msp430g2553鬧鐘源程序
jialinx
2015-9-14 12:10
msp430g2553鬧鐘源程序
#include <msp430.h>
#include"config.h"
#include"1838.h"
#include"1602.h"
#include"dh11.h"
#include"ds3231.h"
#include"ta.h"
//#include"adc.h"
int main(void)
extern_12m();
hc164_init();
LCD_init();
h1838_init();
init_TA();
// I2cByteWrite(0xD0,0x0e,0);
// I2cByteWrite(0xD0,0x0f,0);
// ModifyTime(15,7,19,12,07,00);//初始化時鐘,2007/11/20,12/59/00
//小時采用24小時制
get_show_time();
get_show_Temperature();
dh11_read();
// adc_init();
_EINT();
while (1)
// LCD_disp_string(0,0,"I AM A BOY?");
// LCD_disp_string(0,1,"YOU ARE A GIRL!");
Red_Code();
Key_Icode(key_code[2]);
#include"config.h"
uchar change;
void extern_12m()
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
if (CALBC1_12MHZ==0xFF) // If calibration constant erased
while(1); // do not load, trap CPU!!
DCOCTL = 0; // Select lowest DCOx and MODx settings
BCSCTL1 = CALBC1_12MHZ;
DCOCTL = CALDCO_12MHZ; // Load 8MHz constants
void hc164_init()
P1OUT &= ~(BIT6+BIT7+BIT3); // Clear P1.0
P1DIR |=BIT6+BIT7+BIT3; // P1.0 output
P2OUT &= ~(BIT0+BIT1+BIT2); // Clear P1.0
P2DIR |=BIT0+BIT1+BIT2; // P1.0 output
void LCD_delay_10us(uint n) // - - 10微秒的延時子程序
uint i,j;
for(i=n;i>0;i--)
for(j=4;j>0;j--);
void sendbyte(uchar byte)
uchar c,num;
num=byte;
for(c=0;c<8;c++)
P1OUT&=~0x80;
CLK0;
P1OUT|=num&0x80; //(0x80即十進制的128, 二進制的10000000 按位發(fā)送
CLK1;
num<<=1;
// - - 向LCD1602寫指令
void LCD_write_command(uchar dat)
LCD_delay_10us(2);
LCD_RS_LOW; // - - 指令
//LCD_RW_LOW; // - - 寫入
sendbyte(dat);
LCD_delay_10us(2);
LCD_EN_HIGH; // - - 允許
LCD_delay_10us(2);
LCD_EN_LOW;
// - - 向LCD1602寫數(shù)據(jù)
void LCD_write_data(uchar dat)
LCD_delay_10us(2);
LCD_RS_HIGH;// - - 數(shù)據(jù)
//LCD_RW_LOW;// - - 寫入
sendbyte(dat);
LCD_delay_10us(2);
LCD_EN_HIGH;// - - 允許
LCD_delay_10us(2);
LCD_EN_LOW;
// - - 設(shè)置顯示位置
void LCD_set_xy(uchar x,uchar y)
uchar address;
if(y==1)
address=0x80+x; // - - 第一行位置
} else {
address=0xc0+x; // - - 第二行位置
// LCD_delay_10us(1);
LCD_write_command(address);
// - - 顯示一個字符函數(shù)
void LCD_disp_char(uchar x,uchar y,uchar dat) // - - LCD_disp_char(0,1,0x38); // - - 顯示8
LCD_set_xy(x,y);
LCD_write_data(dat);
// - - 顯示一個字符串函數(shù)
void LCD_disp_string(uchar x,uchar y,char *s)
LCD_set_xy(x,y);
while(*s!='\0')
LCD_write_data(*s);
s++;
void LCD_init(void)
LCD_delay_10us(20);
LCD_write_command(0x38); // - - 設(shè)置8位格式,2行,5x7
LCD_delay_10us(5);
LCD_write_command(0x0c); // - - 整體顯示,關(guān)光標,不閃爍
