標題: IAR與STM32上移植uC/OS II時0x1000000內存溢出錯誤已解決,不知道原因 [打印本頁]
作者: liuzhu    時間: 2015-9-10 00:50
編譯鏈接都能通過,但是在simulator里面就是一直有錯誤。
lcf文件的設置采用系統默認的.intvec start 0x08000000;
內存ROM劃分:從0x08000000開始
調試了幾天都出現這個錯誤:0x1000000內存溢出的錯誤。
uC/OS II運行到這里出現的如上錯誤:
;                                         START MULTITASKING
;                                      void OSStartHighRdy(void)
; Note(s) : 1) This function triggers a PendSV exception(essentially, causes a context switch) to cause
;             the first task to start.
;          2) OSStartHighRdy() MUST:
;             a) Setup PendSV exception priority to lowest;
;             b) Set initial PSP to 0, to tell context switcher this is firstrun;
;             c) Set OSRunning to TRUE;
;             d) Trigger PendSV exception;
;             e) Enable interrupts (tasks will run with interruptsenabled).
OSStartHighRdy
   LDR    R0,=NVIC_SYSPRI14                                 ; Set the PendSV exception priority
   LDR    R1, =NVIC_PENDSV_PRI
   STRB    R1,[R0]
   MOVS    R0,#0                                             ; Set the PSP to 0 for initial context switch call
   MSR    PSP, R0
   LDR    R0,=OSRunning                                     ; OSRunning = TRUE
   MOVS    R1,#1
   STRB    R1,[R0]
   LDR    R0,=NVIC_INT_CTRL                                 ; Trigger the PendSV exception (causes context switch)
   LDR    R1, =NVIC_PENDSVSET
   STR    R1, [R0]
   CPSIE  I                                                  ; Enable interrupts at processor level
OSStartHang
   B      OSStartHang                                        ; Should never get here
終于通過修改vector table和ROM地址從 0x00000000開始,程序可以正常跑了。
還不知道原因,后續還要仔細看下芯片手冊。
