIM_Cmd(TIM2, ENABLE);
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); //嵌套分組為組0,均為響應(yīng)優(yōu)先級
NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn; //中斷通道為通道0
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //搶斷優(yōu)先級為0
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //響應(yīng)優(yōu)先級為0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //開中斷
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
TimingDelay = nTime;
while (TimingDelay != 0);
void TimingDelay_Decrement(void)
if (TimingDelay != 0x00)
TimingDelay--;