LCD_delay_10us(5);
LCD_write_command(0x06); // - - 設(shè)定輸入方式,增量不移位
LCD_delay_10us(5);
LCD_write_command(0x01); // - - 清除屏幕顯示
LCD_delay_10us(200);
#include"config.h"
#define IR_DIR_IN P2DIR&=~BIT3//紅外接收頭P1.0設(shè)置為輸入,
#define RED_R (P2IN&BIT3)//紅外接收頭輸入值
void h1838_init()
IR_DIR_IN;
uchar KEY_VAL;
uchar key_code[4],code_value;
void Red_Code()
uchar i,j,k = 0;
for(i = 0;i < 19;i++)
delay_us(400); //延時400us
if(RED_R) //9ms內(nèi)有高電平,則判斷為干擾,退出處理程序
return;
while(!RED_R); //等待9ms低電平過去
for(i=0;i<5;i++) //是否連發(fā)碼
delay_us(500);
if(!RED_R)
return;
while(RED_R); //等待4.5ms高電平過去
for(i = 0;i < 4;i++) //接收4個字節(jié)的數(shù)據(jù)
for(j = 0;j < 8;j++) //每個字節(jié)的數(shù)據(jù)8位
while(!RED_R); //等待變高電平
while(RED_R) //計算高電平時間
delay_us(100);
k++;
if(k >22) //高電平時間過長,則退出處理程序
return;
code_value>>=1; //接受一位數(shù)據(jù)
if(k >= 7)
code_value|=0x80; //高電平時間大于0.56,則為數(shù)據(jù)1
k = 0; //計時清零
key_code[i]=code_value; //四個字節(jié)的數(shù)據(jù)
// Key_Icode(); //調(diào)用賦值函數(shù)
// Display_Key(KEY_VAL); //顯示按鍵值
// delay_ms(50);
#include <msp430.h>
#define ulong unsigned long
#define CLK0 P1OUT&=~BIT6
#define CLK1 P1OUT|=BIT6
#define LCD_EN_HIGH P2OUT|=BIT2 //拉高
#define LCD_EN_LOW P2OUT&=~BIT2 //拉低
#define LCD_RW_HIGH P2OUT|=BIT1 //拉高
#define LCD_RW_LOW P2OUT&=~BIT1 //拉低
#define LCD_RS_HIGH P2OUT|=BIT0 //拉高
#define LCD_RS_LOW P2OUT&=~BIT0 //拉低
#define CPU_F ((double)12000000) //外部高頻晶振8MHZ
//#define CPU_F ((double)32768) //外部低頻晶振32.768KHZ
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define KEY_0 0x16 //鍵0
#define KEY_1 0x0C //鍵1
#define KEY_2 0x18 //鍵2
#define KEY_3 0x5E //鍵3
#define KEY_4 0x08 //鍵4
#define KEY_5 0x1C //鍵5
#define KEY_6 0x5A //鍵6
#define KEY_7 0x42 //鍵7
#define KEY_8 0x52 //鍵8
#define KEY_9 0x4A //鍵9
#define prex 0x44 //電源
#define nex 0x40 //模式
#define play_pause 0x43 //靜音
#define ch_ 0x45 //模式
#define ch 0x46
#define cha 0x47 //模式
#define __ 0x07
#define _a 0x15
#define eq 0x09
#define _100a 0x19
#define _200a 0x0d
#define power 0x12 //power
#define up 0x1b //up
#define down 0x1a //down
#define left 0x04 //left
#define right 0x06 //right
#define ok 0x05 //0k
#include"config.h"
//連接端口
#define DHT11_Dir P1DIR
#define DHT11_In P1IN
#define DHT11_Out P1OUT
#define DHT11_Bit BIT0
char dh11_str[8];
//8bit濕度+8bit濕度小數(shù)點
//8bit溫度+8bit溫度小數(shù)點
//數(shù)據(jù)位為0是高電平26~28us | 1高電平70us
uchar DHT11_Data[5] = {0}; //從DHT11中讀到的數(shù)據(jù)
void read_DHT11(uchar *Data)
uchar re,m,n,Time_out;
DHT11_Dir &= (~DHT11_Bit); //引腳為輸入
for(n = 0; n < 5; n++)
for(m = 0; m < 8; m++)
while( !(DHT11_In & DHT11_Bit) ); //每1bit以50us低電平時限開始,直到高電平到來
delay_us(30);
re = 0;
if((DHT11_In & DHT11_Bit)) //30us后還是高電平說明是1
re = 1;
Time_out = 2;
while((DHT11_In & DHT11_Bit) && (Time_out++ ));
if(Time_out == 1) //超時處理
break;
*Data <<= 1;
if(re)
*Data |= 0x01;
Data++;
//DHT11的握手協(xié)議模擬和數(shù)據(jù)的讀取
uchar DHT11_GetData(void)
uchar o,sum;
DHT11_Dir |= DHT11_Bit;
DHT11_Out &= ~DHT11_Bit; //拉低,發(fā)出開始信號
delay_ms(18); //拉低18ms
DHT11_Out |= DHT11_Bit; //拉高20us等待
delay_us(20);
if( !(DHT11_In & DHT11_Bit) ) //DHT11響應
while( !(DHT11_In & DHT11_Bit) ); //80us低電平,等待DHT11的響應信號
while( (DHT11_In & DHT11_Bit) ); //DHT11準備發(fā)送數(shù)據(jù)
read_DHT11(DHT11_Data); //主機接收數(shù)據(jù)
sum = 0;
for(o = 0; o < 4; o++) //數(shù)據(jù)校驗
sum += DHT11_Data[o];
if(sum != DHT11_Data[4])
return 0;
return 1;
return 0;
//對溫度濕度進行格式化(如果獲取溫度成功)
void DHT11_format(char *Des_str)
Des_str[0] = DHT11_Data[0]/10 + 0x30;
Des_str[1] = DHT11_Data[0]%10 + 0x30;
Des_str[2] = '%';
Des_str[3] = ' ';
Des_str[4] = DHT11_Data[2]/10 + 0x30;
Des_str[5] = DHT11_Data[2]%10 + 0x30;
Des_str[6] = 'C';
Des_str[7] = ' ';
void dh11_read()
if(DHT11_GetData())
DHT11_format(dh11_str);
LCD_disp_string(0,0,dh11_str);
#include"config.h"
#define SDA_DIR_OUT P1DIR|=BIT4
#define SDA_DIR_IN P1DIR&=~BIT4
#define SCL_DIR_OUT P1DIR|=BIT5
#define SDA_IN P1IN&BIT4
#define SDA1 P1OUT|=BIT4
#define SDA0 P1OUT&=~BIT4
#define SCL1 P1OUT|=BIT5
#define SCL0 P1OUT&=~BIT5
uchar year,month,date,hour,minute,second;
uchar const table[]={'0','1','2','3','4','5','6','7','8','9'};
uchar const month_12[]={31,29,31,30,31,30,31,31,30,31,30,31};
uchar clockset,clockon,clockoff[5],clock_on;
uchar oclock[5][2];
uchar BCD2HEX(uchar val) //BCD轉(zhuǎn)換為Byte
uchar temp;
temp=val&0x0f;
val>>=4;
val&=0x0f;
val*=10;
temp+=val;
return temp;
uchar HEX2BCD(uchar val) //B碼轉(zhuǎn)換為BCD碼
uchar i,j,k;
i=val/10;
j=val%10;
k=j+(i<<4);
return k;
void Start_I2C()
SDA_DIR_OUT;
SCL_DIR_OUT;
SDA1; //發(fā)送起始條件的數(shù)據(jù)信號
delay_us(5);
SCL1;
delay_us(5); //起始條件建立時間大于4.7us,延時
SDA0; //發(fā)送起始信號
delay_us(5); // 起始條件鎖定時間大于4μs
// SCL0; //鉗住I2C總線,準備發(fā)送或接收數(shù)據(jù)
// delay_us(2);
void Stop_I2C()
SDA_DIR_OUT;
SCL_DIR_OUT;
SDA0; //發(fā)送結(jié)束條件的數(shù)據(jù)信號
delay_us(5); //發(fā)送結(jié)束條件的時鐘信號
SCL1; //結(jié)束條件建立時間大于4us
delay_us(5);
SDA1; //發(fā)送I2C總線結(jié)束信號
delay_us(1);
void SendByte(uchar c)
uchar BitCnt;
SDA_DIR_OUT;
SCL_DIR_OUT;
SCL0;
delay_us(10);
for(BitCnt=0;BitCnt<8;BitCnt++) //要傳送的數(shù)據(jù)長度為8位
if(c&0x80)
SDA1; //判斷發(fā)送位
SDA0;
delay_us(1);
SCL0; //置時鐘線為高,通知被控器開始接收數(shù)據(jù)位
delay_us(1); //保證時鐘高電平周期大于4μs
SCL1;
delay_us(5);
c=c<<1;
delay_us(5);
SDA1; //8位發(fā)送完后釋放數(shù)據(jù)線,準備接收應答位
delay_us(1);
SCL0;
delay_us(1);
SCL1;
delay_us(1);
SCL0;
uchar ReceiveByte(uchar b)
uchar i;
uchar temp;
uchar Dat=0;
SDA_H;
delay(5);
SCL_L;
delay(5);
SDA_DIR_IN;
for(i=0;i<8;i++)
SCL1;
delay_us(5);
Dat=Dat<<1;
delay_us(1);
temp=SDA_IN;
if(temp&0x10)
Dat|=0x01;
Dat|=0x00;
delay_us(1);
SCL0;
delay_us(5);
SDA_DIR_OUT;
if(b)//每收一個數(shù)后發(fā)送ACK或nACK
SDA1;
SDA0;
delay_us(1);
SCL1;
delay_us(1);
SCL0;
delay_us(1);
SDA1; //釋放總線
delay_us(1);
return Dat;
/***********將一個字節(jié)寫入DS3231指定的地址***********/
void I2cByteWrite(uchar device,uint addr,uchar bytedata)
Start_I2C();
// delay_us(1);
SendByte(device);
// delay_us(1);
SendByte(addr);
// delay_us(1);
SendByte(bytedata);
// delay_us(1);
Stop_I2C();
/************從DS3231指定的地址讀一個字節(jié)************/
uchar I2cByteRead(uchar device,uint addr)
uchar Dat=0;
Start_I2C();
SendByte(device);
// delay_us(1);
SendByte(addr);
// delay_us(1);
Start_I2C();
SendByte(0xd1);//讀數(shù)
// delay_us(1);
Dat=ReceiveByte(1);//只接收一個字節(jié),所以發(fā)nACK
Stop_I2C();
return Dat;
/*********************讀取時間**********************/
void Readtime(void)
year=I2cByteRead(0xd0,0x06); //年
month=I2cByteRead(0xd0,0x05); //月
date=I2cByteRead(0xd0,0x04); //日
hour=I2cByteRead(0xd0,0x02); //時
minute=I2cByteRead(0xd0,0x01);//分
second=I2cByteRead(0xd0,0x00);//秒
/****************修改時間,BCD碼輸入*****************/
void ModifyTime(uchar yea,uchar mon,uchar da,uchar hou,uchar min,uchar sec)
uchar temp=0;
temp=HEX2BCD(yea);
I2cByteWrite(0xD0,0x06,temp);//修改年
temp=HEX2BCD(mon);
I2cByteWrite(0xD0,0x05,temp);//修改月
temp=HEX2BCD(da);
I2cByteWrite(0xD0,0x04,temp);//修改日
temp=HEX2BCD(hou);
I2cByteWrite(0xD0,0x02,temp);//修改時
temp=HEX2BCD(min);
I2cByteWrite(0xD0,0x01,temp);//修改分
temp=HEX2BCD(sec);
I2cByteWrite(0xD0,0x00,temp);//修改秒
/****************讀取時間 計算 并顯示****************/
void get_show_time(void)
uchar temp1,temp2;
char a[2];
temp1=I2cByteRead(0xd0,0x06); //年
temp2=BCD2HEX(temp1);
a[0]=table[temp2/10];
a[1]=table[temp2%10];
LCD_disp_string(0,1,a);
LCD_disp_char(2,1,'-');
temp1=I2cByteRead(0xd0,0x05); //月
LCD_disp_string(3,1,a);
LCD_disp_char(5,1,'-');
temp1=I2cByteRead(0xd0,0x04); //日
LCD_disp_string(6,1,a);
LCD_disp_char(8,1,'-');
temp1=I2cByteRead(0xd0,0x03); //星期
temp2=table[temp2];
LCD_disp_char(9,1,temp2);
LCD_disp_char(10,1,' ');
LCD_disp_char(8,0,' ');
if(clockset==0)
temp1=I2cByteRead(0xd0,0x02); //時 24小時制
temp1&=0x3f;
LCD_disp_string(8,0,a);
LCD_disp_char(10,0,':');
temp1=I2cByteRead(0xd0,0x01); //分
LCD_disp_string(11,0,a);
LCD_disp_char(13,0,':');
temp1=I2cByteRead(0xd0,0x00); //秒
LCD_disp_string(14,0,a);
if(clockset!=0)
LCD_disp_string(8,0," ");
a[0]=table[oclock[clockset-1][0]/10];
a[1]=table[oclock[clockset-1][0]%10];
LCD_disp_char(10,0,'-');
a[0]=table[oclock[clockset-1][1]/10];
a[1]=table[oclock[clockset-1][1]%10];
LCD_disp_string(13,0,"CK");
LCD_disp_char(15,0,table[clockoff[clockset-1]]);
//顯示溫度
void get_show_Temperature(void)
if(change==0)
uchar Ttemp1,Ttemp2;
char a[2];
Ttemp1=I2cByteRead(0xd0,0x11); //溫度 高字節(jié)
Ttemp2=BCD2HEX(Ttemp1);
// LCD_disp_string(9,1," ");
// Ttemp3=I2cByteRead(0xd0,0x12); //溫度低字節(jié)
// Ttemp4=BCD2HEX(Ttemp3);
a[0]=table[Ttemp2/10];
a[1]=table[Ttemp2%10];
LCD_disp_string(13,1,a);
LCD_disp_char(15,1,'c');
if(change!=0)
LCD_disp_string(13,1," ");
LCD_disp_char(15,1,table[change-1]);
if((clockset!=0)&&(change==0))
LCD_disp_char(13,1,table[clockset]);
LCD_disp_char(15,1,table[clockon]);
void change_del()
uchar temp1,temp2,temp3,temp4;
if(change>0)
temp1=I2cByteRead(0xd0,change-1);
temp2-=1;
if(change<3)
if(temp2>59)
temp2=59;
if(change==3)
if(temp2>23)
temp2=23;
if(change==4)
if(temp2==0)
temp2=7;
if(change==5)
if(temp2==0)
temp3=I2cByteRead(0xd0,0x05);
temp4=BCD2HEX(temp3);
temp2=month_12[temp4-1];
if(change==6)
if(temp2==0)
temp2=12;
temp2=HEX2BCD(temp2);
I2cByteWrite(0xD0,change-1,temp2);//修改年
void change_add()
if(change>0)
temp2+=1;
if(change<3)
if(temp2>59)
temp2=0;
if(change==3)
if(temp2>23)
temp2=0;
if(change==4)
if(temp2==8)
temp2=1;
if(change==5)
if(temp2>month_12[temp4-1])
temp2=1;
if(change==6)
if(temp2==13)
temp2=1;
void change_set()
++change;
if(change>=8)
change=0;
void clock_set()
++clockset;
if(clockset>=6)
clockset=0;
void clock_add()
change=0;
++clockon;
if( clockon==3)
clockon=0;
void clock_change()
if(clockon==1)
++oclock[clockset-1][1];
if(oclock[clockset-1][1]>59)
oclock[clockset-1][1]=0;
if(clockon==2)
++oclock[clockset-1][0];
if(oclock[clockset-1][0]>23)
oclock[clockset-1][0]=0;
void Key_Icode(uchar dat)
// LCD_disp_string(10,1," ");
switch(dat) //第3個字節(jié)是數(shù)據(jù),第4個字節(jié)是反碼
{ //為了更穩(wěn)定,可以加上第4個字節(jié)數(shù)據(jù)的判斷
case KEY_0:KEY_VAL=0; LCD_disp_char(11,1,KEY_VAL+0x30); LCD_disp_char(12,1,' '); break;
case KEY_1:KEY_VAL=1; LCD_disp_char(11,1,KEY_VAL+0x30); LCD_disp_char(12,1,' '); break;
case KEY_2:KEY_VAL=2; LCD_disp_char(11,1,KEY_VAL+0x30); LCD_disp_char(12,1,' '); break;
case KEY_3:KEY_VAL=3; LCD_disp_char(11,1,KEY_VAL+0x30); LCD_disp_char(12,1,' ');break;
case KEY_4:KEY_VAL=4; LCD_disp_char(11,1,KEY_VAL+0x30); LCD_disp_char(12,1,' ');break;
case KEY_5:KEY_VAL=5; LCD_disp_char(11,1,KEY_VAL+0x30); LCD_disp_char(12,1,' ');break;
case KEY_6:KEY_VAL=6; LCD_disp_char(11,1,KEY_VAL+0x30); LCD_disp_char(12,1,' ');break;
case KEY_7:KEY_VAL=7; LCD_disp_char(11,1,KEY_VAL+0x30); LCD_disp_char(12,1,' ');break;
case KEY_8:KEY_VAL=8; LCD_disp_char(11,1,KEY_VAL+0x30); LCD_disp_char(12,1,' ');break;
case KEY_9:KEY_VAL=9; LCD_disp_char(11,1,KEY_VAL+0x30); LCD_disp_char(12,1,' ');break;
case prex:LCD_disp_string(11,1,"PR");clock_change();break;
case nex :LCD_disp_string(11,1,"NX");clock_add();break;
case play_pause:LCD_disp_string(11,1,"PS");clock_set();break;
case ch_: LCD_disp_string(11,1,"C-");change_del();break;
case ch: LCD_disp_string(11,1,"CH");change_set();break;
case cha:LCD_disp_string(11,1,"C+");change_add();break;
case eq: LCD_disp_string(11,1,"EQ");
if(clockoff[clockset-1]==0)
clockoff[clockset-1]=1;
else clockoff[clockset-1]=0;
break;
case _a:LCD_disp_string(11,1,"V+");break;
case __:LCD_disp_string(11,1,"V-");break;
case _100a:LCD_disp_string(11,1,"1+");break;
case _200a:LCD_disp_string(11,1,"2+");break;
case power:LCD_disp_string(11,1,"PW");break;
case up: LCD_disp_string(11,1,"UP");break;
case down:LCD_disp_string(11,1,"DW");break;
case left:LCD_disp_string(11,1,"LF");break;
case right:LCD_disp_string(11,1,"RT");break;
case ok:LCD_disp_string(11,1,"OK");break;
default:KEY_VAL=' ';break;
key_code[2]=' ';
void oclockon()
uchar clock_flag[5];
uchar temp1,temp2,temp3;
temp1&=0x3f;
temp3=BCD2HEX(temp1);
uchar i;
for(i=0;i<5;i++)
if(temp2==oclock[i][0])
if(temp3==oclock[i][1])
if(clockoff[i]==1)
clock_flag[i]=1;
else clock_flag[i]=0;
clock_on=0;
for(i=0;i<5;i++)
if(clock_flag[i]==1)
clock_on=1;
#include"config.h"
uchar t;
/***********TA初始化*********/
void init_TA()
TACCTL0 = CCIE; // TACCR0 interrupt enabled
TACCR0 = 60000; //5ms中斷一次
TACTL = TASSEL_2 + MC_1; // SMCLK, upmode
#pragma vector=TIMER0_A0_VECTOR
__interrupt void Timer_A (void)
if(++t==200)
t=0;
dh11_read();
get_show_time();
oclockon();
if(clock_on==1)
P1OUT ^= 0x08;
